BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding HU_NBT2, missing text in menu after completed
      01-17-2022, 05:53 PM   #1
delltron382
Drives: BMW 330i Xdrive
Hey guys so I am still very new at all of this so I apologize. I was adjusting some of my FDLs, coding completed with "0" errors, but on reboot I am now missing most of the text in all my menus and sub menus. Any ideas what may have happened so I can avoid it in the future? And also what is the proper way to revert back to my saved backups? Do I need to re-code both VO and FDLs? Thank you in advance.
      01-18-2022, 12:35 PM   #2
Siki78
Siki78's Avatar
136
Drives: F30,G30
Did you fdl code from ID5 to ID6? You should to choise ID6_light not ID6
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      01-19-2022, 04:01 AM   #3
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
language settings are incorrect in KOMBI and HU_NBT2
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
      01-20-2022, 09:58 PM   #4
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
VO code the KOMBI and it should come back.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      01-20-2022, 10:36 PM   #5
delltron382
I have ID6 I'm pretty sure. Software version is NBTevo_Y21432J
      01-20-2022, 10:39 PM   #6
delltron382
Ah ok I'll give that a shot. Do I need to change anything in the VO?
And if I want to code fdls, how do I know if I should or should not code the VO also?
Thanks for the help
      01-21-2022, 10:53 PM   #7
steve@codemybimmer
Hong Kong
665
Thanks for the help
Use the original FA and VO code both the KOMBI and HU_NBT2 and it will set the language master back to English US on both.
FDL coding is fine but just don't mess with the language settings.
      01-23-2022, 11:06 PM   #8
delltron382
Ok Sweet. Thanks I got it all back working now.
For future reference, when is VO coding necessary and when is it not? I have been a little confused about that. I appreciate the help
      02-26-2022, 03:49 PM   #9
Keewee
Keewee's Avatar
New Zealand
Drives: BMW F30 328, BMW F10 550
2012 550i  [0.00]
2012 328i  [0.00]
Hi, Did you get this sorted as I have lost all my text after VO coding. Mine is CIC however.
