BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 30K miles and Oil Filter housing Gasket Failed?
      09-27-2018, 11:10 AM   #23
krnlight
Drives: BMW 335xi
Just dropped off my car for an oil change at 40k and was told that I've got both the oil pan and the oil filter housing gasket leaking...mine still is under the CPO warranty so I just need to pay the deductible to getting this fixed.
      09-27-2018, 03:00 PM   #24
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Taking mine into the dealer tomorrow for a scheduled appointment because they saw oil all over the drivers side of the block underneath the intake manifold. Car has only 48k miles. 2k miles short of warranty expiration.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      09-27-2018, 04:17 PM   #25
lkstaack
lkstaack's Avatar
Drives: F30 335i
Way too many early gasket failures on this engine. I replaced my stock oil cooler with a larger one. Hopefully it will delay these gasket failures, but who knows?
      09-27-2018, 11:15 PM   #26
Tchao
Boost Addict
Tchao's Avatar
334
Drives: E30, E82, F30, F87
N55 is no different than every BMW engine since the M50 as far as common parts failure goes.
Expect every inline 6 BMW to have coolant and OFHG problems. Except N54, then you also have another phone book of things that fail often.
S55 M2C | Three Pedal Club | E30TU
      09-27-2018, 11:37 PM   #27
lkstaack
lkstaack's Avatar
Drives: F30 335i
No different? Did you notice that little twirly thing under the exhaust manifold? It tends to keep things kinda hot.
      09-28-2018, 07:46 AM   #28
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
I guess time will tell. You are right in that engine components, especially plastic and rubber ones will fail earlier due to the increase under hood temps. I'm thinking that a vented hood might actually help in this regard. Regardless even NA BMW engines are notorious for gasket leaks (OFHG, VCG, OPG) and coolant leaks so we can expect shorter lifespans with the turbo engines.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      09-29-2018, 01:49 PM   #29
lkstaack
lkstaack's Avatar
Drives: F30 335i
Owning two E46s for over 10 years, I have replaced valve cover gaskets, oil filter gaskets, Oil level sensor gaskets, crank case gaskets, VANOS sensor gaskets, etc. However, with the exception of VCGs, they generally last 100K miles or more before they need to be replaced. Not so with the N55. All of these gaskets, not to mention warped valve covers and transmission pans, need replacing far, far earlier.
I would seriously consider a vented hood if there was a quality one commercially available.
      09-30-2018, 10:28 AM   #30
ceedawg
ceedawg's Avatar
468
As I posted before I believe I saw a lot of moist oil sludge on the passenger side of the block under the intake manifold but a lot. Well below is what they are claiming is the fix so we will see. My car has 48,420 miles ,factory warranty expires Oct 22 2k18 I was told also but I have an extended warranty.
I think they're full of it but I will check in a few miles to see.
      09-30-2018, 11:39 AM   #31
lkstaack
lkstaack's Avatar
Drives: F30 335i
It's certainly possible that the cap gasket failed, but I would also expect a rough idle due to a vacuum leak if it was the cap.
      09-30-2018, 02:03 PM   #32
ceedawg
ceedawg's Avatar
468
I agree and I never ever had an idle nor stall issue.
      10-16-2018, 10:44 PM   #33
lkstaack
lkstaack's Avatar
Drives: F30 335i
Oil filter housing gasket failed on my E46 at around 100k miles and at 37k miles on my F30. BMW needs to figure this out.
51K miles and the housing gasket failed again.
      10-17-2018, 07:44 AM   #34
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
Wife's 2013 X1 failed at about 55k miles. We replaced gasket and water pump. While you;re in there, have them do the water pump too if your mileage is 'close enough' to dictate it since they seem to be in the same basic area.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      10-17-2018, 09:30 AM   #35
JaredG_F30
JaredG_F30's Avatar
1106
I'm glad I have the CPO extended warranty but since I plan on keeping this car for a long time (eventual track rat) I guess I'll need to get good at changing the OFHG.
      10-17-2018, 04:26 PM   #36
lkstaack
lkstaack's Avatar
Drives: F30 335i
The electric water pump isn't near the oil filter housing on a F30 335i. Also, the electric pump isn't problematic like the older plastic belt driven ones.
When I removed the filter housing, I may have discovered why it failed after only 14k miles. It's supposed to be torqued to 16 ft lbs, but my housing (installed by a dealer tech) was torqued much higher. About 35 lbs, I guess.
      10-18-2018, 05:23 AM   #37
enjoythemusic
364
Thank you, learn something new every day. Thanks for the added info and truly do appreciate it.
Enjoy the Drive,
Steven
      10-21-2018, 02:06 PM   #38
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
This was brought to my attention at my 63k oil change service, almost exactly 3 years after I took delivery. I never saw the oil level go down or any drips, but it was making a mess.
Oil change, Vehicle Inspection, and the gasket repair was $1132 with NJ sales tax included at Park Ave BMW. I also threw the tech $20 to take some extra care cleaning up the mess.
      10-23-2018, 12:51 AM   #39
jh_f30
jh_f30's Avatar
1307
Drives: 2013 335i Sportline Auto RWD
Ouch. $20 for oil cooler and oil filter housing gaskets and a few tools and I did mine in about an hour.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      10-23-2018, 12:55 AM   #40
2014 335i  [9.74]
Not buying the hour talk, but it's irrelevant anyway.
Living in a condo has advantages and disadvantages. One disadvantage is not having a driveway that's conducive to tinkering on my car.
F32Fleet3570.00
      01-12-2019, 08:22 PM   #41
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
When people are saying they get this done under 3hrs, are they also draining oil and coolant?
I'm doing research to see if I want to diy, since indie quoted me 865 for the OFHG, Belt and tensioner. They got oil all over them from the leak.
      01-15-2019, 09:02 AM   #42
Tchao
Boost Addict
Tchao's Avatar
334
No oil draining required. Just residual losses.
But forsure coolant loss. Just refill the the coolant, make SURE to leave the proper amount of air in the expansion tank. This is how the system bleeds.
Run the car with the cap off until you see bubbles stop entering the expansion tank from the bleed line, then just cap it and any residual air will find its way into the expansion tank. BMWs are one of the easiest to bleed.
Definitely do the tensioner and belt while you are there. Another super easy job with lots of DIY's posted.
Logicoeur991.00
      01-15-2019, 08:47 PM   #43
jh_f30
jh_f30's Avatar
1307
Hmm, that coolant bleed process is a little different from what I've done. I fill the tank with the bleeder screw off until coolant starts to slightly flow from the bleeder hole. Screw it back in, cap it off, then run the bleed cycle (battery tender hooked up, ignition on, engine off, heater on full blast at max temp, press and hold gas pedal past the kickdown for 10-12 seconds. Starts the pump cycle that lasts around 10-15 minutes. Check the coolant level and adjust if necessary.)
      01-15-2019, 10:00 PM   #44
Logicoeur
Logicoeur's Avatar
991
Is this a documented bleeding procedure? I am hard pressed to understand how and why that works lol. How and why is the gas pedal mapped to starting some kind of pump in the coolant system? Is there a secondary pump just the the cabin heating loop?
