12-06-2018, 08:07 AM | #1 |
Rep 61
340i mppsk 2018 installed
Hello everyone, i have installed Mppsk a few days ago and I experienced the following:
- Feel more power specially on the mid range - when revving on idle in sport mode is awesome bit I realized only one flap is open even in cruising in sport mode Are the flaps suppose to open in sport mode or only one flap? Is there a difference when it comes to the flaps when cruising or in idle? Are the flaps should work in parallel or not? |
12-06-2018, 09:05 AM | #2 |
Rep 1,170
As Skyhigh stated in response to your question on the MPPSK gunshot thread, if only one valve is open, in any mode, you have a problem. Throttle position should not matter. Time to visit the Dealer.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
12-21-2018, 01:25 PM | #3 | |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
Ahmed Abdullatif14.50 |
12-21-2018, 01:36 PM | #4 | ||
Rep 61
As they asked the technical support in germany and replied the above. And ofcourse i cant tell if the other valve opens while cruising or not. |
12-21-2018, 05:45 PM | #6 |
Rep 3,865
Yes, most are. When I went to mine, they were clearly unaware there is a power-increase as well and thought the included SW is only in order to control the flaps.
Later (as they had problems getting the SW from Munich) they started talking about engine tuning (obviously read the installation manual)
Avodka144.00 |
12-23-2018, 06:59 PM | #8 |
Rep 25
It is a good idea to also settle on a flat rate for installation as well. As others have stated, you will see some dealers have difficulty installing the tune.
The dealers need to be more aware of their products. I came from a BRZ and Toyota/Subaru is more on top of their performance parts than BMW. At least, considering the few BMW dealerships I have spoke to. |
01-22-2019, 10:57 AM | #9 |
Rep 3,865
@Ahmed Abdullatif
I decided to check and what do I see - only the right one opens when stationary and switching to Sport (and giving a bit of throttle)!?!? The left one remained closed at all times during the test. I switched back and forth between Comfort and Sport/Sport+, but the left one never opened. I am puzzled!
01-22-2019, 03:14 PM | #10 | |
Rep 61
01-23-2019, 09:18 AM | #11 | |
Fool
1857
Rep 3,542
If only one is opening, I suspect they haven't used the additional loom that comes in the box to connect the other valve up.
01-24-2019, 03:44 PM | #12 | |
Rep 3,865
Starting with the bad: If only one opens at any time - that is as initially thought NOT NORMAL! Both valves are controlled simultaneously. Individual control is just not possible - they get the same electrical signal! So I now realized I have been driving for several months (if not from the start with MPPSK) with one disabled valve!! Good news: I found the reason for the above and it was totally simple - I looked under the car and inspected the wiring connection to the valves. And what did I find by touching the connector of the left valve (which did not open) - the connector was not properly inserted and was sticking out. It was not locked into its receptacle and made no electrical connection!! I clicked it in and tested again - who would think, both valves opened simultaneously!! You would not believe the difference in sound!! With only the right valve open, In sport the vehicle was maybe only about 20-25% louder than in Comfort. With both valves open (as it should be) - 100% louder!! I drove a few short trips today and it was just ridiculous So I advise you to check the connections and if that doesn't help - go get some help. If one opens, then the problem can only be in the connection of the second (or a defect in the valve itself).
01-24-2019, 03:54 PM | #13 | ||
Rep 61
Can you please show me the wiring for the valve so maybe i can fix it too. Because i went to the dealer and told its not an issue and i dont know what to do. |
01-24-2019, 04:08 PM | #14 |
Rep 3,865
That's why I said I have some bad news for you, but believe me - you are up for a big surprise once you fix it
Just look under the car (no lifting required!) at the passive valve. You will see the electrical connection. Pull the plug and see if it moves. Mine came right off. It needs to click/lock into the receptacle and should not be coming off by simply pulling it. If it is correctly in - try to unlock it and inspect it inside. If all looks good there, you will need to go somewhere where they can lift the car and inspect the entire wiring harness.
01-24-2019, 06:00 PM | #15 | |
Rep 61
01-25-2019, 02:56 AM | #16 |
Rep 3,865
You don't need to go under the exhaust, you just need to get your hands on the valve It is right there, the wiring and plug are on the upper side.
Machinebuilder278.50 |
01-25-2019, 06:47 AM | #17 | |
Rep 61
There is a difference and i feel it so well especially while cruising 😮. I owe you man atleast the headache with there is something wrong is gone and i know now the money is well spent. Thanks alot |
01-25-2019, 06:54 AM | #18 |
Rep 3,865
So same problem it was
Insane!! And the dealers didn't even bother checking!? Enjoy your "new" car!! ) I am in the same phase ) Out of curiosity - which valve was disconnected in your case - left or right?
01-25-2019, 08:49 AM | #19 | |
Rep 61
The left valve, did you have the same? |
01-25-2019, 10:00 AM | #20 |
Rep 3,865
Same. The left was off.
And yes - it sounds and feels like a different car now 😆
01-25-2019, 11:14 PM | #22 |
Rep 148
Yup, always easier to just say normal behavior rather than look at a diagram and take a few minutes to make sure things are connected properly. And most have no clue about MPPSK. I had to show them on the BMW website. When I got the car back they had installed the exhaust, but not the tune. The red envelope was left unopened in the glove box.
