08-27-2018, 04:39 PM | #1 |
Rep 740
Tire rubbing sound from rear when turning. Rear Diff?
So the issue I'm having is when taking a turn, the rear sounds like the tire is rubbing but its not. I have stock suspension and stock 18" wheels.
Quick google shows similar problems on the e46's and e9x's. Its stating the noise is likely coming from the clutches in the limited slip differential. Solution for those were change the oil with special differential oil. https://www.m3post.com/forums/showpo...80&postcount=9 Anyone else have this issue? MY 4/13 328i xdrive
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) Last edited by jkwhar; 08-27-2018 at 04:50 PM.. |
08-27-2018, 04:57 PM | #2 |
Rep 16,079
It probably couldn't hurt to try the oil, but note that the campaign was for new cars, and that the noise usually went away as the cars were broken in.
08-27-2018, 07:01 PM | #3 | |
Rep 63
08-28-2018, 05:14 PM | #4 |
Rep 740
I think you're right about not having LSD. But the noise is deff from the rear so I don't think its the TC.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
08-28-2018, 09:21 PM | #6 |
Rep 740
I think my tires are actually rubbing on my inner fender liner. Took the wheel off and checked it.
I'm going to mount my gopro inside somewhere and see if I can visually see it lol. Either that or just paint the inner well white and see if it rubs. Only does it during left turns and giving it gas coming out of the turn.
08-29-2018, 10:22 AM | #7 | |
Rep 63
08-29-2018, 01:06 PM | #8 |
Rep 740
This is what I found yesterday...
08-29-2018, 03:00 PM | #9 |
Rep 3,679
Woah, definitely some rubbing go on, with what appear to be stock wheels... Well at least you found your problem.
08-29-2018, 04:14 PM | #10 |
Rep 63
08-30-2018, 12:38 PM | #12 | |
Rep 740
My guess is either trailing arm, guiding suspension link or track strut bushings. (11, 13 or 18) https://www.realoem.com/bmw/enUS/sho...diagId=33_1602
09-02-2018, 06:00 PM | #13 |
Rep 740
I took the gopro and mounted on the rear fender to see if I can see any lateral movement but nothing.
Took the gopro and mounted somewhere inside the well and took it for a drive but bc of the low light, I couldn't really tell much. Took measurements between between the two rear wheels and the side with the issue (passenger), it measures about 1/4" lower then the driver side. checked the gaps between the wheel and left most point, right most point of the wheel well, and they're about the same (poor mans alignment lol.) Now I'm wondering if I have issues with the spring. Since this only happens when taking left turns and never straight even with passengers in the rear, heres my new theory: when going straight, the sway bar keeps the car leveled to a certain degree but when taking the left turn, the force that shifts the corner weight (rear passenger), the sway bar is going to push down on the passenger side while pulling up on the driver side to try and level the car. which in turn is allowing the extra travel in the suspension.
09-02-2018, 09:16 PM | #15 |
Rep 740
Damn it, lol.
09-03-2018, 10:10 AM | #16 |
Rep 63
Yes.. Mine is also a little higher on the driver's side.. Either way I would bring the car to an alignment specialist because the wear on that tire is not normal.. They should be able to check all of your suspension components and hopefully find the problem..
09-04-2018, 08:36 AM | #17 |
Rep 740
I was going to take it to the dealer but I have the lifetime alignment with firestone so I'll just bring it there to have them re-align the car and go from there.
09-04-2018, 10:39 AM | #18 |
Rep 63
09-05-2018, 09:25 PM | #19 |
Rep 740
Camber was off a bit (I will post the print out later). It helped but it still rubbing a little.
09-05-2018, 09:52 PM | #20 |
Rep 495
They 100 percent are. The battery is on the passenger side and so is the gas tank. I'm actually having rubbing issues on my fender liner since I'm slammed. The passenger side is a tad lower than the driver so it's rubbing on the passenger side. Fixing it this weekend
09-06-2018, 12:47 AM | #21 | |
Rep 1,074
Instagram: M2_Medusa
