12-07-2018, 12:51 PM | #1 |
Rep 1,309
NBT2 Evo / ATM bench coding
Good day!
I'm in the process of gathering parts to upgrade my e series car to NBT2. I have an NBT2 evo, a touch screen, and an ATM on the way, all used/ebay parts. I'd like to bench code them so they talk to each other before tearing apart the car. Has anyone done this? I need to code the NBT with the vin in the ATM if I have any hope of connected drive working, so I'll probably buy an FSC repair kit using the VIN of the ATM... but how can I read out the vin in the ATM? Can e-sys talk to the ATM through the OABR ethernet connection, or will I need to buy a ZGW? Thanks in advance! |
01-09-2019, 07:07 PM | #3 | |
Rep 765
01-10-2019, 01:41 AM | #4 | |
Rep 1,309
I don't have an F car and don't have a ZGW, so experimentation is difficult. I ended up buying an ATM from a local yard with a known VIN, and I'm going to return the ATM I bought of unknown origin. I still need to figure out how to flash my evo without an f car... Maybe I can rent/borrow a zgw and a can filter... |
01-10-2019, 02:59 AM | #5 | ||
Rep 202
Drives: 2011 M3 6sp
01-11-2019, 12:56 PM | #6 | ||
Rep 765
01-15-2019, 05:53 PM | #7 |
Rep 1,309
Haven't tried to code the ATM yet.
I sent back the one I got from laautoparts, which has an unknown VIN. I was told that if I connected it to an evo with a different vin, it would reset itself and be unusable, so I didn't bother with it. I now have a ZGW and I have upgraded my ID5 evo to the 2018-07 psdzdata. I updated the ZGW and evo to match the VIN of the vehicle the ATM came out of (this required purchasing an FSC retrofit kit from a guy in Italy). Once I find the connectors for making the OABR cable, I'm going to connect the ATM to the evo and see if it magically works, or if it blows up in my face. yay. |
Jhnblckwood130.00 |
01-15-2019, 05:54 PM | #8 |
Rep 1,309
(And yes, this is all on the bench)
Jhnblckwood130.00 |
02-27-2019, 02:26 PM | #9 |
Rep 536
02-27-2019, 02:46 PM | #10 |
Rep 1,309
It was in one of the 3 or 4 dozen threads I went through...
I don't think I believe it, since I accidentally left my ATM connected while working on another user's EVO in my car, and nothing got wiped, but I suppose there's a chance. I also found that I was able to read the ATM's donor vin from ESYS, contrary to what everyone had been saying. I needed to connect to it through a ZGW, read the coding, and it was one of the various coding items (there aren't many) |
03-04-2019, 08:54 PM | #11 | |
Rep 765
02-28-2020, 07:35 PM | #12 |
Rep 73
Mind elaborating on where you went too to read that vin ? Im also in the same boat
03-07-2020, 12:36 AM | #14 |
Rep 63
Hey guys, I’m not nearly as advanced as any of you are here. I do have a brand new ATM fitted to my F83, as well as a full NBT Evo retrofit. The Evo was bench coded and flashed correctly to my VIN. The ATM was not bench coded,( we were not aware this was possible,) and has never shown up on my E-sys to even code. It is connected with a retrofit harness I bought on eBay from a seller in the UK, and the GPS extension loop is connected as well. Right now I have an SOS error and no connected drive services, well because my car does not even recognize the ATM is there. I’ve replaced the battery but no luck.
Any and all help is appreciated, I’m not sure what I should do. The only thing I could think of was to have it removed and bench code it. Thanks |
03-07-2020, 08:48 AM | #15 | |
Rep 10,473
In simplistic terms, the ATM/TCB acts as a smartphone. It's like adding a smartphone to your account without the proper SIM the Network is expecting to be there. Just having a used ATM will not allow it to work on a Network without the proper SIM card. It simply will not work, even if your VIN was coded correctly in it. The SIM in the ATM is not assigned in the BMW Computers to your car, but another one. Read this thread: Activating Connected Drive, Live & Internet on a retrofitted NBT EVO https://f30.bimmerpost.com/forums/sh....php?t=1246508 |
03-13-2020, 05:50 PM | #16 | |
Rep 63
My ATM is brand new, unassigned. Does your advice still hold? Any suggestions on a dealer who’s had BMW do this before? Thanks again |
03-13-2020, 09:03 PM | #17 | ||
Rep 10,473
2 other posters have stated they did purchase from Dealer (Parts Department) and the VIN was required for purchase (to be pre-coded in ATM). If you will read those threads, you will notice I asked specific follow up questions (as I was surprised Dealer would sell ATM coded for a pre-LCI car that had a TCB. You will also notice both posters never again responded to their threads. So I have real questions about this myself, but only relaying what 2 others who have ghosted their thread have stated. I do know 100% if the VIN in the ATM and SIM doesn't match what's in BMW Connect's database, it will NOT be working. |
06-10-2020, 10:55 PM | #18 | |
Rep 63
07-17-2020, 08:41 AM | #19 |
Rep 14
Hey guys, I've been looking at what is needed to bench code a BMW headunit using an ENET cable and cant find a definitive guide on the EXACT requirements.
Could you please list the required cables/adapters/looms/control units etc? Much appreciated. |
07-22-2020, 07:52 PM | #20 | |
Rep 214
07-23-2020, 09:26 AM | #21 |
Coding ECU's remotely
445
Rep 1,172
For bench coding an NBT Evo you need a ZGW & can signal generator to wake the headunit and keep it awake - I have a set from this guy:
https://www.ebay.com/itm/COMPLETE-KI...YAAOSwVtZaKPrL And it works well except the can emulator I changed out for a better one. |
08-04-2020, 11:24 PM | #22 | ||
Rep 63
