03-04-2020, 09:40 AM | #507 |
Cheapskate
4445
Rep 4,993
For things like that, I'd recommend either reflashing the tune or reset adaptations to speed up the learning process.
03-04-2020, 09:47 AM | #508 |
Rep 163
03-04-2020, 10:30 AM | #509 |
Cheapskate
4445
Rep 4,993
Gotcha. Yeah it shouldn't take that long. Just keep an eye on it, there could be a lot of factors that play into it. Make sure all of your coilpacks are pushed down all the way, your intake filter isn't dirty, etc etc etc.
03-04-2020, 11:38 AM | #510 |
Rep 39
Hi, just installed 300 cell catted HJS DP + bm3 OTS stage 2 93
http://www.bootmod3.net/log?id=5e5e76c7d10b433a8b85af8f What you think ? Why boost is dropping 1 psi in after 6000 rpm ? It was more consistent in this range in stage 1 ... (http://www.bootmod3.net/log?id=5e303d58c090c621b75e2af1) |
03-04-2020, 01:57 PM | #511 | |
Rep 151
Red - second link. Boost profile is identical after 4000RPM. You got some major throttle closure due to overload at 3000RPM that occured due overboost. It's also strange too see exact same AFR, load and timing profile both in stage 1 and 2. Maybe the only difference between these maps is the requested load in mid RPM range? Or these logs are made on the same map?
Kirill @ OdinTuned
03-04-2020, 03:36 PM | #512 | |
Rep 39
1st link: bm3 OTS Stage 2 93 octane map 2nd link: bm3 OTS Stage 1 93 octane map Are those numbers satisfying for a stage 2 with catted DP? PS : What's this software to make the charts? Thanks! |
03-04-2020, 07:15 PM | #513 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
03-05-2020, 12:55 AM | #514 | ||
Rep 151
OTS maps are not editable, so I can't tell if that equality is normal. I would expect any generic Stage 2 map to have a just bit more timing advance through all RPM range, more boost and richer AFRs than Stage 1 to use an advantage of a high flow downpipe. The software is LogViewer from EpifanSoftware. My version is embedded in a MazdaEdit suite which I use to tune MPS / Mazdaspeed vehicles.
Kirill @ OdinTuned
03-05-2020, 04:40 AM | #515 | |
Cheapskate
4445
Rep 4,993
I've had similar experience on prev cars. I don't understand why the downpipe would be a limiting factor in how much boost you can make. It should react similar to an intake. It allows your powerband to be wider. |
03-05-2020, 06:10 AM | #516 | ||
Rep 151
Kirill @ OdinTuned
boosted116.00 |
03-05-2020, 02:57 PM | #517 |
Rep 198
Low boost?
Thoughts on why boost level is so low? Timing is higher than normal.
https://datazap.me/u/instigatorx/log-1583436729 https://datazap.me/u/instigatorx/log-1583436851 MHD ST1 v3.0 + xHP ST2 on 2018 440i. Fuel = 93/E10 with 2 gals of E85 (really E75)...E18-ish. |
03-05-2020, 09:12 PM | #518 | |
Cheapskate
4445
Rep 4,993
03-05-2020, 09:36 PM | #519 | |
Rep 585
If you look at the Load Target to Load Actual and Boost Target the car is getting exactly what the DME is asking Timing is high because Load is low, normal
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
InstigatorX58.00 kern4174445.00 |
03-05-2020, 11:00 PM | #520 | ||
Rep 198
Thx! |
03-06-2020, 02:50 AM | #521 |
Rep 30
I got my first logging runs in this evening, and I was a little surprised by the timing correction since I at least wasn't expecting it to pull any in the Stage 1 run. Not sure if that's normal/expected or above average, and how to fix it if it's higher than it should be.
MHD Stage 1: https://datazap.me/u/isoleucine/2017...hd-stage-1-3-5 MHD Stage 2: https://datazap.me/u/isoleucine/2017...hd-stage-2-3-6 I've daily-driven the car with either tune in the past and they both feel nice and smooth, just want to make sure there aren't issues I'm overlooking. Wish I could find a 93 octane pump somewhere nearby, but sadly everything here is all only 91. |
03-06-2020, 04:48 AM | #522 | |
Rep 501
your wgdc is sky high, you probably have boost leak
03-06-2020, 05:44 AM | #523 | |
Rep 585
Check out the ambient pressure, very low, high altitude? May explain the relatively high WGDC to achieve the load target.
03-06-2020, 06:36 AM | #524 | |
Rep 585
The power and torque figures here are low because you did the runs both uphill as noted in your log files.
03-06-2020, 01:09 PM | #525 | |
Rep 30
I do actually have access to E85 about 2 minutes away, but I haven't attempted any mixes yet. Is it possible to run an E30 mix with a stock vehicle (cats + fuel filter), and if so are you able to get enough fuel delivered to get noticeable improvements? It seems worthwhile to use just a little as an octane booster regardless, just wondering if it's worth switching to an E30 tune. |
03-06-2020, 03:06 PM | #526 | |
Rep 585
You will struggle with adding much E85 on the BM3 OTS tunes because they load up the boost around 3000 RPM, typically 18 - 19 PSI, and the high pressure fuel pump being cam based won't be able to maintain enough pressure in the fuel rail. MHD limits low RPM boost to about 16 PSI around 3000 RPM, then ramps up from 5000 RPM towards redline. Their E30 OTS maps tend to have even lower initial boost and leaner AFR to 4500 RPM to also assist the HPFP. I have a completely stock M140i and have been running E30 daily for over 7 months combined with MHD Stage 2 95_102 OTS. For consistency I take 4 x 20L plastic fuel containers to my station and add 13 liters of good quality 93 and 7 liters of E85 to each. If your E85 is actually 85% ethanol this results in E30. If it's 60% ethanol e.g. winter blend you'll end up with an E20 mix which will still give you very nice gains. With E30 and MHD Stage 2 95_102 you'll have about 430 - 440 WHP at lower altitude. I run consistent 11.5@121mph at a drag strip inland a bit with a 2000ft DA. Once you try it you'll find it very hard to go back to regular gas.
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph Last edited by OzBMR; 03-06-2020 at 04:18 PM.. |
03-06-2020, 03:36 PM | #527 |
Rep 30
That's great to hear. I know MHD actually has E30 maps directly that I'll probably try first, but otherwise I can simply run the higher octane maps with a little less E85. I know I'm a bit lucky because the local E85 station has been tested by other car folks and found to be solid year round, so that's a plus as well.
I'll have to fill it up with the Ethanol blend shortly and test again on the E30 map, hopefully with similar results to yours. The Virtual Dyno numbers for Stage 1 & 2 with stock cats/filter already pleasantly surprised me given the lower octane fuel here, but I'll never say no to additional power! |
03-06-2020, 03:46 PM | #528 | |
Rep 585
