05-11-2018, 03:45 AM | #45 |
Rep 3,055
As above ^^^^ when I cancelled my order, they actually rang me again to say that perhaps they didn't need quite so much information and they could send the discs, I told them to get stuffed and give me a refund, which they did after about a week.
I bought my discs in the UK after that from https://www.ebay.co.uk/itm/Genuine-O...034e%7Ciid%3A1 |
06-04-2018, 10:44 AM | #48 |
Rep 3,055
All depends what pads you want ?
I did the standard Pagid pads @ circa £46 but I see that eurocarparts have a spring 33% off so are at around £40 |
on_the_virge285.50 |
06-04-2018, 11:02 AM | #49 |
Rep 1,151
Drives: F90 M5 Comp (Evolve Tune)
I have the bmw M performance fronts been so good no noise and been on track day using bmw pads no fade really impressed.
on_the_virge285.50 hudson012003168.50 |
06-04-2018, 03:25 PM | #50 |
Rep 1,060
I've also just fitted M-Performance grooved and dimpled discs front and rear with BMW standard pads. No noise as some have suggested and no brake squeal at the moment, used Ceratec brake grease on assembly. Discs look really good.
G15, 840i M Sport
06-04-2018, 04:50 PM | #51 |
Rep 5,607
Do you have the part No for these?
06-04-2018, 05:36 PM | #52 |
Rep 637
Be careful when using Autodoc. Great price if things go well. Expect hassle if you wish to return for a refund. Reminds me of mobile phone companies when you ring to cancel the contract. You have to go through 20 minutes of discussion before finally they agree to cancel the contract. Beware!!!
06-04-2018, 06:36 PM | #53 |
Rep 1,151
im gonna get rears from bmw can i ask what you paid for rears? i had quote for 22 plus vat
07-05-2018, 04:36 AM | #54 |
Rep 476
I've got the M Performance brakes on my car (335i), but not sure if i have the 340 or 370, Euro's only offer me the 340 and realoem has both listed... little confuse without measuring...
F25 X3 35d - F30 335i - |
07-05-2018, 05:52 AM | #55 |
Rep 1,907
I have the standard brakes on mine just fitted OEM front pads & have noticed a lip on the discs, what discs do you guys recommend for standard brakes.
Happy Motoring
Evdok |
07-05-2018, 07:30 AM | #56 |
Rep 32,881
A bit of a lip is fine. Best to measure the thickness of the disc with a vernier caliper and a couple of coins/washers.
08-16-2018, 03:41 PM | #57 |
Rep 73
Looking for discs here for my own car. Anyone know why this eBay price is much cheaper than other online shops? £256 vs £390
https://m.ebay.co.uk/itm/Genuine-OE-...d=352166091485 https://m.onlinecarparts.co.uk/textar-8036707.html |
08-16-2018, 05:41 PM | #58 | |
Rep 32,881
https://m.onlinecarparts.co.uk/trw-11015794.html |
08-17-2018, 06:00 AM | #59 | |
Rep 3,055
Bought direct from Ace in the UK as per the ebay add fast delivery, good product. in my eyes no different from the super expensive BMW ones. Although the picture doesn't show it they are coated for protection. |
08-17-2018, 06:24 AM | #60 |
Rep 204
Does anyone know what the minimum thickness of the discs is for 370mm discs? On NewTIS it states 28.4mm - 2.4mm but this is for 340mm discs and doesn't specify for 370.
I'm guessing there the same thickness? |
08-17-2018, 07:14 AM | #62 |
Rep 204
That makes sense cheers, the table on NewTIS isn't the clearest as it says deduct 2.4 from the values in the table below. But anyway thanks for that
08-18-2018, 12:20 PM | #63 | |
Rep 73
08-18-2018, 12:22 PM | #64 |
Rep 73
That's a how to on the textar pads on an F31 by Ed China |
hudson012003168.50 TiredGeek360.50 |
08-20-2018, 03:11 PM | #65 |
Old Fart
361
Rep 693
That looks simple, even I can tackle replacing the discs and pads
BMW won't be getting my money for that job then
The doctors said it's OK to listen to the voices..... just don't do what they tell me
08-20-2018, 03:18 PM | #66 |
Rep 32,881
Yep it’s pretty easy, as long as you have something thin enough to drive the pins out. And remember to tighten the reservoir cap and torque the wheel bolts!
