10-08-2021, 12:35 PM | #1 |
Rep 69
New to BMW. 2013 335i 99k miles.
I bought a used BMW. I have went through it and changed plugs, gaskets, belts, trans oil, cleaned vanos, charge pipe, and put a Bm3 tune.
I'm looking for a reasonable price suspension upgrade. Any recommendations? Also is there anything else I should keep an eye on with this many miles. Car rips pretty well after the tune. |
10-08-2021, 03:22 PM | #3 |
Rep 69
10-10-2021, 01:46 PM | #5 |
Rep 69
10-11-2021, 01:54 PM | #7 |
Rep 887
Drives: F32 428i Xdrive
Love the m6 wheels! what tires and sizes?
10-11-2021, 02:03 PM | #8 |
Rep 22
10-12-2021, 03:08 PM | #9 | |
Rep 887
10-12-2021, 03:09 PM | #10 | ||
Rep 22
10-12-2021, 03:44 PM | #11 |
Rep 7,591
Highly recommend going to 245/35/19 front if you are running 8'' wheel
https://f30.bimmerpost.com/forums/sh....php?t=1678451 |
10-13-2021, 05:41 AM | #12 |
Rep 383
I haven’t heard great things about the ride quality of the BC coil overs.
If this is a DD and you don’t care about adjustable damping/ride height consider the BMW M Performance suspension. The dampers and springs are right in your target price point from getbmwparts.com. It’s a 20mm drop from base suspension (10mm from m-sport), and the springs are tuned correctly to the dampers, and maintains Flat Ride (which most aftermarket kits do not). It also suggests using the m-sport sway bars, and you’ll probably want to upgrade that as well with any suspension, if you are on base level suspension. I’m building my car as a DD/SCCA autocross STU and I’m pretty much convinced this is the best option unless you spend over 2k+ |
10-13-2021, 06:44 AM | #13 | |
Rep 69
10-14-2021, 12:23 PM | #14 |
M340i
392
Rep 953
Drives: BMW M340i
Got a link for the complete m performance suspension for 1k? Seems to be a lot more.
10-14-2021, 01:02 PM | #15 |
Rep 5,390
I have the same car. Great combination is Koni Special Actives with mild Eibach springs that lower <1".
10-14-2021, 05:29 PM | #16 |
Rep 383
10-14-2021, 09:41 PM | #17 |
Rep 221
Another vote here for the M-performance suspension.
I got it from bmwpartspros for about $1k. You have to use the dropdown to add springs. If you select the option w/o M Suspension, then you'll also get the beefier sway bars. |
10-16-2021, 08:16 PM | #19 |
M340i
392
Rep 953
Drives: BMW M340i
Wow you bought a 100k mile BMW? I hope you own an auto garage. Good luck.
10-16-2021, 08:28 PM | #20 |
Rep 69
