09-16-2021, 08:33 PM | #46 |
Rep 62
I left the CTEK 24hrs connected for the first time. Right after I removed the charger, the resting battery showed 13.3V
One hour later it dropped to 12.7V. Does this mean the battery is somewhat still in pretty decent shape? |
09-16-2021, 09:15 PM | #47 |
Rep 16,140
That's about right. If it's still above 12v come morning you're probably OK, especially as you don't have cold winter temperatures to deal with.
09-16-2021, 09:23 PM | #48 | |
Rep 628
The question you really need to ask yourself is can your battery be maintained and not leave you stranded under normal operating conditions? |
09-16-2021, 09:34 PM | #49 |
Rep 1,199
The real question is how much time you're going to waste troubleshooting a battery instead of just replacing it and forgetting about it.
09-17-2021, 12:36 PM | #50 |
Rep 628
09-17-2021, 02:33 PM | #51 |
Rep 16,140
And if you had a dollar for every time it was recommended that the poster buy a battery and it turned out to be something else you could afford a new battery, at dealer prices. For example: https://f30.bimmerpost.com/forums/sh....php?t=1360823
Being a New Englander I always follow the rule that you can't fix it if it ain't broken. |
dmaxdmax417.00 |
09-17-2021, 03:17 PM | #52 | |
Rep 628
09-17-2021, 04:55 PM | #53 |
Rep 919
It probably 'is' due for a replacement, but, OP, if it was me, I'd do what others have said. Charge it, monitor it, see what you get. You might not want to leave it unstarted for weeks...and after being that low, it really did need a long drive to restore what you've lost--you've also undoubtedly lost some capability from it you'll never get back.
If you have a garage and can charge easily...just do that and then maintain it from under the hood. Keep it up for a year. Maybe try charging every few days...it's probably good enough for most uses--maybe not unlimited short trips--the starting is what drains it. Good luck.
Billfitz8277.00 |
09-17-2021, 05:03 PM | #54 | |
Rep 16,140
09-18-2021, 06:04 AM | #55 | |
Rep 628
12.7 V read off a multimeter after waiting an hour doesn’t show anything other than it is holding voltage in a no load condition. Doesn’t really show anything about capacity and the ability to push out amperage. It fact after an hour it is still probably a surface charge. |
09-18-2021, 09:05 AM | #56 | |
Rep 1,199
Point still stands that his battery is 6 years old. He had a pretty rough start and it got measurably low, which isn't good for it. Probably best to replace it anyway. Then you KNOW it's not the battery that's the issue. This is valuable in troubleshooting. You don't have to be absolutely sure about a potential fix to try it. It just needs to be probable. Then when you compound it with something like the fact it may need replacement relatively soon anyway, it's kind of a no brainer. The linked shifter thread IMO was poor troubleshooting. No other symptoms in the car except shifter malfunction? Probably not a battery issue. Should he have a CTEK around anyway? Yes absolutely. So OP really doesn't lose in any path forward here.
09-21-2021, 02:26 PM | #57 |
Rep 62
To end the discussion. I had it replaced today at BMW service. The cars starts as soon as I hit the ignition button with zero lag.
This is why I decided to pull the trigger. -After a full charge, resting voltage was 12.2V the next night. I thought it is not holding a good charge. -I am leaving town for a while and don’t want my wife to deal with it if it causes any issues. Last edited by micharlie; 09-27-2021 at 08:14 AM.. |
10-14-2021, 03:54 AM | #59 | |
Rep 474
Then download then pay for Bimmer link. You can register the battery yourself with it and any other bmw in the future. Just have to buy the battery somewhere.
J. D. Cordier
12-06-2021, 10:51 AM | #60 |
Rep 4
Hi - I'm looking to replace the OEM car battery on my 2015 335D
The Original BM battery is 90Ah and 900CCA - the closest equivalent I can find is the Bosch AGM 019 Car Battery - S5 A13, or the EXIDE EK950 019AGM, both of which are 95AH but only 850CCA. Will the 850CCA be sufficient for a 335D - anyone replaced their OEM with a different car battery ? Comments/advice appreciated as both of these are approx £100 cheaper than OEM BMW batter at £233 and that's before fitting - which I'm looking to do myself. |
