05-18-2020, 12:37 AM | #1 |
Rep 140
Need help with f30 rear wheel specs
Will these specs fit for f30 rear wheels? Are 10" too wide for the f30?
Rear: Size: 19 x 10" Center Bore: PFS ET: 25 Bolt Circle: 5 - 120 |
05-18-2020, 12:44 AM | #2 |
Rep 3,752
Your starting with et25... you are already poking out like 1" probably more. Using spaces will move the wheel some more toward the outside, means it will not just poke out... it will look like a low rider. Time to buy some wide body kit
alohasurftoad3076.50 |
05-18-2020, 12:51 AM | #3 |
M Enthusiast
438
Rep 624
Drives: 2018 F80 M3 ZCP
Depends on how far you're willing to go to make them fit.
It'll work. Stretched tires and camber will do the trick. If not, +25 offset is way too aggressive, especially with a 10" wide wheel
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
05-18-2020, 12:56 AM | #4 |
Rep 140
Hmm I see because the wheels are coming off an e46 m3. The front wheels are the exact same specs for both cars but the rears have different et and width. The wheels are bbs lm btw
05-18-2020, 01:10 AM | #5 |
M Enthusiast
438
Rep 624
Tire size and brand can play a big factor too.
From personal experience of loving to run aggressive fitments, Michelin PSS or PSC2 tends to run pretty wide compared to something like Hankook Ventus V12 Evo's when they're the same width and aspect ratio. If you can give me the tire info, I might be able to help you dial in the fitment. Also, are you on stock suspension or aftermarket?
