BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Wheel Cleaner
proTUNING Freaks
      07-15-2018, 08:38 PM   #1
IK6SPEED
Drives: BMW M3 / AH3
Wheel Cleaner
I am sure there are about 10,000 posts on this, but let me give the exact scenario.
A Detailer I used several times would spray something on the wheels about 60 seconds before they started with the car soap from a pressure washer.
Always took every bit of the dirt, grime and whatever from every single place on the wheels. Never found out what it was.
Wondering if anyone knew of something that worked this well on melting off the dirt without getting into the wheel with a brush?
      07-16-2018, 09:20 AM   #2
DarkStarBimmer
Colonol Forbin
DarkStarBimmer's Avatar
208
Drives: 17' BSM 330i xDrive
2017 330i  [0.00]
IRON X it smells awful but works great.
IK6SPEED4488.00
      07-16-2018, 09:27 AM   #3
Tribalpinoy911
Tribalpinoy911's Avatar
Drives: F34
Sonax wheel cleaner does this.
IK6SPEED4488.00
      07-16-2018, 12:03 PM   #4
IK6SPEED
Full Effect or Cleaner Plus?
      07-16-2018, 12:24 PM   #5
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
The full effect. Great wheel cleaner.
IK6SPEED4488.00
      07-16-2018, 03:46 PM   #6
Tribalpinoy911
Drives: F34
+1
      07-16-2018, 03:51 PM   #7
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
I use the Sonax Cleaner Plus. It is the newest formulation, 30% stronger than the Full Effect and works much faster
I use it 1X/wk, removes all brake dust, dirt, any discoloration with just a garden hose - I would guess a pressure washer would be even more effective
IK6SPEED4488.00
      07-16-2018, 03:53 PM   #8
a803sgo
Drives: BMW 320D M-SPORT (F30)
bilt hamber
IK6SPEED4488.00
      07-16-2018, 06:08 PM   #9
FaRKle!
Not for me it doesn't. I use Sonax Plus all over my wheels (and Sonax Multistar APC on the tires), spread it around with my brush, then pressure wash it off, and it definitely won't get absolutely everything off. I usually go over the wheel with a microfiber towel after to really get it all clean (after I blow all the water off with a MetroVac).
Plus definitely works better than Full Effect or Car Guys' wheel cleaner though. I like the spray nozzle on it. It's much better at getting a wider area with even spray. A bottle doesn't last very long though...
IK6SPEED4488.00
      07-16-2018, 06:15 PM   #10
louielouie
Drives: '18 F80
Iron X is quite good as a cleaner for the wheels, but I still use a degreaser (SuperClean) in a 3:1 with distilled water to take the browning out of my tires. And you gotta scrub for the tires.
I'm curious if there's a 1 spray fits all as well but to remove/stop corrosion from industrial runoff and pull the browning from the tires is a tall order.
IK6SPEED4488.00
      07-16-2018, 07:06 PM   #11
IK6SPEED
Not positive.
Ugh.
      07-19-2018, 10:30 AM   #12
rolltidef32
National Championship #17 and Counting!
rolltidef32's Avatar
793
Drives: 2018 BMW i3s and 2019 X5
I use P21S Gel cleaner for wheels and tires; buy it by the gallon and it lasts all year. I wait for 25% sales on Autogeek.net which happens at least once per quarter.
Sonar Plus does work great. I would not use Iron X for regular wheel cleaning, as it is a waste, costly, and smells terrible as someone pointed out. I use Iron X before twice annual paint corrections.
I've never found a cleaner where I didn't need to follow up with a cheap microfiber towel. Just be sure that whatever you use is PH neutral, which means stay away from crap at Autozone unless you find Griots at Advance Auto.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control
IK6SPEED4488.00
      07-19-2018, 10:50 AM   #13
IK6SPEED
Originally Posted by LobB View Post
Dragon's breath.
Dragon's Breath seems to be the only one listed above that all YouTube demos do not show any manual intervention with a brush or towel.
Then again, getting it USA from EU certainly runs the price up.
      07-19-2018, 12:39 PM   #14
louielouie
Drives: '18 F80
I tried Decon from Chemical Guys as well - it smells wayy worse and doesn't work nearly as well. You should give it a try because now I think Iron X smells good, hahahah.
      07-20-2018, 01:46 PM   #15
vanbmw
vanbmw's Avatar
Drives: 2015 Black 335i
Did the wheel dirt/grime turn RED and run off? If it did then it is something like SONAX or similar. If it didn't then they may have used a strong degreaser. I have a buddy that uses a strong degreaser on his wheels and it certainly takes everything off however I have read he label and it is some bad strong stuff! I read the warnings and I wouldn't use it on my wheels. However, he uses it on his wheels (Porsche Cayman) and figures since he rinses it off quickly he won't have problems. His car is 6-7 years old and his wheels haven't had any issues but it still doesn't make me want to switch to that stuff.
      07-20-2018, 02:06 PM   #16
evdok
evdok's Avatar
Drives: 330D M/SPORT xDRIVE INDIVIDUAL
This is good..
Happy Motoring
Evdok
      07-20-2018, 02:16 PM   #17
IK6SPEED
Most all turn some shade of red in YouTube demonstrations.
What is the stronger stuff called?
      07-20-2018, 02:20 PM   #18
IK6SPEED
Originally Posted by evdok View Post
This is good..
Demo shows brushing needed and recommends only for light dirt. They suggest their Dragon’s Breath product for heavily soiled wheels.
      07-20-2018, 03:20 PM   #19
evdok
evdok's Avatar
I never let my wheels get black/heavy brake dust, but I can say medium dirty wheels left for a week odd come up clean & I mean no need to touch the wheel with anything.
Happy Motoring
Evdok
      07-20-2018, 03:28 PM   #20
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
Do you know what color the liquid was? Honestly it's probably a diluted solution of Dawn, bc it's cheaper than them buying wheel cleaner
i've used this and it works pretty well https://www.amazon.com/Best-Wheel-Ti.../dp/B014V9GFJU
      07-20-2018, 07:18 PM   #21
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
there is no such thing as a 100% hands free wheel cleaner.
either your wheels were relatively clean to begin with and the detailer just spray wheel cleaner on to get some light dirt off or you might have not watched his whole process.
i'm not trying to rain on your parade i'm just saying ask any detailer and they will agree there is no such thing as a true no agitating wheel cleaner on the market.
      07-20-2018, 07:21 PM   #22
IK6SPEED
They were filthy...and I’ve seen several times.
