01-15-2022, 01:02 PM | #1 |
Rep 16
Need advice...
The front passenger side run flat that my car came with blew out with a small tear in the sidewall today. The tires only have about 17000 miles on them. In a spot where it feels wasteful to buy one brand new one as the tread difference would be about double on the current tires. Thought about just buying a used run-flat for the time being. Thoughts? Thanks.
01-28-2022, 02:14 PM | #5 |
Rep 715
Drives: 2021 X3 M40i
This would be my advice as well. Better to have a matching set, especially on the front.
01-28-2022, 05:38 PM | #6 |
Rep 1,641
Definitely get two. That has happened to
me a few times after taking a few construction nails in the tires. There are some new Michelin Pilot sport 4zp run flats that seem at least to me worlds better than anything I have run in the past. In case it matters they are also star bmw rated. I have also noted that the tire pressure on the door does not work well with oem run flats. My dealer recommend different pressure and on my second set of tires I doubled the mileage on them. The door says 32/35 for my 340. The dealer said 36 square and that has worked great. I would probably even go to 36/37 as the backs wore just a slight bit faster. For me, the first set of rfts were all worn on the edges, not the middle using the 32/35 setting; with the 36 square I had even wear on all four tires for the most part (maybe a little bit more on the back. I have a staggered set up so I can not switch from front to back. Anyway I hope that might help? |
02-19-2022, 05:02 PM | #7 | |
1296
Rep 3,533
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
02-20-2022, 12:47 PM | #9 |
Rep 16
Hey everyone appreciate everyone's input. I know some time has passed but wanted to give a little update. At the moment when I had made the post I needed to be able to drive the car asap since I had a family member in the hospital. All local shops did not have tires in stock and needed to have them shipped which would have taken too much time given my situation. I went ahead and just replaced the front with a used run flat. I have bought a new set of tires and am going to be replacing all 4 of them soon enough
