05-25-2020, 11:14 AM | #1 |
Rep 25
Dynamic sequential mirror turn signals and DRL
Found this on Ali express. It looks like it can also act as a DRL when it's not being used as a turn signal.
I only see 2 sellers and 1 or 2 purchases and no reviews so far. Has anyone tried it and can talk towards if it's drop in wiring or if it requires some splicing or more? Also curious how bright the DRL really is |
05-25-2020, 08:39 PM | #2 |
A family of bimmers
2747
Rep 7,742
Searchbar has your answer. Search for sequential and you'll see a lot of results. I can't figure out how to link that from mobile app
05-25-2020, 09:20 PM | #3 |
Rep 113
don't know about the ones you posed above OP. My guess is you gotta splice I have the ones below https://www.uniquestyleracings.com/s...roduct_id=1305
they are drop in and play but they are just the turn signal not the drl or puddlelights. |
06-05-2020, 07:58 AM | #6 | |
Rep 144
07-04-2021, 10:58 AM | #7 |
Rep 25
FYI all, I bought them and yes they need you to splice. They're sitting pretty in my garage until I figure out whether it's worth it to see how to snake them into the door or another power source. I'm hesitating to splice into any of the other power sources in the mirror itself.
03-16-2022, 08:00 PM | #8 |
Rep 2
I also purchased this exact listing. In the end I was unable to run the wires from the side mirror to the headlight for the DRL function. I ended up using wiring connectors so that I have a Sequential turn signal and flashing puddle light.... Finding a way to connect them to the headlight was extremely frustrating and is going to take a lot more effort than expected. I now realize why I never see any bmw's with DRL side mirror lights haha. Also, if you don't have prior work or knowledge with wiring this will be a challenging task.
03-17-2022, 12:54 PM | #9 | |
Rep 2
03-28-2022, 11:34 AM | #10 |
Rep 308
After coding the mirror LEDs as marker lights perhaps using the below coding can also enable the mirror LEDs as DRL?
https://f30.bimmerpost.com/forums/sh....php?t=1378397 "Mirror with DRL as following Mapping_universal_1_output > 10 Mapping_universal_2_output > 11" If you use the above code please share your results here. I coded my mirror lights as markers 2 years ago and have had 0 issues. I would like to code/modify my mirror LEDs to be DRL white with ignition ON or LB and blink sequential amber.
2017 F31 328d xDrive
M Sport M Performance |
09-28-2022, 07:26 PM | #12 |
Rep 299
anyone been able to find the seller? i've searched far and wide and cant find this version of the blinkers anywhere..
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
10-12-2022, 01:44 PM | #13 |
Rep 308
Which ones, the sequential amber mirror lights? I got mine from Aliexpress. I got mine 2 years ago and they are still running strong. I code mine to stay ON with markers and low beam.
10-12-2022, 01:46 PM | #14 |
Rep 308
Not gonna happen without splicing wires and shit.
10-13-2022, 07:40 AM | #16 | |
Rep 299
Thanks heaps in advance |
10-13-2022, 07:41 AM | #17 |
Rep 299
10-13-2022, 08:07 AM | #18 |
Rep 16,079
It would be very easily done with Bimmercode in expert mode, or with ESys, if you know what to change. That you'd probably have to find out from someone who's done it. The beauty of the system that BMW uses is that any lamp can be assigned to any duty without the need to change any wiring. The trick lies in knowing how.
10-13-2022, 11:23 AM | #19 | |
Rep 308
I done have picture hosting, so no go on posting pics. I ordered 2 years so I cannot find the EXACT item. But before buying, I looked for a buyer which sold most of that item and with the most favorable reviews.
10-13-2022, 11:24 AM | #20 | |
Rep 308
10-13-2022, 02:33 PM | #21 |
Rep 16,079
I'd figure it out if I had any interest in doing that mod, but I don't. Before investing in it I'd want to see full instructions on how to do it from someone who did.
