BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Part# Vapor Barrier
Studio RSR
      11-20-2021, 08:00 AM   #1
BNTLY
Master Chief
Drives: F34
Part# Vapor Barrier
Anyone replace their vapor barriers (SOUND INSULATING DOOR)? I’m looking for the part# for the rear right. I appreciate any input plz and thanks.
      11-20-2021, 09:57 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
https://www.realoem.com/bmw/enUS/sho...53#51487343922
Don't replace it, cover it with this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I've lined all my doors and trim with this vinyl mastic, including the underside of my parcel shelves.
      11-20-2021, 11:03 AM   #3
BNTLY
Master Chief
Drives: F34
Nice, you provided both — much appreciated.
      01-10-2022, 06:51 PM   #4
BNTLY
Master Chief
Drives: F34
Took the door panel off, inspected the vapor barrier and it was still sealed really well. Dynomatted the vapor barrier and went for a car wash. Still leaking ahhh!
      01-10-2022, 09:44 PM   #5
Billfitz
Billfitz's Avatar
Leaking where? Doors aren't watertight. Water will make its way past the window gaskets, it drains out of weep holes at the bottom of the doors. That's why the sills get wet.
      01-11-2022, 12:12 PM   #6
DavidSTryk
Denmark
23
Drives: BMW 320D F34 Gran Turismo
https://www.amazon.com/gp/product/B0...UTF8&psc=1
The underside of the parcel shelf ? No problems getting it to stick to it ?
      01-11-2022, 12:49 PM   #7
Billfitz
Billfitz's Avatar
I first coated the underside of the parcel shelves with spray on adhesive to give the adhesive on the mastic something to bond to. It works a treat.
      01-11-2022, 10:37 PM   #8
BNTLY
Master Chief
Drives: F34
Leaking from under the RR door either gasket or drain holes into the RR floor. Cleaned out the drain holes before sealing too.
      01-12-2022, 07:22 AM   #9
Billfitz
Billfitz's Avatar
The only way to be sure if that's related to the door is to pull the door card and then put enough water on the car for the leak to show up. I've seen reports of water on the floor coming from multiple sources, most of them not the door. Don't discount the moon roof seals.
