03-14-2016, 10:42 PM | #1 |
Rep 578
///M Red Performance Brakes installed on Glacier silver
For as long as i could remember, i have wanted a Big Brake kit. I love nothing more than seeing a nice big caliper behind a nice wheel. It's just one of my favorite looks. And this might crazy, but many years ago when i was looking to changes cars, i thought it was pretty cool that BMW sold an OEM big brake kit.. And after I drove my 1st E46 BMW, it was a done deal. Fast forward many years later, I have finally installed a Big Brake Kit on one of my cars... It's not the 6piston/4piston setup I would have loved... but i'm really happy with the way this came out. And also, about 1/3 of the cost of a Stop Tech kit. You can find good deals if you look hard enough...
i really wished i had taken more photos during the install so i could share with you what i learned doing this install. I searched & searched & searched for a DIY & there really isn't one. I was really hoping to document this & create a DIY but the problem is, brakes are really freaking messy so i would have had to constantly be changing my gloves to grab my phone to take photos. And not only that, with a 1 year old & work travel schedule like mine.. getting 2 days to work on your car is next to impossible if i'm trying to keep the wifey from divorcing me (let me tell you, she was thrilled to have to move the brakes off the front porch b/c i was traveling when the second set arrived (i bought phoenix yellow 1st & them sold them... after i ordered the Red... . I find the best to ask for forgiveness method when i find a deal too good to pass up on. i can answer any question you guys may have about install the brakes as I learned a lot researching this project & during the install itself. Install Rheingold, that really helped too. Here is the front passenger caliper after I moved over the brake line: Here is the front caliper installed with the front rotor. I had a really bad scrapping sound on my 1st test drive... oddly enough even though i swapped dust shields on the front... the new one got bent somehow & was rubbing the rotor on the back side. So after i bent that sucker away from the rotor, all was good. That rear was a complete biatch to get off.. have no idea how mine could have been that stuck which my car has never seen the snow & i don't drive it when they salt the roads. Plenty of anti-seize will ensure that doesn't happen again. Now i had read some post about cutting the rear dust shield to accommodate the larger rotor.. I didn't have to touch the rear dust shield & the new one looked like the exact same (the front was definitely the same). I'm not sure if it's b/c i had a 335 or what but i was able to skip that whole part of the install which i wasn't sure how the heck i was going to get those off anyway. The electronic brake is built into the hub. Unfortunately I didn't get any additional photos during the install, but here is a teaser of the post... I hope to get some good photos this week. They look absolutely amazing, and other than the OEM 437M wheels, by far my favorite mod. : It's hard to say at this point how the brakes are performing b/c i haven't properly bed them or coded them, compare to stock i don't think there is as much initial bite.. i'm trying not to step on them until i properly bed them & code the car. It's too early to judge, i just finished the rears today. |
03-14-2016, 11:08 PM | #2 | |
Rep 2,639
I'm assuming when you do the brakes, you should apply a ton of anti-seize on the hubs? Anywhere else in particular you should put some more? And what brand/type (copper/silver) anti-seize? |
03-15-2016, 06:53 PM | #4 |
Rep 864
03-16-2016, 09:33 PM | #6 | |||
Rep 578
Here is a really good tip to do before you remove the brake line. i got this from Rheingold, BMW uses a special tool to lodge between the brake & front seat allowing you to press the brake pedal BEFORE you disconnect the brake from the caliper, almost no fluid leaks out that way. My special BMW tool was a push broom w/o the handle installed... I was so worried about that step b/c i thought brake fluid was just going to get everywhere, but as i stated, almost no fluid came out with the brake pedal pressed down Here were the steps i did after getting the car on jack stands & wheels off:
Thanks man!!! |
03-25-2016, 09:45 AM | #7 |
Rep 578
I had a chance to code the car yesterday... I thought the brakes were improved until i had to really get on them yesterday. I definitely have air in my lines. i'm debating if i try to flush the system one more time in the proper order or take it to the dealership & have them flush it electronically & be done with it. Brakes are kind of an important thing. In fact, i think i'm gonna call them now to see if they can work me in this afternoon.
Took a few photos just before the BMW CCA meet last night I was photo bombed by this chic walking by... |
03-25-2016, 04:04 PM | #8 |
Rep 129
Your car can hang with mine! Hendrick was slammed this morning, dropped my car off for them to take a look at the mushy pedal post BBK upgrade. Did you notice an improvement when you coded?
2017 Azurite Black Metallic M3 | Competition package | AA EL mid-pipe
03-25-2016, 07:28 PM | #9 |
Rep 2,082
Looks nice man. Im getting there to be ur twin. I need some of those wheel but 19"s
Also for you guys with the m performance brakes. I have this constant fluttering/ticking noise while driving. Very notice with the windows down and driving next to road dividers and walls. Went to the dealer today and they told me is normal as the rotors are drilled/dimples and air pass through. Pretty annoying. Here is the thread about it. http://f30.bimmerpost.com/forums/sho...d.php?t=826559
03-27-2016, 09:39 PM | #11 | ||
Rep 578
The weather has been great in NC the last few weeks & i've actually been home. Since i installed the Dinan CAI & Exhaust, i rarely ride around town with music on, i love listening the CAI spool up & the blow off valve releasing that air & the burble of the exhaust... I have not noticed any ticking noise what so ever.. I'm wondering if they didn't grease everything? i greased every thing as per the Rheingold instructions. Might could be the Anti-rattle clip???? Whatever it is, it's not normal & the dealership needs to find the source of that noise & fix it. Good luck & keep us posted. |
03-27-2016, 10:24 PM | #12 | |
Rep 129
They haven't fixed things just yet and they had my car all day Friday and Saturday and are still reporting the "mushy" pedal. They have informed me that they bled the system 2 additional times and the issue is still there. I am going to go tomorrow and ask to see the ISTA/P report showing that they ran the measures plan for the sport brake retrofit. At this point, I'm wishing I had the OBD cable to do my own damn coding...
06-08-2016, 03:33 PM | #13 | |
Rep 372
06-08-2016, 07:35 PM | #14 | |
Rep 578
You know man, i ended up having the dealer bleed my brakes. It wasn't worth me trying to get my car back up on jack stands, remove all my wheels again & risk a scatch... With the m performance front spoiler, I don't have racing ramps so I can't just drive up on my ramps that I have. It takes me just as long to get the car up on jack stands as it would to bleed the brakes. Sure you can do it with the wheels on but I just get frustrated trying to work on the brakes with the wheels still on. I had an $100 service credit at the dealership so I just had them do it & happy I did. |
06-09-2016, 12:05 AM | #15 | |
Rep 372
06-09-2016, 07:36 PM | #16 | |
Rep 578
Hey but look at all the money you saved from the actual install... wished i knew if they used the software to flush the fluid or just bleed the brakes like we would. |
06-13-2016, 01:25 AM | #18 |
Rep 284
Drives: F30 335i EBII MPPK/BBK
Garage List 1999 Honda CR-V [0.00]
2013 BMW 335i [0.00] 1986 BMW 325e [0.00] 2014 Porsche 991 Ca ... [0.00] 2018 Audi SQ5 [0.00] 1971 Volkswagen Sup ... [0.00] |
They definitely make noises; most noticeable when driving close to barriers/walls/other cars etc. It really doesn't bother me. Add it to all the wind noise, high pitched buzzing and door creaks, it fits in perfectly in the F30.
Current Garage
2018 Audi SQ5 2014 991 Porsche Carrera 4S 1986 BMW 325e 1971 VW Super Beetle |
06-13-2016, 11:40 AM | #19 |
Rep 1,523
I am trying to decide if I should install the set with the dimpled rotors or order an extra set of blank rotors. Too bad there is no one in my area with the kit that I can take a ride in to determine if I can put up with the noise.
06-13-2016, 11:56 AM | #20 |
Rep 2,406
Drives: E30 M3 Cecotto, F85, G05, G07,
I too always wanted a bbk and was so excited to have them on my F31. Congrats, it looks great. Have you noticed a braking difference?
I too have a toddler and a new born, to get the wife to let me spend a few hours on the car is mission impossible.
06-13-2016, 01:12 PM | #22 |
Rep 1,523
The rotors are the same as stock, so you shouldn't need to adjust the parking brakes. There are 2 different part number for the rear rotors (ending 598 and 600). The difference between the 2 is the size of the inner drums for the parking brakes.
