BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Amplifier Upgrade to HK System (F32)
      06-17-2021, 11:33 AM   #1
spiritbreaker
Drives: 2015 435i
In the market for a plug-play amplifier upgrade (inclined to get used ones) to compliment the SVS 8W woofers. So far looked at Bimmertech and Bav, any others in the market?
Thanks!
      06-17-2021, 08:45 PM   #2
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Thanks!
mObridge MOST25 8.1.1 AMP
      06-18-2021, 08:49 AM   #3
spiritbreaker
Drives: 2015 435i
that seems to be a very hefty amplifier, anything on the low end?
      06-18-2021, 09:14 AM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
There are no low priced options for BMW amp replacement. The most economical upgrade for use with SWS woofers is to add a separate amp for them. In so doing the H-K amp runs cleaner, as its power supply is no longer taxed by the woofer current draw. This should help: https://f30.bimmerpost.com/forums/sh....php?t=1730058
      06-18-2021, 10:01 AM   #5
spiritbreaker
Drives: 2015 435i
That's what I've been speculating after going through this thread https://f30.bimmerpost.com/forums/sh....php?t=1311415
I've just ordered the technic's add-a-sub harness (https://technicpnp.com/product/hifi-...sub-harnessloc), now contemplating on what amplifier should I go for?
Since the current woofer setup seems to be stereo, having thoughts on if I should I go mono or stereo amp while reminding myself that I just need more punch and not going bonkers on the budget.
      06-18-2021, 11:23 AM   #6
Billfitz
Billfitz's Avatar
There's no such thing as stereo subs. Low frequencies have been summed to mono in the studio on virtually all recordings since subs first came along in the 1970s. I'd say the amp Johnung used works well based on his experience. Where dual channel amps are used to separately power dual subs the signal content is the same to both.
      06-18-2021, 12:20 PM   #7
spiritbreaker
Drives: 2015 435i
On my way to grab the kicker cxa600.1!!1
Any quick walkthrough on setting these up? Does the harness from technic send the signals back in or should I need to re-wire the SWS 8Xis?
Thanks for clearing things up.
      06-18-2021, 05:28 PM   #8
johnung
The AudioControl ACM-2.300 that I used was ideal for a few key reasons:
1) Small size. I ended up mounting it on top of my tool kit cover in the right alcove in the trunk. Out of the way. Doesn't take up trunk space and easy access to power and ground near the battery.
2) Contains a built-in LOC so I didn't have to find more space for another box. A LOC is required to take the speaker level outputs from the Technicpnp harness and connect them to the secondary amplifier. The HK amp has no other way to connect a secondary amplifier. Also a cheap LOC cannot be used. The cheap ones can only handle lower voltages. The HK puts out the higher level signals.
3) Has exactly the right amount of power to supply the Earthquake SWS-8Xi (2-ohm) subwoofers. The AudioControl ACM-2.300 puts out two channels of 150watts/channel into 2-ohms which is what the Earthquakes are rated. Turn down the gain on the amplifier slightly because if you go over 150watts per channel, Earthquake tech support warned me that it could blow the subs.
I searched for amplifiers and LOCs for over a month before I found this AudioControl amplifier with these exact features. Be careful if you try another LOC and amplifier, that they meet these requirements. If I was going with a separate LOC I would suggest looking at the AudioControl product line because they make high quality stuff.
Hope this helps!
      06-18-2021, 05:30 PM   #9
johnung
Photo of AudioControl ACM-2.300
      06-18-2021, 08:21 PM   #10
Encanto
Encanto's Avatar
The under seat speakers are woofers, BMW call them "subs" for promotional and not technical reasons.
The woofers are wired and processed in stereo in all BMW OEM audio systems. Play a stereo 50Hz tone and it will sound left and right discrete.
Go.
      06-19-2021, 09:09 PM   #11
spiritbreaker
Drives: 2015 435i
Go.
I had the same theory since I was able to isolate the channel when I changed the balance from my media player
      06-20-2021, 08:14 AM   #12
Billfitz
Billfitz's Avatar
Read my post again: 'Where dual channel amps are used to separately power dual subs the signal content is the same to both.' Dual amps are often used to power dual drivers when the load impedance of dual drivers parallel wired would be too low for a single amp to handle. The low frequency content sent to both amps is the same. That's because "Low frequencies have been summed to mono in the studio on virtually all recordings since subs first came along in the 1970s." Stereo only exists in the midbass and higher frequencies, where the content of the left/right channels is different.
      06-21-2021, 12:01 PM   #13
spiritbreaker
Drives: 2015 435i
How did you wire the woofers from the amplifier?
      06-21-2021, 01:12 PM   #14
johnung
I ran new speaker wire from the AudioControl in the trunk above the battery to the underseat sub boxes, but the Technicpnp harness can utilize the existing BMW speaker wire to the underseat boxes as well. It should be on the wiring diagram that came with the harness.
      06-21-2021, 05:39 PM   #15
Encanto
Encanto's Avatar
The under-seat woofers are not subs.
      06-29-2021, 07:21 AM   #16
spiritbreaker
Drives: 2015 435i
Woofer: SWS 8Xi
Amplifier: Kicker CXA600.1
Install time: 3hrs
Results: Totally blown away.
Billfitz5414.00
