09-27-2017, 01:39 PM | #771 | ||
IG @bmwF9xG80
3813
Rep 7,593
Bring a fan with you or visit another Dynojet that has fans You will fail flashing if your JB4 is active on any map other than 0, for safety i would put it on map0 turn off car wait 1 minute disconnect from OBD2 lock doors wait 1-2mins so car goes to sleepy. Go back to car and connect the OBD2 to Enet cable, then press ignition without touching brake. Quote:
read above
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 09-27-2017 at 05:33 PM.. |
135iDCT138.00 |
09-27-2017, 02:19 PM | #772 | |
Boost Addict
334
Rep 349
Remember Lambda and AFR are not the same. You will indeed have the same lambda but your actual Air to fuel ratio will change, as you stated you are now dumping more fuel to keep the same lambda. Our sensors read lambda. Which then gets translated into gasoline AFR. But your actual AFR is changing with more Ethanol.
S55 M2C | Three Pedal Club | E30TU
09-27-2017, 09:01 PM | #773 | |
Rep 488
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
09-27-2017, 09:08 PM | #774 | |
Rep 2,360
(A Dane in China) |
09-27-2017, 11:16 PM | #775 | |
IG @bmwF9xG80
3813
Rep 7,593
09-28-2017, 12:19 PM | #776 |
Rep 1,805
Hey guys,
Quick couple of questions. Just sent in my "new customer form" with my vin to BM3 Saw 2 sections that I was curious as to what other guys have done. Burble -OEM -GTS Style vs Aggressive -What Burble option do you guys like? I have EWGN55 with DP and Remus axle back Cold Start -on vs off -Does this essentially open the exhaust flap on cold start so it's louder? Thanks guys, VERY excited to get the file loaded into the car! sounds like it only takes a couple days for them to turn it around BM3 FTW!!!!!!!!!!!!!!!!!!!!!!!!
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
09-28-2017, 12:45 PM | #777 | |
Rep 2,640
I have PWG, but if I had EWG. I would do GTS burble as the Agressive is too much for a DD, it's fun to have if you just wanna show off and make noise, but if you're driving around and doing track, GTS burble is perfect. Cold start I turned off as I'm catless. It quiets the exhaust for I'd say around 50% quieter. It's also better for the engine as cold starts are very bad for the engine. The whole point of cold starts is to warm up the cat for emissions. What it is basically is when you first turn on the car when it's cold, its loud for around 15-30 seconds and your RPM rises to about 1-1.5k to warm the cat. When you turn it off, it goes to around 6-800rpm (basically idle RPM)
PabloK597.00 |
09-28-2017, 01:17 PM | #778 | |
Rep 1,805
Thank for the help! How are you liking the BM3? I'm looking at your mods and my car is almost identical but with EWG. I'll be running pump gas 93. I'm switching from a JB4 setup, just curious on your thoughts of the BM3... Did they have a Pure stage 2 map for you? Is that their map called "Bootmod3 S2"? Thanks for your help man!
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS Last edited by PabloK; 09-28-2017 at 01:22 PM.. |
09-28-2017, 01:29 PM | #779 | |
Rep 2,640
Car feels great, and I'm very happy it's not like JB4 where it pulls timing and gets drivetrain malfunctions randomly. JB4 for me was a nightmare and there were too many damn wires. The damn Bluetooth adapter JB4 provided almost fried my DME as well. I was driving and one day the car threw literally every single code possible on the highway and I had to pull over to see wtf was going on. Literally had transmission overheat, engine overheat, transfer case, literally EVERYTHING popped, and a backfire came from behind as it did. I reset the car and everything was normal again. From then on, I sold the JB4 and Bluetooth and got Bootmod3. Had a problem with drivetrain malfunction as well, but it was due to the target boost being too high (nothing serious at all, I had PWG, and target boost was for 18-19psi but it should be 16 as that's where PWG turbo maxes out) and they reduced it. And from my 5 month ownership, never had any problems at all after that, just improvements to my OTS maps and such. Their customer service is top knotch, if you have ANY problems, send in a ticket or message them directly if it's urgent and they'll fix it in hours. I've sent in a log and had the revision done within a couple hours, and if I needed something done or a question, my answer would come very quickly. I've never had such great customer service anywhere else other than Pure Turbos, both of them are great.
09-28-2017, 01:44 PM | #780 | |
Rep 1,805
Did you go ahead with the $300 custom map or do you think the supplied map is sufficient for us? Really appreciate the in-depth response.
09-28-2017, 02:13 PM | #781 |
Rep 1,468
Is the GTS/Aggressive burble tied to the map you purchase? So if i wanted to be able to change between the 2, i would need a S2 GTS and a S2 Aggressive map? Or can i switch between GTS and aggressive within one map?
09-28-2017, 02:20 PM | #782 |
Rep 2,640
I'm about to get the custom map soon. I've milked the OTS map for all it's worth and it's not enough. That's my opinion, maybe for you it might be sufficient enough.
09-28-2017, 02:20 PM | #783 |
Rep 2,640
You can request the same map with two different burbles, just ask them for a copy of one but different burble.
09-28-2017, 02:27 PM | #784 |
Rep 801
FWIW, I have a catless downpipe on my car and full AWE exhaust. The burbles in OEM configuration (when in sport mode) are insane and nonstop. Constant crackles and pops every time my foot lets off the accelerator. I could not even imagine what GTS or aggressive are like, nor do I want to know.
Insane435479.50 |
09-28-2017, 03:39 PM | #785 | |
Rep 1,805
And to confirm it's best to leave the cold start valve closed to let the engine warm up faster as it's better for the car? Being in MN I don't want to cause any premature harm to engine when I fire it up at 0 degrees.
09-28-2017, 03:50 PM | #786 | |
Rep 2,640
09-28-2017, 04:14 PM | #787 | |
Rep 801
09-28-2017, 11:53 PM | #789 |
Boost Addict
334
Rep 349
Interesting, I thought cold start was purely for catalytic reasons, and not really to do with with engine warm up, since it only last like 20secs.
09-29-2017, 12:06 AM | #790 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
You’re correct, it seems as if there’s some dealers/customers out there who have been misinformed or misunderstood. If you’re catless, then you should turn off cold start.
FSociety3812.50 |
09-29-2017, 02:07 AM | #791 |
Rep 2,360
Cold start is awesome with de-cat - and so are the OEM burbles Just enough to get noticed and too little to be obnoxious (thats what I tell myself anyway)
(A Dane in China) |
09-29-2017, 06:28 PM | #792 |
Rep 1,805
Hey guys,
I'm having some issues activating my account with the BM3 WIFI module and IOS app. -BM3 App opens up properly, and says "connected: VIN XXXX". All wifi connections between my hotspot and the wifi module seem to be in working order. -However, once I sign in, I get the following message, "Welcome to bootmod3. It appears that vehicle details have not been registered for this account." -I have not received an "activation key". Is this something I punch into the APP? -SSR Performance sent my 4mb ECU file to BM3 yesterday. -I have an active ticket open with the service desk but I believe they might be out for the weekend.. was hoping to have the car going for the weekend. -My last communication with the service desk was them asking if "SSR had sent over the file yet" Did I miss a step? Appreciate any help! Pumped to get the car in action!
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS Last edited by PabloK; 09-29-2017 at 06:35 PM.. |
