BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LCI M Performance (Black Line) Tail Lights
      05-05-2018, 02:14 PM   #309
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
Originally Posted by IK6SPEED View Post
Originally Posted by Kailec View Post
Hey all, just bought a set with the harness. It's coming in the mail currently so I was hoping to get some info before it arrives. I'm in Canada and the lights will be Euro Spec. Is there anything special that needs to be done to get them working?
I've seen this video:
But someone in the comments of the video mention Euro Spec you have to 'tap into the existing outer blinker wires'. How do I go about doing that? Am I also still following the same wiring on the lights themselves like it's mentioned in the description?
You purchased the OEM Harness so you are fine.
But the harness is simply for pre-LCI to LCI? Euro Spec is different, no?
      05-05-2018, 02:18 PM   #310
IK6SPEED
Drives: BMW M3 / AH3
Harness isn’t sold in USA.
It’s a Euro Part only.
      05-05-2018, 02:23 PM   #311
Kailec
Kailec's Avatar
Hmm that makes sense. Hopefully it's that easy then.
      05-18-2018, 06:28 PM   #312
ty666
ty666's Avatar
Drives: BMW 435xi
Originally Posted by Anshu View Post
ikonmotorsports has these on ebay now. it seems like they are replicas though. can anyone confirm? waiting on a response from them.
Bought mine from IkonMotoSports from Ebay.
Reverse lights don't work for some reason, It's probably the harness, they said they'll send me a new one, will update later.
Other than that, I'm happy with them.
      05-24-2018, 09:44 PM   #313
Kailec
Kailec's Avatar
So I just installed my blackline tailights. The turn signal on the inner tailights don't flash. Any reason why? I know it has to be the harness but any idea what about it? I think the harness I was sent wasn't OEM but I don't know that it would make a difference?
      05-24-2018, 11:57 PM   #314
IK6SPEED
Did it have a bmw label around the wiring or in a plastic bag with a BMW Part Number sticker on it?
      05-25-2018, 12:00 AM   #315
Kailec
Kailec's Avatar
It's came in a bag with the printed copy of the BMW retrofit instructions. Don't recall about the logo though. Still, OEM or not, it's just supplying power no? I'll see what happens after I do all the coding I guess.
      05-25-2018, 12:09 AM   #316
IK6SPEED
I didn’t even need to code with the wiring harness.
It should have had a BMW Part Number 61122410220 on the bag.
Also a big wrap around sticker on the wiring.
If not, you received a non-OEM harness that isn’t wired properly.
(Also, are the wire colors as below?)
      05-25-2018, 12:15 AM   #317
Kailec
Kailec's Avatar
Nope, not that. I'm a bit skeptical though that the official harness alone would remove the need to code though. At the end of the day all it is are wires feeding power from the light to the trunk. I will say that there might be a difference in quality though, since when I tried to plug in the right side green cable to the harness in the trunk, I think the cable got mashed a bit and I couldn't plug it all the way in for a click. The blue one was fine though. At this point though I'll see what happens if I code since I couldn't get the green cable out completely once I pushed it in.
      05-25-2018, 12:17 AM   #318
Kailec
Kailec's Avatar
Case in point this post that may answer my question:
http://f30.bimmerpost.com/forums/sho....php?t=1373916
OP says he used OEM harness too. Didn't get fixed until he coded.
      05-25-2018, 12:20 AM   #319
IK6SPEED
I didn't even need to code with the wiring harness.
well, I had coded for the LEDs, but prior to installing I had my istep upgraded at dealer, which wipes out all coding, as you know.
Didn't think about that when installing several weeks later and everything installed fine.
Wasn't until a month later when I suddenly remembered and went, hmmm.....why did that work?
Kailec594.50
      05-25-2018, 12:24 AM   #320
Kailec
Kailec's Avatar
Didn't think about that when installing several weeks later and installed fine.
Wasn't for a month later when I suddenly remembered and went, hmmm.....why did that work?
That makes more sense. Lol
I mean if the official harness came with a circuit board like the new ones from USR, it makes sense that there's no coding required. But not when it's just some copper wire with a connector soldered at the end.
      05-25-2018, 08:06 AM   #321
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
When I installed my OEM taillights using the OEM retrofit harness my lights worked perfectly fine prior to coding. The only thing the coding did was overrode the lighting checks upon start up. You get flickering lights without coding as a result of the check picking up the LED retrofit.
Suggest you look at how you did your repinning when you installed the harness. If it's not the pinning than it's most likely a flawed harness or taillight.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
IK6SPEED4488.00
      05-25-2018, 10:58 AM   #322
IK6SPEED
Thanks.
That confirms the mystery of what I experienced.
7iM3less2595.00
      08-04-2018, 06:34 AM   #323
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
These might be my next mod... before a splitter/defuser/spoiler....
Lets see some installs on Glacier Silver... Post 'em up!!!! Thx
      08-12-2018, 06:26 AM   #324
disintegrator66
No GSM cars with these lights? C'mon boys.. post 'em up!
      08-12-2018, 06:52 AM   #325
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
I dont understand. I bought my LCI/harness combo from schmeidmann and didnt have to code shit. No flickering. I've had the lights on for about 6 months. Could it be that my ECU was updated to latest version about a year ago? Dealership was diagnosing a problem and updated it.
Hi
      09-03-2018, 12:22 AM   #326
sean2648
sean2648's Avatar
Drives: 2015 335i
Anyone have a cheaper or better place to get these from besides schmiedmanns?
And if not why is the “kit” so much more than buying the harness and lights separately? And what are those extra 2 pieces in the kit pictured?
Looking like just around 600$ including shipping, this the going rate ish?
      09-03-2018, 12:36 AM   #327
sean2648
sean2648's Avatar
Drives: 2015 335i
Looks like uk eBay has them for about 520 for the lights, then adding the harness for roughly 40, save a couple bucks.
      09-03-2018, 09:28 AM   #328
Kailec
Kailec's Avatar
Hey Sean, just to be clear, those 2 grey pieces that they sell are drip trails for your lights. The LCI lights are a different shape and those trails help divert water as a result of a different shape.
Here are the part numbers:
51497453333
51497453334
I bought them for about $70 CAD so if you're buying them separate on ebay, you should factor in the price of these things into the overall cost, and see if it actually saves you anything. Also, if you're not in a rush, might I suggest you wait til another eBay 15-20% off day?
      09-03-2018, 10:15 AM   #329
sean2648
sean2648's Avatar
Drives: 2015 335i
Awesome, good to know on those 2 pieces, so if I'm buying off Ebay just get the lights, the OEM harness and the 2 drop trails total. And ya right now they are doing a 20% off which is why I wanted to pull the trigger
But there isn't a cheaper place people who have these got them from I'm assuming?
      09-03-2018, 12:59 PM   #330
Kailec
Kailec's Avatar
Not that I know of. I bought my lights and harness of eBay but the drip trails at my dealership.
