07-19-2020, 10:37 PM | #1321 | |
Rep 164
This was the 93 ots map (Stage 2) https://datazap.me/u/devil-doc/m240i...37-38-39-40-44 This was the 91 Ots map (stage 2) https://datazap.me/u/devil-doc/mhd-s...40-41-42-43-47 This was after I reflash the stock map. https://datazap.me/u/devil-doc/stock...-47&zoom=2-105 |
07-19-2020, 11:11 PM | #1322 | |
Rep 585
If you can't or don't want to use better fuel maybe consider a Stage 1 91 tune?
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-20-2020, 12:47 AM | #1323 |
Rep 141
Hey guys was wondering if someone can look at this log I did. (Previous one I posted was a third gear pull this is a fourth gear)
I had a problem with the wastegate rattling last week. Tried to tighten it and ended up throwing a check engine/drive train malfunction/limp mode. I tried my best to adjust it back to where I thought it was before. When I started it in the morning no check engine was on, drove like a grandma for three days, until I decided to do a little pull before the log and it seemed semi decent. (I made a appointment with a local shop to check out the wastegate on Wednesday) Not sure if it’s all in my head but I think something might be slightly off. (Spark plugs gapped to 0.022) https://www.bootmod3.net/log?id=5f15...90c66625c37ee6 Thanks guys *ps. Low end feels fine to me, mid to high seems to fall flat? |
07-20-2020, 03:27 AM | #1325 | |
Rep 151
07-20-2020, 03:45 AM | #1326 |
Rep 585
Stock gap for plugs is fine up to and including straight E85 with stock turbo
07-20-2020, 03:48 AM | #1327 | |
Rep 141
Catless DP. Any advice? What do y’all think is causing it? Would installing the stock plugs be beneficial? Last edited by alpinweiss340; 07-20-2020 at 03:57 AM.. |
07-20-2020, 04:15 AM | #1328 |
Rep 35
Want to run meth, what’s the best way to go about that. Do I buy the bms meth kit and then buy a JB4 and run their wmi map along side bm3/mhd. Or is it better to get a custom tune to intergrate the wmi, what’s safer and advantages and disadvantages for both?? Thanks
07-20-2020, 04:21 AM | #1329 |
Rep 1,010
Are you now maxing out the stock turbo ? or you you think there's still more in it ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
07-20-2020, 04:28 AM | #1330 |
Rep 585
In cooler weather there is probably a bit more, especially if I further increase ethanol, but not in hotter months here.
IMS-340C394.50 |
07-20-2020, 04:35 AM | #1331 |
Rep 192
since timing pulls seem to happen to 90% of us running OTS maps with straight pump gas, and engines don't seem to be blowing up all over the place, should I assume that the OTS maps are safe even with the timing corrections?
07-20-2020, 09:01 AM | #1332 | |
Rep 30
Do any clean logs exist for B58 motor that do not pull timing? Seems like even stock tunes have some amount of pull. Trying to get a feel for how much timing pull is too much, etc... I've heard the E30 maps work well (I don't have E30 near me), but I wonder what the timing looks like. I'll try to find one. |
07-20-2020, 09:42 AM | #1333 |
Rep 151
Engine won't blow because timing WAS corrected and the amount of correction is learned over time. But exhaust valve seals and stems, headers and cats can melt away with time
07-20-2020, 10:40 AM | #1334 | |
Rep 69
Won't be funny to replace them I guess that's an 2.000 euro job. |
07-20-2020, 11:19 AM | #1336 |
Rep 413
Hi OzBMR
Please could you plot the virtual dyno on this log. https://datazap.me/u/m140bcs/log-159...og=0&data=5-23 440i Gran Coupe RWD - ZF8 Thanks.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
07-20-2020, 11:23 AM | #1337 | ||
Rep 151
Kirill @ OdinTuned
07-20-2020, 11:27 AM | #1338 | |
Rep 151
Kirill @ OdinTuned
OzBMR574.50 |
07-20-2020, 12:29 PM | #1339 |
Rep 413
I've checked the 4 logs I did yesterday and they all have rpm glitches??
07-20-2020, 12:43 PM | #1340 | |
Rep 1,010
What fuel are you using ?
07-20-2020, 12:57 PM | #1341 | |
Rep 192
07-20-2020, 01:00 PM | #1342 | |
Rep 192
https://datazap.me/u/m140bcs/log-159...&data=5-23 According to his signature he's only running DP and HPFP on straight 98RON pump gas Logs were taken with 11ºC ambient temperature and IATs are therefore suitably low at around 22-25ºC though. |
