10-16-2021, 08:43 AM | #1 |
Rep 766
NY shops required to purchase new inspection machine
I wonder if the new inspection machine will check the ECU/DME for OEM software or not. Just a thought. The message came up yesterday morning when I booted up the current machine in our shop.
10-20-2021, 12:47 PM | #2 |
Rep 766
Confirmed - next year any car in ny with a tune, regardless of readiness monitor status, will fail ny inspection. Also we will be required to do a 360* walk around the car with an inspection camera, and the catalytic converter must also be photographed for the inspection.
10-20-2021, 01:03 PM | #3 |
Rep 5,457
Drives: F30
10-20-2021, 03:19 PM | #4 |
Rep 1,811
how will it know you're tuned? and also is this just any type of coding? like if you retrofit parts into your car that require coding is that going to flag the machine?
10-20-2021, 07:06 PM | #5 | |
Rep 766
This is tunes only. Coding is a non-issue |
toxik2435.00 |
10-20-2021, 08:26 PM | #6 |
Rep 738
Drives: '11 328xi |'18 440xi GranCoupe
Yikes, I don't get why it would fail with a tune if CAT is still present. If the tune doesn't effect emissions it should be a non issue.
10-20-2021, 10:55 PM | #7 |
Rep 39
can't we just flash back to stock before the inspection?
imperfectluck425.00 |
10-21-2021, 07:09 AM | #8 |
Rep 1,597
Looks like they are getting serious short of bringing back the sniffer test for exhaust gas. The cat eye-check is legit but some high flow cats look normal. I wonder if they can't be challenged on the tune. What is next? Improper coding fails inspection too?
10-21-2021, 01:16 PM | #9 |
Rep 419
I second this, since most platforms makes a copy of the original tune and assuming it doesn't modify it, the MD5 checksum should match up. If that's the case then I would only see this problematic if they can sift through the log history to see how many flashes have been done against the DME similar to how BMW can already do so today.
The more concerning part is the photographing of the cat. Curious to see if they're going after the catless or if the high flow catted people like myself will fall into that category. Forthose that cannot easily revert back to their stock tunes I can see it becoming problematic. Interesting to see NY becoming the second after CA with these kind of checks. And now I wait patiently to see how folks plan to get around this one |
11-13-2021, 01:01 PM | #11 |
A family of bimmers
2745
Rep 7,741
Where is the proof of this? I saw the exhaust law for increasing fines of aftermarket exhausts or devices to make them louder.
11-14-2021, 09:15 AM | #12 | |
Rep 766
https://www.nyvip.org/PublicSite/Pag...wer.aspx?ID=78 |
11-17-2021, 10:06 AM | #13 | |
Rep 14
12-04-2021, 05:11 PM | #14 |
Rep 15
Why is this not being discussed more? This seems like huge news.
My question is -- will using a BMW M performance exhaust, will you still fail? Technically an OEM part, but also technically a modification since my car did not come with this out of the factory. Can anyone clarify? |
12-08-2021, 09:30 PM | #15 | |
Rep 4
05-22-2022, 11:14 AM | #16 |
Rep 1,934
How is this going for you guys in NY this year?
08-14-2022, 05:40 PM | #19 |
Rep 136
08-15-2022, 05:15 AM | #20 |
Rep 766
08-15-2022, 06:43 PM | #21 |
Rep 30
I just moved to NY from CT recently and NY seems a lot stricter. Are these new regs part of the 'emissions' inspection, or just the 'safety' inspection?
