01-29-2024, 11:45 AM | #23 | |
Rep 8,500
I’ve used magnetic sump plugs on other privately owned cars and they’ve also had light build-up. It doesn’t concern me, and I appreciate that the oil filter is there to do its job (including capturing the non-ferrous fines which the magnetic plug obviously won’t), but taking some/all of it out of the oil can only be a good thing.
01-29-2024, 02:41 PM | #24 | |
Rep 385
Let's be clear with arguments: Although most combustion engines, after leaving a factory, will produce lots of dust during the first thousand miles, it is still a good practice to flush out oil every once in a while in older engines as will always produce some. Aluminum dust is less dense than non-ferrous metal, thus less dangerous, but is still heavier than oil and will settle at the bottom due to gravity. For some reasons this discussion reminded me of a 'good housekeeping institute' where bunch of people decide what's bad and what's good. I personally prefer flush for a piece of mind.
1995 E34 525td auto • 2016 F30 320ed auto
01-30-2024, 02:22 AM | #25 |
Rep 8,500
Same here. I use oil flush (and gravity drain the oil via the sump plug), every oil change, as well.
Get as much sludge, varnish, carbon (piston rings), dust, etc, out of the system as possible.
02-01-2024, 03:38 AM | #27 | |
1897
Rep 2,089
Keeping the oil fresh with a decent filter, for me, is a better option... Engine flushes for a 'new to you' car maybe; so you start afresh if that makes sense?
Burnout27.00 |
02-01-2024, 08:28 AM | #28 |
Rep 811
Yeah every time I've bought a car, its always had a few 'long life' services before my ownership, so typically do a flush beforehand. Flushes are typically 90%+ paraffin/kerosine so i just use some diesel! Theres a few YouTube videos proving its got plenty of lubricity to work short term.
1. Drain Oil 2. Refill with some 5w30 LL04 mixed with 1L of Diesel 3. Run car for 15-20 mins at idle until warm (leave heater off) 4. Drain & replace Oil Filter - clean filter housing well 5. Refill with fresh oil |
02-01-2024, 10:14 AM | #29 | |
Rep 1,013
I had already looked at pictures of the inside of the N57 sump before getting the oil sucker as some sump designs don't work well with that method (mainly transverse FWD), but in the N57's case, both drain methods are effective. See for yourself. https://www.ebay.co.uk/itm/275387183875 Look where the dipstick hole points the suction tube.....right into that pocket next to the drain plug, which is actually deeper than the drain plug because of it's threaded ledge. You can also clearly see neither method gets all the crud out of the webbing and corners. |
02-01-2024, 12:59 PM | #30 | |
Rep 385
How quick is your pump? (rhetorical) I could argue flow speed matters for flushing particles out. I am not too sure if some heavier particles will get picked up by a pump due to gravity.
02-03-2024, 04:07 AM | #31 | |
Rep 1,013
Agreed. The fast flow out of the drain hole drags crumbs out with it. I do also use the sump bolt method, but I save that for when I jack the car up, such as swapping the winter wheels to summers etc. I just do the sucking method as a quick interim clear outs as it's more the soot saturation that bothers me more than anything else. The only issue with jacking up just the front is oil moves into a corner that won't drain out because of the angle, so ideally a ramp is best for that method. |
02-03-2024, 03:14 PM | #32 | |
Rep 385
While drinking a tea I picked up some pics from google for educational purpose of 5 bmw F30 sumps; see how drain plug is conveniently located near the edge of a sump on 4 sumps not counting B58 and N57 as in your case. So if car is to tilt backwards it should only help for draining out oil. By looking closer at a threaded drain hole can be seen it is not enclosed and has a cut out that brings it to a level of a bottom. Your point about soot is spot on as its really harmful to an engine due to its abrasive properties and clogging.
02-03-2024, 03:25 PM | #33 | |
Rep 385
Someone said 3rd party additives are similar to non prescribed drugs
danb19791897.00 |
02-04-2024, 04:55 PM | #34 |
Rep 43
Drives: previously an E39 528i, now an
Regarding normal amounts of iron in oil, it’s worth nothing that Blackstone universal data for all the N55 samples they have received has an average of 24 Parts per Million (PPM) of Iron.
I’ve seen 4-9 PPM depending on interval (with the exception of my first oil change after purchase which was 19 PPM), and those have been with a magnetic drain plug that typically has a small amount of metallic sludge stuck to it |
02-05-2024, 03:02 AM | #35 | |
Rep 385
Phosphorus, Calcium, Molybdenum, Boron, Silicon - these elements only present in a synthetic oil and are higher than a reference value, which leaves me wonder which oil has been used. Your observation with iron and magnetic plug only confirms that its working good; there must be a reason why most car manufacturers tend to avoid use of a magnetic plug.
02-05-2024, 04:25 AM | #36 |
Rep 43
Without hijacking this into yet another oil analysis thread, yep I was told the previous oil change before I bought it was done with Liquimoly, I’ve used the SpecialTec 5W-30 religiously and get consistent values for those first 4 elements (along with Zinc as well).
Silicone - Blackstone have been kind enough to flag my values are greater than typical even for this oil so I’ve been looking for air intake leaks. As for the potential of there being OEM mag plugs, contrast that potential investment with how many parts are made of plastic that really should be metal that were already aware of. Also a mag plug is an investment in longevity, ie keeping that extra material (however fine) out of the oil flow to hopefully keep bearing races less scored over time. It’s not essential to enable the car get through the warranty phase, so why would a manufacturer invest in it? |
02-05-2024, 04:33 AM | #37 | |
Rep 1,013
Wazman999403.00 |
