02-25-2020, 02:45 PM | #1 |
Rep 1,827
Why I will stick with Michelin PS4Ss
I had a square set of Pilot Sport 4Ss (245/35 R19) put on last July. I drive a lot, occasionally spiritedly, and in the 16,000 miles I've put on them, they're down to the cords. Slightly more wear on the inner edge, to be expected due to the natural camber of the car plus I'm lowered.
On these tires, Michelin offers a 30,000 mile treadwear warranty, so my prorated discount came to a savings of -$476.40 on a replacement set that would've cost $1028. So my total out of pocket came to $689.63 including mounting, balance, TPMS service, etc. Less than a new set of lesser, more "budget-minded" tire options. Yes, there is a higher level of entry, but if you go through tires quickly, I think it's worth the warranty. Disclaimer, having a square setup is key because the warranty stipulates that tires are rotated and balanced properly. If you run staggered, the warranty mileage is cut in half. Also, if you run a lot of negative camber and the wear is TOO uneven, Michelin may reject the warranty claim. Store manager at my America's Tire said mine were close but was even enough that it should be ok.
02-26-2020, 12:17 AM | #2 | |
Rep 7,602
I am fully aware of the other "fine print" - i have read costco's and its mostlyt relaged to abnormal wear or improper alignment. I just autocrossed the car and plan to drive the 5k miles before my rotation to get the tire wear "looking" normal again. I know they will only rotate side to side if staggered, but have never heard of the warranty being cut in half. Is this explicity in writing somewhere? |
02-26-2020, 12:35 AM | #3 | ||
Rep 1,827
https://www.michelinman.com/on/deman...uick-Guide.pdf At the bottom under Split Fitments:
02-26-2020, 11:32 AM | #4 | |
Rep 7,602
The other interesting thing about the screenshot is that only the rears are cut in half? |
02-26-2020, 12:13 PM | #5 | ||
Rep 165
03-02-2020, 10:15 AM | #6 |
Rep 891
When filling out the claim form to Michelin you need to list the date and mileage of each completed rotation.
"At the time of a claim for mileage warranty coverage, the tires must be evenly worn to 2/32nds of an inch of tread remaining, the date and odometer reading at the time of mounting must be documented, and the rotation service record must be completed, showing that the required rotations were performed." https://www.michelinb2b.com/wps/b2bc...ure_manual.pdf
jh_f301306.00 |
03-02-2020, 10:18 AM | #7 | |
Rep 1,827
03-02-2020, 11:03 AM | #8 |
Rep 891
You did it right!
03-03-2020, 12:34 PM | #9 |
Rep 7,602
I have made multiple mileage claims over the years when my tires have worn out before the mileage guarantee and i have never once been asked to actually complete any of the paperwork for the warranty myself. I have really only been asked to confirm documentation for the rotations (which are essentially always done at the place you get the tires from so no additional paperwork is required). Maybe this only applies if you order direct or from tirerack or something?
03-03-2020, 06:06 PM | #10 | |
Rep 891
03-05-2020, 05:41 PM | #11 |
Rep 5,506
I had PS4S installed. I had BMW OEM Pirelli P7s before. Definitely made a big difference in the car. Much more tire grip and the ride is more comfortable as well.
For the warranty, the shop told me I need to have a wheel alignment and documented tire rotations every 5-6k miles in order to maintain the tire warranty. I usually do my own tire rotations so this part is kinda a bummer as I need to set aside extra time to drive to a shop and pay someone to do it.
Auto Detailing Enthusiast!
03-05-2020, 06:16 PM | #12 | |
Rep 7,602
03-05-2020, 08:17 PM | #13 | ||
Rep 165
03-06-2020, 01:29 AM | #14 | |||
Rep 1,827
03-13-2020, 04:52 PM | #15 | |
Rep 5,506
I usually go to a local shop that mounts my wheels and tires. They always do an excellent job and it is the same tech that does every car that comes in. I've had a bad experience with large chain tire stores scratching my wheels. I also prefer to just rotate tires myself as its more convenient to do it at home.
03-13-2020, 05:13 PM | #16 | ||
Rep 165
04-03-2020, 03:36 PM | #17 |
Rep 88
A question to jh_f30 (or anyone with tire warranty claim experience):
One of the common tire wear warranty requirement is for the tires to wear out down to 2/32" between a certain period. In your case, the inner edges are for sure below 2/32" since they are down to the cords. How about the outer edges? I am wondering if they will take into account the lowest measurement or the highest portion. Example: inner edge is 2/32" but the outside is still 4/32", will they honor the warranty? Personally, I would think that VERY few people can take advantage of tire wear warranty. If the alignment is neutral and all four tires wear evenly, it would be dangerous to drive around until the whole surface of the tires (inside, middle, outside) wear down to 2/32". Most people would've replaced the tire before this. |
04-03-2020, 04:59 PM | #18 | |
Rep 1,827
I imagine some shops might not want to take the chance, and I can't speak to how much variance between inner and outer wear Michelin considers "allowable". I would GUESS that 2/32nds difference wouldn't cause any red flags, especially for performance tires. I'm sure all parties involved are aware that sports/sporty cars run some amount of negative camber from the factory. I don't have a camber kit on my car, so if you do and you're running upwards of -2 degrees or more, and the inner tread is down to the wear bars and the outer tread is still 5-6/32nds (hypothetically), there's probably a good chance they'll reject them. Also, I don't know that the warranty only applies to tires that have worn down to 2/32". If you get down to 3-4/32" after 15K miles on a 30K mile-warrantied tire, you might have a good case for replacement with close to a 50% prorate. However, again, YMMV depending on your shop, rep, manager, etc. In any case, it worked for me and I came away with a set of brand new MPS4Ss for under $700, mounted & balanced.
04-03-2020, 07:00 PM | #19 | |
Rep 88
The reason for the questions above was that I am currently looking for a new set of tires, and slightly considering going square (currently riding on staggered 400m's) to maximize the mileage warranty. After doing further research, it seems that the warranty for Michelin has more "gray area" compared to Continental (the tire I'm interested in). Continental's: "Subject to the provisions of Section 4 in the Total Confidence Plan, if one of the tires listed in this section wears out before the stated mileage/ kilometer coverage, CTA will warrant the tire on a pro-rata basis as indicated herein. "Wearout" means that the tire's tread has worn evenly down to the tread wear indicators (2/32nds of an inch or 1.6 mm of tread remaining.)" Michelin's: "If the tire treadwear does not reach its mileage warranty a pro rata replacement of the tire may be available under this warranty. For the mileage warranty associated with a specific tire, please see your Michelin tire retailer or visit www.michelinman.com/promise" Continental's seems to only allow a claim if the tires are already 2/32nd. While, I guess, Michelin *might* allow a claim if we can show the the usage trajectory will wear out the tires before reaching the mileage warranty. Such as your example of "get down to 3-4/32" after 15K miles on a 30K mile-warrantied tire". |
04-03-2020, 07:07 PM | #20 | |
Rep 7,602
04-03-2020, 08:15 PM | #21 | |
Rep 1,597
04-03-2020, 09:19 PM | #22 | ||
Rep 1,827
