07-02-2021, 01:31 PM | #1 |
Rep 27
Help, I think I added too much e85
I have a jb4 running map 5 and I accidentally added 6 gallons of e85 on a full tank, I'm full bolt on with stock spark plugs and have 32k miles on the car, is there anything I need to be worried about with adding a bit too much e85? I'm lowkey freaking out
07-02-2021, 02:15 PM | #2 | |
1296
Rep 3,533
drive in eco mode till you can add more 91-93 to compensate.
07-02-2021, 02:47 PM | #3 |
Rep 7,606
What car do you drive? This is the N55 section but your profile says 430?
07-02-2021, 03:27 PM | #4 |
@_sunbish
282
Rep 611
Just stay out of boost and you'll be ok. Once you lower the level enough, add whichever premium gasoline is available to you (91 or 93).
07-02-2021, 10:46 PM | #5 | |
Rep 27
07-02-2021, 10:52 PM | #6 | |
Rep 27
07-02-2021, 10:54 PM | #7 | ||
Rep 27
07-03-2021, 03:41 AM | #8 | |||
1296
Rep 3,533
imperfectluck426.50 |
07-03-2021, 09:44 AM | #9 |
Rep 5,776
I think you will be fine--when I was using my JB4 I would put in 6gal and the rest 91 when the tank was under 1/4 full. That was my mix. If your car is running well and things look good that might be your go to mix.
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-03-2021, 11:19 AM | #10 | ||||
Rep 1,148
I added too much, did I hurt my car? Goes out and beats on it Lolol |
07-03-2021, 12:39 PM | #11 |
Rep 7,606
Pussiwillow521.00 |
07-03-2021, 01:51 PM | #12 | |
1296
Rep 3,533
07-03-2021, 02:06 PM | #13 | |
Rep 27
07-03-2021, 02:23 PM | #14 |
Rep 7,606
Use the JB4 to collect a datalog and make sure its recording the HPFP parameters. Read my thread on datalogging here: https://f30.bimmerpost.com/forums/sh....php?t=1732327
07-03-2021, 08:34 PM | #15 | |
Rep 27
07-03-2021, 11:28 PM | #16 | ||
1296
Rep 3,533
07-03-2021, 11:58 PM | #17 |
Rep 7,606
07-09-2021, 07:29 AM | #18 |
Modder of everything I own
147
Rep 491
I add about 6.75 gallons of e85 with my 6.75 gallons of 93oct every fill up for the past couple of years and run in map 7. Is yours a PWG?
*Actually I see the mileage on your car so unlikely it's PWG lol, sorry
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
07-09-2021, 08:58 AM | #19 |
Rep 190,777
Drive conservatively until the gas tank is on empty , there is nothing to worry about as long as you are not pushing the car on high RPM
07-09-2021, 10:07 AM | #20 |
Rep 7,606
Asked the same thing above, but he didnt answer. PWG can handle more E85 because boost falls off before HPFP crashes typically.
07-10-2021, 12:40 PM | #21 |
Rep 4,913
Yup. Slightly larger outlet on the ewg makes up for the smaller amount of e85.
07-10-2021, 02:06 PM | #22 | |
Rep 27
