04-13-2016, 11:07 AM | #23 |
Rep 1,573
There are 2 ways to enable Sport Auto Transmission through coding. the easiest way is:
1) changing 205 to 2TB. For whatever reason or another I found that to be a little more difficult than the route I decided to take: 2) updating 3-4 parameters in the transmission ECU (yields same result as #1) I wish this thread came out earlier i really wanted to do this, but i only have a few more months left on my lease...not worth it now (price is just under $700)
2015i Cadillac Escalade ESV
04-13-2016, 12:38 PM | #24 |
Rep 266
04-13-2016, 01:03 PM | #25 | |
Rep 1,067
If you have 205, you don't have sport trans coding. |
04-14-2016, 06:43 AM | #26 | |
Rep 266
Ok , clear ,
but then what is this coding? Quote:
F32 m428i estoril blue
E65 745i toledo blue Athens GREECE |
04-14-2016, 09:12 PM | #27 | ||
Rep 962
04-15-2016, 03:18 AM | #28 |
Rep 266
Thanks guys now situation is cleared in my mind.
And a last question that maybe helps also the tutorial. Are these above 3 orders enough to fdl code SAT or there are some more ? Can somebody clarify which are the correct ones via fdl coding ? |
04-15-2016, 07:02 AM | #29 | |
Rep 1,067
KOMBI FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 ICM ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut EGS EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv EGS/3000 Applikation -> LC -> aktiv I don't recommend FDL coding (above) for Sport+/LC/Sport Trans coding. |
04-26-2016, 05:48 PM | #30 |
Rep 943
Drives: 2012 328i Modern Line
Without tearing your console apart to check, how would you be able to tell which shifter you need as there are two different ones available, a 7-pin and a 10-pin?
04-27-2016, 04:13 PM | #31 | |
Rep 1,067
On RealOEM.com, I thought you could input your VIN, I wonder if we could cross-reference the non-sport shifter variant. Does that site list that level of detail? |
04-27-2016, 04:40 PM | #32 | ||
Rep 943
:wave:
05-03-2016, 09:21 AM | #33 |
Rep 943
Ok so I found a reasonably priced shifter but my I-Level is older than what is listed in thread as a requirement. The dealer said they won't/can't do a update unless there is a malfunction or new hardware is added.
If I was to install the newer shifter with the car the way it is now would I still be able to drive the car and have the I-Level updated later?
:wave:
05-03-2016, 05:54 PM | #34 | |
Rep 1,067
05-04-2016, 06:12 AM | #35 |
Rep 943
Does this mean my I-Level is the first number and the update is the one under it?
[IMG]http://d.pr/i/1jitk+[/IMG]
:wave:
05-05-2016, 07:42 AM | #36 |
Rep 5
i can confirm for shore that for the guys that do not have the necesary i-level can be done with fdl but you can not code LC the rest works like a charm just finished coding on my 2012.09 F30 and is a big diference in handeling and how the car responds to your foot
05-06-2016, 03:38 PM | #38 | ||
Rep 943
The bottom left screw was the biggest challenge of the install but following your instructions I got er done. [IMG]http://d.pr/i/13cCZ+[/IMG]
:wave:
05-08-2016, 02:26 AM | #39 |
Rep 27
When you performed the coding procedure, how did you ensure sufficient power was provided? Are you using a battery charger or kept the car running?
I have read on the forums that ECU only coding can be done while the car is running, however this seems risky... Thank you in advance. |
05-08-2016, 02:40 AM | #40 | |
Rep 3,947
You will want a power supply/charger for a full flash. http://f30.bimmerpost.com/forums/sho....php?t=1204244 has discussed this a bit. |
05-08-2016, 02:53 AM | #41 |
Rep 27
Thank you for the link. Can you recommend a battery charger of a decent price? I have trickle charger but based on the forums looks like it's not appropriate.
05-08-2016, 02:59 AM | #42 | |
Rep 3,947
The others require workarounds to work. Even a CTEK MUS 25000 that can supply a constant 25A @ 12V may not have a high enough voltage and even if it did, 25A may not be enough for long flashes. For example, I was using a charger that could do 60A but you may see a voltage > 16.0V when there was no load on the system. |
05-08-2016, 04:23 AM | #43 |
Rep 27
Thank you for the detail. sounds like that the charger option is delicate balance; would finding a second car as a power source, presented as an alternative, be something that you'd recommend?
05-08-2016, 09:44 AM | #44 | |||
Rep 1,067
