02-20-2019, 07:23 AM | #155 | |
Rep 2,302
So „detect caf for swe“ and code the NBT Evo. |
02-20-2019, 01:44 PM | #158 | |
Rep 3
I didn't flash before and I hope to be able. Before flashing HU_NBT2 do I have to flash the ZGW at the same I-Step level I will use for NBT-Evo? I will use a bench for coding/flashing with an ZFW2 from an F10 |
03-07-2019, 08:02 PM | #159 |
Rep 3
05-09-2019, 02:04 PM | #160 |
Rep 3
05-12-2019, 10:56 AM | #161 |
Rep 14
Hello all,
I had retrofit the reverse camera, hardware wasn't an issue, camera was working after VO coding 3AG and coded the rest of the ECU's. only the ECU of the TRSVC couldn't find the correct CAFD, in fact he didn't had any CAFD file. I tried this option: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired TRSVC => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. But there was the KIS error CAFs for "swf1_00000468-013_002_001 not found, so I looked for the latest PSDZdatabase V4.17.11 Full version and still no CAFD file available. Can I reset the ECU of the TRSVC or inject another CAFD so I don't have this camera error message on the dash? Last edited by Freebeeman; 05-12-2019 at 11:21 AM.. |
05-14-2019, 07:34 PM | #162 |
Rep 1
Hey Shawn new F30 owner, I'm attempting to do some basic Esys coding and am getting the same error as above, would you mind helpng me out with the current PSdZData files?
Thanks so much in advance. |
05-14-2019, 11:19 PM | #163 | |
Rep 40,793
05-14-2019, 11:20 PM | #164 |
Rep 40,793
PM sent.
05-15-2019, 02:39 PM | #165 |
Rep 14
Hello Shawnsheridan,
I tried now for two days to flash, every time there is an error like "VCM isn't updated", then I went 3.32 to E-SYS 3.27 next error "SVK-Ist does not match". So I think I used a wrong I-step. I'm worried that when I push to far I brick my car. But thank you for your help. |
05-15-2019, 02:44 PM | #166 | |
Rep 40,793
This "SVK-Ist does not match expected SGBMIDs for ecu..." means you have chosen an improper I-Step Shipment when you made your SVT Target (SVT_soll). The problem is that this ECU is not factory original, so ECU I-Step Shipment is different then your car's actual I-Step Shipment, and you have no way of knowing what the right I-Step Shipment is for this ECU. So, redo flash, but this time after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it. If HWEL is Black only, no Red / Blue HWEL, then you can proceed to flash it. If HWEL is not Black only, the only thing you can do is try different I-Step Shipment dates until hopefully one works. This is simply Trial and Error.
05-18-2019, 07:18 AM | #167 | |
Rep 14
Thank you for the new information. I tried with almost 10 versions of I-Step (ship), ticket "HW-IDs from SVTactual" and everytime I calculated the I-Sep version without succes. It's taking almost 5 minutes per calculation and there are at least 30-40 I-step versions, so yes it's trial and error. I tried without calculating anly ticked "HW-IDs from SVTactual" but I think this not checking if it's the correct version. I'm going to return the unit and try to find another one that will work. Thank you very much for your support and effort you put into this, keep up the good work. |
05-18-2019, 07:32 AM | #168 | |
Rep 40,793
07-09-2019, 10:46 AM | #169 |
Rep 4
bmw f21 coding
i need
BKOMBI [60] [J808281] readCPS o.k. CAFD_00000760_007_003_032 Fehler: File for "cafd_00000760-007_003_032" not found! [C012] and i need cafd_000000f9_007_009_009 please) |
07-09-2019, 11:37 AM | #170 |
Rep 40,793
PM sent.
07-09-2019, 11:52 AM | #171 |
Rep 295
Drives: 2016 340i X Drive
The dealer recoded my 2016 340X to stop the A/C unit from freezing up in hot, humid weather. The good news is that for the first time since the car was new, the adaptive headlights are now working as designed.
On the other hand, they wiped out the coding done by Ryan Lee, whom I can't seem to find. If you're here Ryan, please PM me. I tried connecting the esys cable and ran the software, but I'm getting errors. Shawn, would you please be available to guide me by phone as I do it? |
07-09-2019, 12:38 PM | #172 | |
Rep 40,793
07-10-2019, 11:42 AM | #175 |
Rep 40,793
I replied to your same PM.
07-12-2019, 12:56 PM | #176 |
Rep 4
good afternoon again. when encoding blocks, when clicked "read coding data". next, click "edit fdl" and then go to the encoding blocks choose "3000" then click "Funktion" and then all the folders are named "."I need to call for example "bc_digital_v". What to do?
