12-01-2020, 11:51 AM | #1 |
Rep 6
New engine on the way
so around a year ago the engine on my 335i spun a bearing and the day has finally come that I have sourced a new engine and have a garage to do the swap. My question is going from a my 2014 n55 sport package to a 2013 N55 out of a m sport edition are there any swaps that I need to do in order for this to work properly. I know that the turbo will need to be swapped due to the the EWG vs PWG , but is there anything else? Thanks for the help
12-01-2020, 11:57 AM | #2 |
Rep 5,369
I wouldn't do it. The 2013 N55 runs the old rod bearings that are more prone to spinning. At some point in 2014, BMW started using the S55 rod bearing in the N55s.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
12-01-2020, 12:09 PM | #3 |
Rep 6
i plan to put new bearings into the motor before it goes in anyway. It will be getting new bearings (most likely VAC coated), new gaskets, and other odds and ends. I just could not pass up and entire running motor for $500
12-01-2020, 01:18 PM | #4 | |
Rep 7,602
In terms of your question, you might need to look into coding certain things like injectors, depending on differences between the engines. There may be some software changes needed in addition to any hardware swaps. |
12-01-2020, 02:00 PM | #5 |
Rep 1,105
I would source a 2014 or newer engine. I've read so many posts regarding random issues with model year 2013. Not to mention it has the smaller PWG turbo. If possible I'd look at the m235 engine or a m2(n55) engine.
12-01-2020, 07:01 PM | #6 | |
Rep 1,118
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
12-01-2020, 08:33 PM | #7 |
Rep 6
Took the car in for an oil change and 2 days later noticed a little oil around the oil filter housing, wiped it down and carried on. Checked on it the next day and it was back so I took the car in to have the gasket replaced. Gasket was replaced and about a week later the engine seized on me driving home from work.
12-01-2020, 08:35 PM | #8 | |
Rep 6
12-01-2020, 10:51 PM | #9 |
Rep 1,148
A lot of bearing failures after the ofhg replacement, I just changed mine and dumped oil down there and primed it per bmw and so far so good 1k miles later.
Made me nervous after hearing about it all, sorry for your experience with the problem. |
DG33069.50 |
12-02-2020, 06:35 AM | #10 | |
Rep 1,118
12-02-2020, 11:24 AM | #11 | |
Rep 7,602
I am wondering if OP tried anything similar with the shop that did the repair... |
Boostedphil698436.00 |
12-02-2020, 11:56 AM | #12 |
Rep 67
Yeah wow when this happened to me I also heard a lot of bearings failing after a OFHG replacement This is oddly strange it happens right after the replacement.
12-02-2020, 01:04 PM | #13 | ||
Rep 1,118
12-02-2020, 03:00 PM | #14 | |
Rep 5,369
12-02-2020, 06:03 PM | #15 | |
Rep 6
12-02-2020, 06:05 PM | #16 |
Rep 6
No it was an independent shop that did it. My closest BMW dealer is 2.5 hours away versus this shop being 3 blocks from my house. The owner also races Porsche cars and has built a couple 3 series track cars in the past. So I trust him with his work versus the other shops in my area.
