02-14-2020, 01:38 PM | #23 | |
Rep 79
Higher velocity means higher head loss along the length of the pipe, all other variables being equal. Flow is driven by pressure differential: the more head loss through the pipe, the more flow you lose. The real kicker is this: It also increases the pressure at the outlet of the turbine, since ambient pressure in this case is fixed. Turbine work is defined as the change in enthalpy across the turbine, and higher pressure at the turbine outlet means less deltaE. This affects spool. Lower head at the turbine outlet means more turbine work for the same flow rate. There's a point of diminishing returns on size though, which is why you're right about the 5in exhausts being ridiculous. Look at the BMW/Megatron F1/GTP motor from the mid-80s. It's got a ~3in exhaust and moved upwards of 1400bhp worth of air through it just fine. |
Skyhigh1888.00 B50AteYourRide70.00 |
02-14-2020, 02:35 PM | #24 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
I'm sold.
BRB, disconnecting my downpipe
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
02-22-2020, 11:17 PM | #25 |
Rep 233
not sure....someone would have to take a risk and open it up
04-01-2020, 01:30 AM | #26 |
Rep 585
After checking out all the options I've ordered a CG Precision DS-1 catted downpipe as it has the same 5" cat diameter, but a single 200 CPI race cat, so guaranteed to flow a lot better than the stock DP. I also really like the design, purged/passivated welds with no annealing colors ensuring more durability.
I'll be posting up datalogs from before and after vs the stock DP. I hope to have it by the end of next week and installed ASAP. Now that I'm running higher boost on top of the MHD Stage 2 E30 OTS map and E34 fuel some additional flow will benefit. Thanks Mike at Extreme Power House for sorting it out so quickly for me
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph Last edited by OzBMR; 04-13-2020 at 06:44 AM.. |
InstigatorX58.00 |
04-16-2020, 12:03 AM | #27 |
Rep 585
Got the CG Precision DS-1 down pipe delivered today and ... they sent me the wrong pipe
It looks like someone's old pipe that must have been sent in for warranty repairs as it had a new catalytic converter, but the pipe itself looks like it's been on a car for a few years and 30K+ miles of wear and tear. Sending it back and expect it'll be several more weeks before I get the replacement.
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-09-2021, 05:14 AM | #29 | |
Rep 3,873
Above - stock. Below - Akrapovic (note they declare lower weight which is wrong) [IMG] View post on imgur.com [/IMG]
eljefe301.50 |
07-09-2021, 06:30 AM | #30 | |
Rep 10
