12-13-2020, 01:22 PM | #1 |
Rep 28
Diamond cuts advice
Hey guys, after some tailored advice from the experts, I’ve just gotten my new car it’s a white (not sure what type but it’s not metallic)
Shadow edition f31 The alloys I don’t like, they are some 19inch ‘orbit grey’ diamond cut upgrades and I’ll be honest, they are no good to me!! I’ve read it’s best to clean diamond cuts weekly which I won’t lie will be a struggle but I’m willing to try, then after researching it seems a minefield of horror story’s of people using the wrong product and wrecking them even worse! So if anyone could recommend a brand of a product in best using that would be epic |
12-14-2020, 08:36 AM | #2 |
Rep 849
Drives: BMW 435i
I use the regular Griots Garage wheel cleaner (the green one). It cuts through the brake dust and it works well. The key is to use something mild and as PH neutral as possible.
EDIT: Just noticed you are in the UK, so Griots may not be available. I'm not sure what brands are available where you are, but P21S is a very gentle wheel cleaner. SONAX is also a good brand, but I'm not sure if their legendary wheel cleaner might be a little too harsh on the diamond cut wheels. I assume you're talking about the 442M wheels with the diamond cut faces? I'm not a fan either and really don't like how the clear coating starts to fail around the wheel hubs.
12-14-2020, 01:39 PM | #3 | |
Rep 28
And yeah I’ve already noticed a hell of a stone chip right in the centre which is only going to get worse! I can see my just having them powder coated black in the next few years, white car with shadow edition parts should probably look better anyway |
12-15-2020, 12:41 AM | #5 | |
Rep 5,391
01-18-2021, 04:03 PM | #6 | |
Rep 944
The brake dust won't get encrusted in a week, not even two. Just some build up that takes little effort to clean off. Using the soap solution is as safe as it gets. If there is some encrusted deposits left after that (usually there would not be), I find a little AutoGlym wheel cleaner is completely safe and easily shifts encrusted deposits that might have built up in the groove that goes behind the spokes. Let the product dwell for 30s after spraying, then agitate with a soft brush. Only go up to a stiffer brush (say a tooth brush) for the odd small area where the above approach fails. Hope this helps. |
01-18-2021, 04:11 PM | #7 | |
Rep 944
Even if it has started corroding, get a spot repair done before it spreads, and it will be unnoticeable from any reasonable distance. |
01-18-2021, 04:26 PM | #8 |
Rep 749
Drives: F31 320d xDrive M Sport
Whatever you clean them with, whatever you deal/protect them with... they will get ruined eventually.
Harsh/abrasive products, kerbing the wheels, and using a pressure washer are all ways to speed up the ruin. Never use anything more than regular hosepipe water pressure on them or it can force water underneath the lacquer, then it'll bubble and turn white (google "white worm wheel corrosion"). BMW wheels in particular are bad for it, and they never seem to fix it with later models. Maybe if they get bad and you can get them repaired under warranty you can get them fully painted or powder coated, so there's no diamond cut exposed metal.
