01-31-2021, 10:42 PM | #23 |
Rep 40
My logs are horrible as well, pulls timing all across the band with 1 step colder gapped, 2 step colder gapped, upgraded coils and all. Why do you say .022 isnt good? Tuner suggests to gap it...fbo upgraded lpfp with meth injection on 93 pump. The only time i dont get much correction is when i add 2 gal of e85 but than hpfp struggles. Although recently i discovered that my hpfp crashes under wot even on pump gas so that might be a root of my corrections imo
02-01-2021, 09:07 AM | #24 | |
Rep 3,361
08-02-2021, 08:41 AM | #25 |
Rep 338
Anybody figure out a way around the massive timing corrections. M240i AT running MHD stg 2 HPFP e40 map. Even increasing to e60+ doesn't correct it. DSC off and seems the DME still using safety nannies to apply power to the ground. Using M z40i/Supra plugs didn't help. Car became very responsive though. I was running stock gap. Went down to 20-22 than to 25 gap. Just reduced response but not corrections. I added an injen closed air intake 2-3 weeks ago which feels like more torque and power especially midrange. It seems the corrections got even worse after that. Sometimes easing into the throttle helps a little but that's no fun.
12-19-2022, 09:24 AM | #26 | |
Rep 6
Did anyone ever solve this. I'm dealing with the SAME issue right now I'm on flex fuel tune and the SAME event is happening. Truly frustrating. Any help is appreciated! |
12-19-2022, 09:26 AM | #27 | |
Rep 6
12-19-2022, 09:27 AM | #28 |
Rep 6
12-19-2022, 09:53 AM | #29 |
lurker
24
Rep 111
It's not an issue that I've been able to see. It's that some cars are more finicky to changes in tuning when pulling cats. This is something that my custom tuner has been able to work out, I now have pure800 on my b58 and it runs strong with good timing. It's just that it takes my tuner a bit to dial mine in compared to some b58's, but Chris @ Motiv has always got me set and happy in the end. Tuning for port injection now! 😈 --MW
12-19-2022, 03:15 PM | #30 |
Rep 182
Did you figure out why load actual exceeds sometimes load target, causing some torque limiter intervention (and timing corrections), and how to avoid this issue?
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
12-21-2022, 07:44 PM | #31 |
Rep 146
Timing corrections are unavoidable when the tune is maxing out to get high power levels. Bootmod3 stage 2+ tunes have timing corrections as well. Can’t escape it. But I would go bm3 or do a relearn if it’s availabile on mhd. Best option is a custom tune to program out the timing corrections so it doesn’t cause you any issues.
09-18-2023, 01:34 PM | #33 | |
Rep 6
09-18-2023, 01:36 PM | #34 | |
Rep 6
04-06-2024, 11:48 AM | #35 |
Rep 1
Hi I have the same issue on my M140i and I solved in this way:
- replace camshaft sensors with new one both side exhaust and intake; - Delete adaptation, with MHD+ load adaptation, vanos adaptation, fuel advance adaptation, knock adaptation. - leave 2 minute the car in idle condions After try to drive the car in different speed and load After try again to push full load My car in another car, more torque and power |
