BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Bm3 no burbles help
      10-24-2020, 03:48 PM   #1
mattbert
Drives: BMW 320i 2016
Bm3 no burbles help
I have a BMW 320i n20 2016 and I'm running vrsf catless, no resonators, and a performance muffler. Tuned with stage 1 91 octane. I do not seem to get any burbles in drive, but when my car is in park/neutral, it works perfectly. I have tried to even bring my aggression to 10 and it still does not work in drive. I've contacted bootmod3, and they have told me to re-download my map and not modify it, but I ended up with the same results as before. I really want to hear the burbles in drive, any help would be great, thank you!
      10-24-2020, 04:21 PM   #2
sqwinny
Drives: 2013 6MT 328i M Sport
screenshot your "burble settings" and upload to your post. this is the only way for us to help.
      10-24-2020, 05:15 PM   #3
mattbert
Duration: 1.8
Agression: 7.5
Min speed: 5
Max Speed: 90
Min RPM: 1500
Max RPM: 5500
      10-24-2020, 06:15 PM   #4
snipagang
Drives: 2017 320i xdrive
I have a 2017 320ix. How does the car feel? Does the car feel much faster? Stock this engine feels extremely weak and disappointing.
      10-24-2020, 09:12 PM   #5
mattbert
Tuning my 320i to Stage 1 was worth it 100%, you feel a big difference with the tune, and overall makes the car more fun to drive. I would also recommend getting a upgraded charge pipe to be safe. I ordered one from VRSF which should be coming soon. Also take a look at air intakes for your car, also makes the ride much more fun, I'm using one by injen.
      10-25-2020, 08:42 AM   #6
sqwinny
I had the same issue before recently. Flash it back to stage 1 and leave the burbles up to the tune without modifying them leaving it to "OTS" in your settings. Also the car has to be warmed up, and have some boost built to get burbles in my experience.
      10-26-2020, 10:00 PM   #7
mattbert
Hey thank you for the reply, I gave that a try today, and also tried 93 octane, did not seem to work either. I'm wondering if it could be my muffler, i have a magnaflo performance muffler. But its a performance muffler that rests on the larger side. But i'm not sure if this is possible because you should be able to hear burbles with a stock muffler if you have a burble tune and downpipe.
      10-26-2020, 10:15 PM   #8
j.f.leonard
j.f.leonard's Avatar
Drives: 2012 328i f30
I dont know if a 328i is even remotely the same as far as burbles go, but mine is not tuned and would burble in sport mode with the stock muffler. I got a muffler delete today and it pops like no other. My point is that I dont think its your muffler. I wonder if your car is sulev? Maybe that makes a difference?
      10-27-2020, 02:47 AM   #9
davidr3
Drives: 335i
Active sound design must be enabled. Burbles gotta be turned on within your burble settings. Car gotta be in sport+, warmed up for a few mins or else the car is unwilling to dump the extra fuel.
      11-01-2020, 05:32 PM   #10
sheen.f30
Drives: BMW 328i X-Drive
OP I have the same issue, just flashed today and didnt even get burbles in park! Emailed Protuningfreaks and awaiting a reply. Can't seem to find anything on this. I have N26 engine. Catless Dp, no res, but i do have the stock muffler.
      11-01-2020, 09:54 PM   #11
Wai328
Wai328's Avatar
Drives: F31/F80
It takes some time for the car to adapt to the tune. It took around 100 miles or so before I got all the burbles.
      11-02-2020, 09:11 AM   #12
sheen.f30
Drove over 100 still nothing. I have ASD enabled because PTF told me it has to be enabled for burbles, and on BM3 it says it on there as well. I get burbles in park but not while driving. However, i do have a cheap downpipe. Am buying ER downpipe, will update if anything changes.
      11-03-2020, 12:45 AM   #13
mattbert
I have tried just about everything, been back and forth with pro tuning freaks for almost a month now. Nothing seems to be working, just changing settings for my tune and re instaling things. I don't think a new downpipe will fix it, ive only come across one possible fix for this issue after days of research. If you read this post here: https://f30.bimmerpost.com/forums/sh....php?t=1487843 this person had the same issue and had it fixed with a custom tune from pro tuning freaks. I asked them in the email but they don't think I need to do that to fix the problem yet. Will update on what happens, tried just about everything.
      11-03-2020, 12:50 AM   #14
mattbert
I have switched my tune to 93 octane stage 1, catless downpipe, straight pipe all the way to performance muffler, aggression all the way to max, enabled sound, played with all other settings, and none of that has changed a thing. Not even the smallest burble in drive. I feel like the only fix is a custom tune, unless we are all missing something, but I have tried everything. If anyone else has any ideas please tell me.
      11-03-2020, 02:02 AM   #15
davidr3
Drives: 335i
Isn't your downpipe, I get them on stock cats.
      11-03-2020, 08:31 PM   #16
jkstyle834
Drives: 2016 BMW 330e M Package
I have the same issue... but i do have a hybrid... doing a mid muffler delete this weekend to see if that will help because this car supposedly have two muffler and a resonator. We will see.... i have burble setting at ots. I think.... or i put it to custom and didnt move a bar.
      11-04-2020, 03:08 PM   #17
sheen.f30
Yeah honestly I have no clue... I'm buying awe exhaust with midpipe + the er downpipe and intercooler , so if there's no burbles with stage 2 I'm gonna have issues
      11-07-2020, 06:11 PM   #18
les anderson
Drives: 340i
I have had to reflash before to get burbles. Also, you should have your exhaust valves forced to open. Try shifting with paddles too, bring it up to 5k fast in manual mode and then let off.
Something definitely weird happens at times w bm3 and burbles but I am always able to get it sorted.
      11-14-2020, 07:14 PM   #19
mattbert
Found some what of a solution, when I put my car in manual I get all the pops I'm supposed to. Still does not work in drive, but I'm happy putting my car in manual to get crazy down shift pops and bangs. Anyone else with the same issue try manual, hope it works!
      11-19-2020, 05:00 PM   #20
F30Tattoo
Drives: BMW 320i F30
I’m having similar issue. Did I reflash making it more aggressive and still next to nothing except in really low rpm and next to no noise. I can really only tell cause it’s in a parking garage when I do hear it. I’m pretty sure the 320i doesn’t have ASD and through Bimmercode I did add the sport+ mode but can’t access it either. Not sure if that had something to do with since you can adjust burbles for comfort and sport modes.
      11-20-2020, 01:59 AM   #21
mattbert
just put in manual and try on down shifts.
      11-20-2020, 07:35 AM   #22
F30Tattoo
Yeah I saw that had worked for you and it hasn't made a difference for me.
bm3, bootmod3, burbles, catless
