11-22-2021, 09:05 PM | #1 |
Rep 10
Hey guys so after a while of looking over forums I was trying to figure out which pump would work for me. I'm just trying to run bm3 stage 2+ e30 multimap and a hpfp is required hardware. Can I get away with a stage 1 pump without it crashing. I would much rather buy the stage 1 since I should be upgrading cars in about a year. Thank you (2015 335i)
11-22-2021, 10:08 PM | #2 |
Rep 7,602
Stock turbo?
The main other consideration is that most people run E50 or so on that map. You might be approaching stage 1 limit depending on what E% you run. |
11-22-2021, 10:13 PM | #3 |
Rep 10
yeah brother stock turbo I know lots of people get the stage 2 pump but they usually have a PS2 turbo on the setup I just plan on running the bm3 stage 2 + multimap and I'm hoping I'd be fine with a stage 1 pump as the car does feel like it's starving from fuel with the stock pump.
11-22-2021, 10:20 PM | #4 |
1296
Rep 3,533
get the stage 2
11-22-2021, 10:44 PM | #5 |
Rep 10
11-23-2021, 11:35 AM | #6 | |
@_sunbish
282
Rep 611
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
F30IDR7.00 |
11-24-2021, 09:16 AM | #7 | |
Rep 190,775
we have the stage 1 dorch on a 15% sale this week
11-24-2021, 09:38 AM | #8 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
Dorch just announced a lift kit for the N55 which will flow more than stage 2. So I'd wait for that if you can or need it.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
11-24-2021, 11:07 PM | #9 | |
Rep 5,393
11-24-2021, 11:35 PM | #10 |
Rep 419
Currently running a stage 1 here. I also contemplated when it was first released if I were going to do the stage 2 but settled on 1 and also running the stage 2+ map and I just 50/50 fill up every time. HPFP hasn't had any issues and since you're planning on shifting cars in a year, if you want to just get some fun within this last year of ownership, get the stage 1 and call it a day. If you were going behind the stock turbo then I could see the contemplation between the two.
johnung4528.00 |
11-25-2021, 03:00 PM | #11 | |
Rep 10
imperfectluck425.00 |
11-25-2021, 03:07 PM | #12 | |
Rep 419
F30IDR7.00 |
11-26-2021, 11:31 AM | #13 | ||
@_sunbish
282
Rep 611
11-26-2021, 11:43 AM | #14 | |
Rep 190,775
we are only offering the discount on the stage 1
johnung4528.00 |
11-26-2021, 11:58 AM | #15 | |
Rep 5,393
Dorch Stage1 supports up to 530hp on 93 Octane (E10) while Dorch Stage2 supports up to 650hp. (500hp on E85) You would need a big turbo upgrade to require a Dorch Lift Kit. |
F30IDR7.00 |
11-28-2021, 07:48 PM | #16 | |
Rep 419
johnung4528.00 |
11-29-2021, 02:42 PM | #17 | |
Rep 7,602
Also, i have no idea what you mean about your e mixture dwindling at half a tank, the E% in your tank should be basically constant between fillups unless you had significant separation between the ethanol and gasoline in your tank which should not happen, especially if the car doesnt sit for extended periods of time without being driven. |
11-29-2021, 02:57 PM | #18 | |
Rep 419
11-29-2021, 05:18 PM | #21 |
Rep 190,775
11-29-2021, 06:27 PM | #22 | ||
Rep 5,393
