11-27-2024, 09:25 PM | #1717 |
Rep 44,690
PM sent.
11-28-2024, 08:03 AM | #1719 |
Rep 12
Hi shawnsheridan , I tried to PM you but seem unable to as the system is preventing me from doing so.
Would appreciate if you could PM me as I really like to consult you on a matter. Thanks, Shawn! |
11-28-2024, 09:54 AM | #1720 |
Rep 44,690
Your PM function is disabled. Send one when enabled.
11-28-2024, 11:00 PM | #1722 |
Rep 12
Hi shawnsheridan , I have been reading several threads and you are certainly a legend in this forum.
I’m currently driving a BMW F10 (523i) variant and I’m currently experiencing some issues with my car instrument cluster wherein only the speed gauge works and the rest of the gauges (fuel, rev meter, and oil temp) don’t. My iDrive is showing me 4 faults, namely, ‘Vehicle Configuration Inconsistent’, ‘instrument cluster’, ‘cornering ability restricted’, and ‘SOS call system failure’. Apart from the unresponsive gauges, all else works fine with my car. I went to a local workshop earlier today who helped me with coding, using ISTA and E-sys. They told me my CAFD file is corrupted. Specifically, the KOMBI CAFD file does not contain my vehicle VIN, hence the fault codes are appearing and my gauges within the cluster aren’t working. For the other folders like CAS etc., my VIN is present when you read CPS. But for my KOMBI, my VIN don’t show when CPS is read and it shows some gibberish symbols instead (see attached). The guy mentioned that they can’t seem to code the KOMBI cluster as the system keeps kicking him out when he tries to patch the new CAFD data to the KOMBI folder. He suspects that my instrument cluster may have some short circuit issues. However, when they used the one diagnostic tool to test the rev meter, it moves and responds to the diagnostic tool executed commands. Hence, I’m not too sure if it is really an instrument cluster hardware problem which they suspect or just a pure coding issue. Thanks and grateful for any help or advice, Shawn. |
11-29-2024, 12:13 PM | #1724 | |
Rep 44,690
11-29-2024, 12:13 PM | #1725 |
Rep 44,690
PM sent.
11-29-2024, 12:33 PM | #1726 |
Rep 12
Thanks, Shawn.
Are you able to elaborate what you mean by that? I really appreciate any help / advice that you can give. Also, is it still possible to flash KOMBI if the KOMBI data is corrupted (KOMBI doesn’t recognise my VIN) like the image I sent in my previous posts? |
11-29-2024, 03:20 PM | #1727 |
Rep 5
11-29-2024, 04:40 PM | #1728 |
Rep 14
Thanks in advance Shawn
shawnsheridan
Looking for the link to ISTA+ I see you've been active today- appreciate it!! Last edited by NWMoss; 11-29-2024 at 04:41 PM.. Reason: fixed @ |
11-29-2024, 06:59 PM | #1730 | |
Rep 44,690
E-Sys - Flashing Guide v.1.0.1.pdf: https://mega.nz/#!p9JQhAwZ!JJ9ptw8Ti...JcnSUvG81nYMsw
11-29-2024, 07:00 PM | #1731 | |
Rep 44,690
The following users were not found: lmg03l
11-29-2024, 07:01 PM | #1732 | |
Rep 44,690
Or try Megabasterd: https://github.com/tonikelope/megabasterd
11-29-2024, 07:15 PM | #1733 | |
Rep 49
11-29-2024, 07:18 PM | #1734 |
Rep 44,690
Size is way too small. GLOBAL_4.39.20.7z alone is 18.53 Gb.
11-30-2024, 07:38 AM | #1735 |
Rep 12
11-30-2024, 10:18 AM | #1736 |
Rep 6
ISTA Link Request
Hi shawnsheridan , hope you're well. Could I please get the link to download ISTA + and ISTA/P or INPA (need programs for coding and diagnostics on my e92 2010 lci 325i)? Would be much appreciated, kind regards - Nabeel
11-30-2024, 10:34 AM | #1737 |
Rep 44,690
PM sent.
11-30-2024, 10:36 AM | #1738 |
Rep 44,690
No idea. If it can't be flashed, the car is broken in some way. Fix would depend on what's broke. Asking this is premature.
