10-01-2018, 02:57 PM | #45 |
Rep 37
Changed the springs today. Damn, this car should have came with these springs from the factory. So much calmer ride compared to the stock wobbly springs . I am not afraid at motorway speeds anymore.
Got a mild drop too, maybe 20mm. Should have changed these sooner. |
10-02-2018, 08:57 AM | #46 | |
Rep 1,343
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
10-02-2018, 12:55 PM | #47 | |
Rep 37
I put the 403Ms on, here is a crappy picture from crappy angle. Can't really see the drop, sorry. I will take a picture tomorrow from the side, if I remember before its too dark |
D's Bimmer235.00 |
10-02-2018, 02:03 PM | #48 |
Rep 1,467
I am xdrive lowered on kw v1's. Phenomenal upgrade; without it, the car doesnt even compare.
https://f30.bimmerpost.com/forums/sh....php?t=1367923
10-02-2018, 07:45 PM | #49 |
Rep 1,348
The ACS springs are better than stock but still needs a better than stock shock and strut setup. Does not inspire as much confidence as I would like but still a better ride quality and handling than stock springs. The drop is just right as well.
2k15 335i Msport xdrive 6spd
10-03-2018, 09:54 AM | #50 | |
Rep 86
I owned an E92 xDrive with KW V1's, and while it was a better "complete" suspension setup, I'm not unhappy with just ACS springs. The springs were enough to get rid of the coilover itch until the factory shocks give out in a few years. I also think this car rides better than the KW V1's did, but handling with the V1's is on a different level. Right now, I prefer the comfort. |
10-03-2018, 07:08 PM | #51 | |
Rep 1,348
01-27-2019, 06:20 AM | #53 |
Rep 102
01-29-2019, 11:01 AM | #54 |
Rep 1,261
01-30-2019, 07:18 AM | #55 |
Rep 1,064
https://f30.bimmerpost.com/forums/sh....php?t=1569536
i lowered with Eibach Pro Kit + stock dampers last month. happy so far! i think eventually I will put B8's on to replace the stock shocks. |
02-14-2019, 12:02 PM | #56 | |
Humanist
272
Rep 398
'19 F31 M Sport Estoril Blue : '16 F80 M3 ZCP Mineral Grey : '15 E84 X1 M Sport Le Mans Blue : '13 E92 M3 ZCP Alpine White '10 E82 135i M Sport Le Mans Blue : '99 E46 328i Sport Fern Green : '95 E36 M3 Cosmos Schwartz : '95 E36/5 318ti Clubsport Jet Black |
02-18-2019, 01:04 PM | #57 |
Modder of everything I own
147
Rep 491
No spacers. I screwed up though, I am a bit wider than I wanted to be although i do love it. I could have went with a bit larger offset and used spacers to tweak it to move it out to fall just short of the lip. I have it set really stiff so I don't rub, which I like so it's actually fine.
I have 19x9.5 20mm offset wheels.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
02-21-2019, 08:04 AM | #58 |
Rep 1,467
KW V1, no spacers needed. Flush in back, slightly inset in the front.
02-22-2019, 10:08 AM | #59 | |
Rep 1,502
Drives: F36 435xd
If anyone knows of the reseller in EU, please let me know.
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
02-22-2019, 11:24 AM | #60 |
Rep 1,467
These wheels are for sale with TPMS. I have new ones I am putting on. They are stance sf03 wheels.
02-22-2019, 12:10 PM | #61 |
Rep 1,502
Drives: F36 435xd
Yea, but you are in the US and I’m in Europe in a country with high tax on imports.
Otherwise I would be int in buying. What size are they?
Brgds
02-22-2019, 12:19 PM | #62 | |
147
Rep 491
I had issues after lowering, blowing out my Right front inner ball joint. It started after I lowered about 3", maybe a bit more. I lost 3 axles (all right front) since last summer but the last time the axle support bearing housing broke as well. I destroyed the right front of my car a couple of years ago so I'm thinking the support bearing housing could have been cracked since then and I never noticed it and with lowering it I put more stress on the axle support bearing so the housing allowed more play in the end of the axle at the differential and then it finally broke early Feb. I've replaced my axle support bearing and housing along with the motor mount to assure there was not excess play and I'm hoping that solves my issue.
02-22-2019, 04:20 PM | #63 | |
Rep 1,467
Looks like you have different coil overs. I would also check your camber on your alignment. I know that can really affect the front axles. Looks like you also have different sway bar in the rear not sure about the front but that could make a difference. How hard was the rear sway bar to install? And did you notice a difference?
02-22-2019, 07:23 PM | #64 | |
Rep 227
Drives: 2000 BMW E39 M5
The rear sway bar upgrade definitely reduced the amount of rear body roll (obviously), but it's a little bit less composed over asymmetrical bumps. It's nothing crazy, but the rear jostles just a bit more than before. Eventually I'll get around to doing the front sway bar too, but will need to set aside a couple of days for that one. It's supposedly even more difficult than the rear.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
02-24-2019, 10:17 AM | #65 | |
147
Rep 491
The rear swaybar was really easy to replace (I did use a lift though so that makes most things easier), I changed it the same time I installed the coilovers and the Rear subframe bushings so I can't really evaluate the swaybar by itself but everything I did noticeably tightened up the rear end. I haven't changed my front swaybar yet.
