05-12-2021, 05:13 PM | #1 |
Rep 31
Whistling when accelerating N20
So a while back I installed a CAI and a NB+ diverter valve on my N20 328i. It ran really good for about 2 months, then I started hearing this whistling noise. At first I thought it was my charge pipe, so I took it out, looked at it and found nothing was amiss. I decided to change it out anyway, since it was the only plastic piece in my intake. No change in sound. Now I'm wondering if it is a vacuum leak or my diverter valve somehow started leaking. Video included of whistling when accelerating past 75%, then the last acceleration was at about 50%. Please let me know what this could be https://youtube.com/shorts/UAxtV6_IXgg?feature=share
05-13-2021, 12:00 PM | #3 |
Rep 73
That does sound like a leak. You say it started randomly after about 2 months?
I have a B46 and they do not have any DV upgrades out for it yet, but does it have any kind of seal that is used with the DV you purchased? I know it sounds counter intuitive, but maybe put the OEM parts back on and see if it disappears? You already ruled out the Charge Pipe, so i would leave that alone, unless of course the virton (spelling?) o ring is maybe folded in some way allowed air to enter at the turbo inlet or around the charge pipe seal? Just thinking out loud here.
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
05-13-2021, 05:50 PM | #4 |
Rep 31
I greased every part of my CAI when I replaced the charge pipe, and since all the pieces are metal I doubt there's somehow a hole in one of them. I'm going to try to smoke test it next, to see where the leak could be
05-13-2021, 05:54 PM | #5 | |
Rep 31
As for the seal, I'm not quite sure what you could be talking about, but the new charge pipe came with a new seal that goes into the turbo. I did grease all around the seal before installation. |
05-13-2021, 10:57 PM | #6 |
Rep 73
Hmm. This is interesting. I would really like to see this in person. Do you have any extended acceleration videos? 0-60 WOT prefferably?
05-14-2021, 10:12 PM | #7 |
Rep 31
So the whistling happens regardless of how fast I'm going, I could be going 3km/h in the parking lot and as soon as I press on the gas past 75% it whistles. But I think I know of what you're asking, so I'll explain a bit before I can get a video later on. It whistles pretty loud initially at the starts, then starts to die off. But when it changes gear, it starts whistling loud again, and dies off.
05-16-2021, 06:38 AM | #8 | |
Rep 31
Here is the video of 0-60 with my foot all the way down. I had the windows up because of the wind noises. It stays whistling as long as my foot is down |
05-16-2021, 08:19 PM | #9 | ||
Rep 29
https://youtube.com/shorts/b_QGfg5WebI?feature=share |
05-17-2021, 07:10 AM | #10 |
Rep 73
This guy had a similar whine, I can hear although it is not as pronounce as yours.
https://f30.bimmerpost.com/forums/sh....php?t=1595918 If this IS the timing chain in your car, I would take it to a local BMW shop and see if it is covered under warranty if it is indeed the timing chain/tensioner.
05-17-2021, 07:04 PM | #11 | |
Rep 31
05-17-2021, 07:05 PM | #12 | |||
Rep 31
05-17-2021, 08:38 PM | #13 | ||||
Rep 29
My options are to buy either a new or refurbished turbo, or sell the car entirely before the turbo is completely toast. I am leaning towards buying a 335 or 340 and selling my car. Pretty disappointed since it is a 2016 n26 with less than 100k kilometres. |
07-16-2021, 10:28 PM | #14 |
Rep 29
I was quoted $2500CAD for a new turbo and $1300 for a refurbished one. What do you guys recommend? I have a very desirable spec, BSM with Dakota red, m sport, all options. I am thinking I will be looking at quite a price jump to get into a 335 or 340 with similar spec to my 328.
07-17-2021, 10:58 PM | #15 | |
Rep 326
Just make sure they replace both oil supply lines. I would also recommend replacing the coolant lines as well. I would go for the new turbo, especially at that amazing price for both part and install, as the refurbished one will have pre-existing wear on various components. With that being said, I've heard of good stories with refurbished ones. Again, with the Mitsubishi turbos, usually it's just the cartridge that is replaced. If you can't afford the new turbo, then I would go for the refurbished.
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
atpenney7.50 |
