09-09-2020, 08:35 AM | #177 | |
Rep 80
0W-20 product EZT, has sec CC3 plus a VW only spec, this oil was developed for VW only. |
09-09-2020, 08:53 AM | #178 | |
Rep 80
When LL17FE+ is met there is not need to mention LSPI. I don't see that on the certificates posted for other oils either. You must be an insider to know that Amsoil is balking at approvals Their products have have performed well for me since 1978. I have had it lab tested ok after using one batch for 35000 miles. What's the problem. |
09-09-2020, 09:45 AM | #179 | |
Rep 498
09-09-2020, 12:20 PM | #181 | ||
Rep 10,367
https://www.acea.be/news/article/ace...ly-2020-update. Hit hyperlink REV3.
"Drive more, worry less. "
09-10-2020, 08:16 AM | #182 |
Rep 80
09-10-2020, 09:35 AM | #183 | |
Rep 498
Have you tried asking Amsoil if you can pay even more for your platinum double diamond status? Here's another 6 oils that meet BMW 17 FE+, but sadly no scamsoil: ELF EVOLUTION FULL-TECH APX SAE 0W-20 TOTAL Lubrifiants Mabanol Xenon Alpha FE SAE 0W-20 Mabanol GmbH & Co. KG RAVENOL EFS SAE 0W-20 Ravensberger Schmierstoffvertrieb GmbH ROWE HIGHTEC SYNT RS C5 SAE 0W-20 ROWE MINERALÖLWERK GMBH SRS ViVA 1 ecosynth FE SAE 0W-20 SRS Schmierstoff Vertrieb GmbH TOTAL QUARTZ INEO DYNAMICS SAE 0W-20 TOTAL Lubrifiants You're spreading actual disinformation at this stage. |
09-11-2020, 08:26 AM | #184 | |
Rep 80
The Amsoil company produces over 55 different engine oils for the gasoline, diesel and natural gas fuels, in addition to almost a dozen gear and transmission lubes , compressor and hydraulic oils. The BMW market is a drop in the bucket of their overall market base. Responding to a self anointed oil guru who has his own ideas about what it takes to market products becomes meaningless. The industry itself becomes it's own policeman. Over the past 40 years that I have know the company there have been many stone throwers including other oil companies and all eventually go away. |
09-11-2020, 09:52 AM | #185 | |
Rep 498
Here is an actual R&D engineeer from an actual oil company discussing API vs ACEA vs Manufacturer Approvals: 4:26 If it's a good ole boy system, why is every other oil company able to get a certification from VWAG/BMW/Mercedes? Why did Amsoil pay for the process for the older formulations of their euro line? Say what you will about Liqui Moly being (truthfully) a bit overrated, they do put their money where their mouth is and actually attain manufacturer approvals for their products - unlike some companies. Again, I'm sorry you've wasted so much money and breath on being an Amsoil ambassador - maybe they'll refund your expensive membership fees if you ask nicely? |
09-12-2020, 11:19 AM | #186 | ||
Rep 10,367
09-15-2020, 06:16 PM | #187 |
Rep 104
Drives: BMW 328i
Back on topic a little bit. Why does my engine previously have BMW LL01 as the recommended oil (from the 2014 user manual). Almost all LL01 oils are 5W-30, and all are either 0W or 5W, 30 or 40.
Now BMW recommends Longlife-17 FE+? All of which are 0W-20? This seems like a bit of a deviation from the original spec surely? |
09-17-2020, 01:46 PM | #188 | |
Rep 10,367
09-18-2020, 10:15 PM | #189 |
Rep 104
Drives: BMW 328i
So 0w-20 is what I/ other N20/N26 F30 owners should do?
Maybe I'm just stuck on my old 5w-30 ways but it seems ironic to me that countless hours have been spent on the forums, backseat engineering the minute difference between whether 5w-30 or 5w-40 is better for your engine. Just for bmw to completely change the game on us. |
F32Fleet3606.00 |
09-19-2020, 09:43 AM | #190 | |
Rep 10,367
Billfitz8269.50 |
09-19-2020, 09:48 AM | #191 |
Rep 5,457
Drives: F30
@idopullups
I would not run 20 weight oil. Much too thin and only chosen by BMW (after LCI) to fluff up their fleet wide fuel economy numbers. The vast majority of N2X owners on here are running 30 or 40 weight as originally spec'd by BMW (as you indicated in your chart). |
09-19-2020, 10:28 AM | #193 | |
Rep 5,457
Drives: F30
The recommended oil for the N20 is 40 weight... per my owners manual. |
09-19-2020, 10:40 AM | #194 |
Rep 5,457
Drives: F30
I use Castrol 0w40 because thats what BMW recommends. They even go as far to say using anything lighter than 30 may cause engine damage.
Go head, run 20 weight |
09-19-2020, 11:10 AM | #195 | |
Rep 498
Us in the B48/58 realm have no real reason to not use 0w-20. |
09-19-2020, 11:12 AM | #196 | |
Rep 104
Drives: BMW 328i
"ensure that the engine oil belongs to one of the viscosity grades SAE 0W-40, SAE 0W-30, SAE 5W-40, SAE 5W-30" And I can link 50 threads debating which of the above is best for your N20/N26 depending on climate/ driving style/ engine age etc etc. Now the BMW technical service manuals state 0W-20 (LL-FE 17+) is recommended. https://www.newtis.info/tisv2/a/en/f...enance/1PSryV8 I'm sticking with my 5W-30 but I just find it funny is all. |
sspade2467.00 |
09-19-2020, 12:19 PM | #197 |
Rep 1,597
My dealer put in 0W-20 the last time they did mine. I did not notice until I changed the oil myself and sent it in for analysis. After 6 thousand miles, Blackstone detected much above average wear on iron, copper, aluminum. I would never put in 20 weight oil the way I drive.
sspade2467.00 idopullups45.50 |
09-19-2020, 01:50 PM | #198 |
Rep 16,128
They made the change to 0w-20 for CAFE reasons. Then dealers started using 0w-20 for earlier models as well, because they didn't want to have to stock more than one SKU. That more or less forced BMW to revise the service manuals. The acronym for why is CYA, but those in the know are aware that it's all happy horseshit.
