02-04-2024, 08:43 AM | #265 |
Rep 551
Hello,
In the Factory Settings menu (the code is curiously 0000) I cannot find any parameter allowing you to change / choose the correct BMW OEM screen resolution in 10.25". This chapter / choice is not present in the parameters I tried to code the unit (Display_Size and Dispaly_Variente) but with no result, still the OEM screen at two thirds In addition in the du'sine settings with this code 0000 = No choice of starting the LINUX unit (you know BMW or Android-Carplay) Really curious... do you have any idea how to access another "factory menu" please? EDIT : Well you had to use the code 8866, and there another menu appears!! Code 0000 gives access to a restricted factory menu. Another problem now, and an important one, is that the screen sometimes goes black then comes back while driving, and especially when starting up every other time: Black screen, nothing works anymore, you have to restart the car's ignition for it (the screen) to start correctly... help please? Last edited by F20_M135i; 02-04-2024 at 11:47 AM.. |
02-05-2024, 03:29 AM | #266 | |
Rep 551
02-08-2024, 04:11 AM | #267 | |
Rep 25
What manufacturer, model of unit and software version do you have? |
F20_M135i100.50 |
02-08-2024, 10:31 AM | #268 |
Rep 551
I'm going to try with my old iPhone that I'm picking up this weekend from a friend.
Unfortunately the Aliexpress seller (known as "BONROAD") does not respond to any of the messages or emails (now that he has received a good rating from me)... Thanks for the advice, I hope to resolve this big bug |
02-14-2024, 11:59 AM | #269 |
Rep 1
Hi all. I recently installed a Linux screen into my wife’s 2015 F33. It didn’t come with any instructions but I watched plenty of videos and read this thread and got it done. It works well, CarPlay connects almost immediately and my wife is happy.
Unfortunately, every once in awhile, after she drives in reverse, the speakers become very crackly and loud (static) and she cannot turn them down with her phone or the knob on the dash. She turns off the car, restarts, and all is well. Any ideas where I should try and troubleshoot? I carefully and thoroughly moved the optical cable to the new harness and also made sure to secure each end of the harness that comes with these head units. |
02-14-2024, 05:30 PM | #271 | |
Rep 7
Had it for 6 weeks, used with an iPhone 13, everything works flawlessly, not had a single problem with it. |
kentodessa6.00 |
02-20-2024, 09:21 AM | #272 | |
Rep 25
03-01-2024, 10:14 AM | #273 |
Rep 7
Hello all,
i have non android HU ew960qlcpnb and have 2 issues, firt and importat is extremely loudness which i cannot turn off so bass are at extreme level ane its distorted via carplay, and second is brightness of dispolay during night / lights on/ . anyone can help me please ? |
03-01-2024, 12:08 PM | #274 | |
Rep 7
Everything works great, Spotify, calls with the BMW factory mic, answering calls with the steering wheel button, activating Siri etc The only time the phone connects to bluetooth on the screen is to start carplay (after which the bluetooth connection is dropped and the rest of the carplay communication is over wifi) I can't help with the screen brightness though, on my unit its just there in the settings, various sliders for day and night, and it toggles automatically. |
kokot30000.00 |
03-01-2024, 07:12 PM | #275 | |
Rep 7
03-01-2024, 07:14 PM | #276 | |
Rep 7
03-01-2024, 07:27 PM | #277 |
Rep 7
I tested right now music from spotify via car bluetooth vs via carplay, and its huuuge difference, via car BT its clear, good bass and treble... in this car its basic sound but its ok, when i change to carplay, i tried to configure HU equaliser.. but it does not really matter where are these sliders... it sound like it was blanket throed via speakers and bass are loud .. i think its shitty DAC maybe .... im thinking aboout that to change from this HU (it has tuning solutions startup logo to andream) but im afraid it has same shitty sound quality....
03-11-2024, 07:13 AM | #281 |
Rep 25
I have this model EW960QLCPNB and the latest software update released in the last few months did give an excessive bass boost to the sound. It is possible to turn down the bass in the EQ and also the BMW sound bass control and return it back to an acceptable level.
The previous car I had was fitted with an MMI box instead and that also had excessive bass until you disable the loudness setting and it returns back to a reasonable level. hyri - what model are you looking at buying? |
03-12-2024, 09:21 AM | #282 |
Rep 5
Just wondering if I’ll have to reroute or directly connect an AUX cable into my centre arm rest? 2014 F30 CHAMP2 with Business Nav, OEM Aux, Bluetooth Calling but no Bluetooth Audio. No combox in rear. Will I have to do any coding either?
I saw the previous posts with CHAMP2 but both have Combox in rear. I’m hoping it’ll be a bit easier for me haha |
03-16-2024, 12:43 PM | #283 |
Rep 10
Hi guys
I've had this unit for 18 months and the reversing camera suddenly stopped working. I managed to trace the fault back to the unit itself - it had stopped supplying power on the pink "campow" wire. Not sure why as it has been working fine since the install. I decided to find an alternative power source and found a suitable one in the boot fuse box. This raised 5A fuse (can't recall the number right now) supplies 12V when the igntion is on. The whole bank of fuses on that left side work this way. No need to run negative as that is internally grounded in the headunit. I initially tried to tap into the reversing light as a lot of posts here describe, but this does not work as the reversing bulb drops to 9V once the engine is running. I used an "add a fuse" tap on the fuse above, ran the wire and she's back. All testing was performed with a multi-meter; this is not guesswork on my part. I hope this helps anyone that finds themselves in a similar situation to me. |
FastFrog143.50 |
03-31-2024, 02:42 PM | #284 | |
Rep 7
03-31-2024, 02:43 PM | #285 | |
Rep 7
andream mmi carplay |
