01-26-2024, 04:07 AM | #1 |
Rep 17
2nd transfer box failure
2014 F30 M sport w xdrive. Petrol 2 litre
Transfer box failed in April 2021 - BMW dealer applied for goodwill on the new one and it got 100%, only had to pay for investigation fee and something else that was small. The actual bill though was around £4,800. Fast forward to today, put in for MOT at official dealer and it passed but they asked about a knocking noise (which has only just started). I agreed it was there on occasion and they say they think its the transfer box again. Im gutted - the warranty on new parts is 2 years I think and its just outside that. They say they will apply for goodwill again but im not so sure on my chances. I love my car and hand picked it, if its not done under goodwill though I might have to let her go as its a very expensive repair. RIP. I'm also slightly concerned its eaten two transfer boxs very quickly. I only did 12k miles in 2yrs 9 months on the new one. Did not expect it to fail. My question to the forum is is that just bad luck or should I consider selling the car even if its repaired under goodwill? |
01-26-2024, 04:18 AM | #3 |
Rep 17
No but the one that's in my model (and others around the same time) appear to be quite likely to fail early. Hence the goodwill repair on mine originally, it appears everyone gets it. I read some of the technical details why before on other parts of this forum, but a bit over my head.
01-26-2024, 05:47 AM | #5 |
Rep 17
It's only got tyres from the BMW dealer on it, and when they tell me they want to put new ones on it then it gets done. It's in for its service like clockwork at the official dealer. It doesn't do many miles.
I realise I'm spending a bit too much doing that, but I also realise the answer to your question is very likely "yes". I'm not very technically competent as you can easily tell. |
Lorcan3609.00 |
01-26-2024, 09:04 PM | #6 |
Rep 17
Update :
Dealer called back, said it was definitely the transfer box. Then said they are going to try a fluid change on it first before asking BMW UK for goodwill and changing it completely again. I would have to pay for the fluid change, around 2-300 quid. I agreed but did ask why are they doing this step now - when the first one failed 2 years 9 months ago it was just changed out. The answer was this is a new step in the process to try first that BMW introduced in the last couple years. Apparently they do have some joy simply changing the fluid on them and also apparently BMW UK were spending a fortune doing everyones transfer box under goodwill, so they try this first now. I agreed and it comes at a cost of around £400 total to me, I get the car back on Monday. The guy said if it starts knocking/juddering again within 200 miles to bring it back in and they will apply for goodwill for a new case. I asked how long have I got exactly for that and he said "not years but if it starts up again bring it in". I did ask for an explanation why it ate a second case within 12k miles and under 3 years, but didnt really get one. Fingers crossed the fluid change does the job. I did read some of the technical threads on here about it and seems it has a good chance. |
01-27-2024, 02:39 AM | #7 | |
Rep 175
01-27-2024, 03:49 AM | #8 |
Rep 17
Yes I am sure at what they are suggesting. My BMW official dealer might be expensive, and inclined to try and get you to purchase things but they are not cowboys doing stuff like that - and do remember every phonecall you have with them is recorded. They are changing the transfer case fluid. They spend a fortune replacing these cases on goodwill so I understand why they they now try this first. A lot of the mechanically minded on the xdrive forum do it themselves.
01-27-2024, 04:08 AM | #9 | |
Rep 175
01-27-2024, 04:15 AM | #10 |
Rep 1,099
If a bearing / bush / chain / clutch pack etc is causing a knocking noise then something is worn broken or internally damaged so changing the fluid will not fix the issue unless they fill it with slightly heavier oil to potentially mask the problem , for a while.
Porsche had a terrible problem with transfer cases on their earlier Macans / Cayennes due to water ingress so much so the fluid was replaced annually to prevent them consuming themselves internally. If the dealership is a good as you say then the removed TC oil should be sent for analysis to check for metal fragments which would indicate how much internal wear has taken place. K |
Leeg1633138.00 |
01-27-2024, 05:17 AM | #11 | |
Rep 8,501
I wouldn’t rely on conversations and allegedly recorded phone calls - I’d put the entire history in writing to the dealer, including dissatisfaction / concerns / etc. I think it’s best to not be passive in these situations.
Leeg1633138.00 |
