10-13-2018, 02:51 PM | #1 |
Rep 3
Problem with tail light
Hello, looking for some help with my issue for my 2014 f32. My right side tail light works when I press on the brake but it doesn't turn on when I put my headlights on. Sometimes my turn signal would stop working too but would fix itself. I replaced the socket fixture and bulbs but still have the same problem. Any help would be appreciated. Thanks.
10-13-2018, 06:00 PM | #2 |
Rep 1
having similar issue with taillight. after investigation, it appears there was a short and the brown wire pin from the housing burnt into the connector. thought cars had fuses to prevent this type of thing . anyways, was able to dig the burnt pin from the connector and have a new bulb housing on order. The pin receptacle is a bit mangled, so hard to say if it will fix the issue.
might pull the taillight again and inspect the wiring. HTH |
10-13-2018, 06:09 PM | #3 | |
Luxury at the redline :)
9105
Rep 7,563
I am pretty sure that's yours and OP's issue with the tail light.. BMW been having issues with their tail lights since the E46, nothing new. |
10-13-2018, 10:30 PM | #4 |
Rep 3
Thanks for replying. Is there built in led bulbs in the actual tail lights? I swapped my entire working tail light from the left side and plugged it in the right side connection and it worked. Took the non working tail light and did the same to left side connection and it had the same exact issue leaving me to believe the entire light fixture is bad.
10-13-2018, 10:54 PM | #5 | |
9105
Rep 7,563
The LCI is all LED lights with the exception of the reverse light bulb. It is possible that the LED for the tail light is burned out but there are more than one LED in there for the tail light, so it's little odd that both are defective. I think there might be a short within the tail light unit, thus the burnt-out wire. Probably best to replace the harness, re-pin the ground wire and replace the one defective tail light. Harness part number: https://www.ecstuning.com/b-genuine-...g/61132359993/ |
04-10-2019, 11:33 AM | #7 |
Rep 1
Rear Driver Side Light Malfunction
Hello,
My rear driver side lights keep malfunctioning. I get the error message "rear brake malfunction" and "rear turn signal malfunction". I have a 2015 320i and I do have a bumper to bumper that will cover this with a $250 deductible that I would like to avoid using if possible. I have changed the bulbs multiple times and even replaced the panel that you plug the bulbs into to no avail. It will work for a couple days then they go out and I get the same error. Any help?? |
