02-11-2019, 02:18 AM | #1 |
Rep 55
Tire pressure recommendation
A couple weeks ago I had a local shop put on a staggard setup of 235/40ZR-19 MICHELIN PS4S and 265/35ZR-19 PS4S on my 2015 335i.
After the install I talked to the technician and he said he set the tire pressure to 41 psi. That seems a bit high. Does anyone know if that is an issue? Any insight into whether I should keep that pressure or drop it back down to 38 psi? |
02-11-2019, 08:03 AM | #2 |
Rep 5,457
Drives: F30
Recently left the dealer and they asked permission to set the tire pressure to 32psi cold. They mentioned this is the proper psi for this body "from the factory."
I agreed, no problem. When they get warm, psi increases to 34 or 35 max. |
02-11-2019, 09:13 AM | #3 |
Rep 10,256
For OEM 19" run flat tires, BMW suggests 33 PSI in the front and 38 PSI in the rear. The tire pressure on non run flats should be higher to account for softer sidewall but is 41 PSI on all tires correct?
02-11-2019, 09:59 AM | #4 | |
Rep 5,457
Drives: F30
This was with Continental DWS 06 (the best, non run-flat all season they offer). Dealer recommends 32psi cold, all around. Had I been wearing top of the line Michelin... the result would be the same. |
02-11-2019, 10:05 AM | #5 |
Rep 3,679
I run PS4S's as well, 245/30-20, and set them to 34 cold all around. As long as they're not super high (41 cold is closing in on that) or super low ( <30 cold) it'll be fine, it's kind of a preference thing. That said, I'd drop it down to at least 38 psi. IIRC my tires even say on them do not inflate over 40psi, though that may vary for different sizes.
02-11-2019, 10:40 AM | #6 |
Rep 4,325
the driver door sill placard lists cold tire pressures. since non-runflats have a softer sidewall than runflats, i'd initially add 3 psi to whats listed and then adjust if needed, after driving around and seeing what the comfort, steering response, etc., is like.
02-11-2019, 10:53 AM | #7 | |
Rep 5,457
Drives: F30
I believe a couple psi increase to compensate for softer walled tires makes sense. Putting us somewhere in the 34 psi cold, 36 warm range. At the end of the day, as mentioned above - it comes down to personal preference and feel once you are within the 32-38 range. Anything lower or higher may need adjustment. |
rjd_F301999.50 |
02-23-2020, 09:51 PM | #10 |
Rep 165
What model, year, trim , tire brand and tire size, square or staggered setup ? My 2017 440i convertible door placard says 36psi front, 41 psi rear (cold) on 19" staggered set up, Pirelli P Zero RFT. Seems as if these placard pressures coming from factory are all over the map between trims.
02-23-2020, 11:03 PM | #11 |
Rep 2,808
Drives: F33 430 and F39 M35i
Yep. My f33 lists 33/41 for oem. I switched to goflats and have been running 34/43 which is what I find comfortable.
02-24-2020, 06:43 AM | #12 |
Rep 223
Does anyone know what is recommended by BMW for staggered set 225/45/18 front and 255/40/18 rear on runflats?
BMW F30 320D EfficientDynamics
Stage 1 remap, EGR delete, 398 alloys, tinted windows, M Sport front bumper, M Performance grilles, M Performance spoiler, gloss black mirrors, tail light tints, debadged. |
02-24-2020, 04:29 PM | #13 | |
Rep 7,602
For OEM 225/40/90 and 255/35/19, it is 35F/38R or 39F/44R if over 100mph. This was my OEM spec for RFT. I switched to PS4S non runflat with a change in front size to 245/35/19 (still 255 rear) and i run about the same now, 36F/38R, as my cold PSI setting. It seems to work well overall. I dont have a problem hooking 1st year from a dig really, but if you did, you could probably lower to 35 or 36 psi square. |
02-24-2020, 11:44 PM | #14 |
Rep 165
What model, trim, tire set-up? The pressures on door placards vary significantly based upon these factors.
02-26-2020, 01:50 PM | #15 |
Rep 165
02-26-2020, 04:44 PM | #16 |
Rep 2,808
It rarely gets past 43. it's so cold here and it always drops to 41 the next day anyway. my gauge might be broken. lol
I just checked a little bit ago and i'm at 31/40 right now. |
02-26-2020, 06:53 PM | #17 |
Rep 165
After driving around 100 miles on a warm day (approx 90 deg), I have pulled into my garage & measured my tire pressures and they were (starting out at 36 front/41rear cold): 38-39 front/43-44 rear. Of course the next morning after the car sits around 10 hours the pressures are back down to 36 front/41 rear. I'm just wondering if I want to put my 'cold' pressures at something like 34 front/38 rear. I'm putting the new tires on tomorrow so I'll play with tire pressures for a few weeks and come up with something. Thanks
