BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Could JB4 Map 1 cause DME 118602/P2096?
Studio RSR
      09-01-2021, 07:56 AM   #1
Crispykickz
Drives: 2015 BMW 435i M-Sport
I have a '15 435i that has sporadically given me DME 118602/P2096 - Oxygen sensor before catalytic convertor fine mixture control, exhaust gas after converter too lean.
I understand this could be attributable to several things...more air in the system or a bad O2 sensor.
Here's the thing - it only comes on when I have JB4 Map 1 turned on. Additionally, it takes a really really really long time for it to come on, like months after switching to the map. It takes so long that I forget about it until one day it pops up.
The first time this happened, I cleared the code and switched to JB4 Map 0...the code never came back in over a year. Then I installed the MPE and was playing around with the exhaust flap settings and decided to turn Map 1 on again. That was several months ago...and then the code came back yesterday.
Would there be something in the Map 1 tune that could be causing this condition? If I came back within a few months with the Map 1 off - I'd consider starting to poke around to check for any air leaks..but its just fine with Map 1 off, so its got me confused.
I have a chargepipe and upgraded intercooler - but other than everything is stock.
Car drives fine with or without the CEL on.
Thanks!
      09-01-2021, 10:02 AM   #2
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Thanks!
yes it could. if it happens while using the map and then doesn't when you're not.. well, I mean
contact burgertuning and they will help you out.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      09-08-2021, 03:04 PM   #3
Crispykickz
Thanks ... this actually came back this time with all maps off. Will be taking to a shop next week for evaluation.
