03-12-2018, 07:39 PM | #1057 |
(Incoming) G80 M3Cx
250
Rep 516
My car is in for the MPPSK and after someone mentioned EBT I've realised this may be the reason they are unable to do the programming they're attempting.
My issue is the car is not with me so I'm not sure if I've written the modified FA to the car. If I haven't, I believe I should simply read the FA off the car and then code the HU_NBT ecu to reset the VO coding I did for EBT. Is this right? What would I do if I have written the modified FA to the car though? |
03-12-2018, 07:44 PM | #1058 | |
Rep 32,881
If you’ve written the modified FA to the car then you need to write the original FA to it now. |
03-12-2018, 08:02 PM | #1059 | ||
(Incoming) G80 M3Cx
250
Rep 516
How do I write the original FA to the car if I haven't saved it anywhere? I followed the guide that had the instructions to do the coding so I may have that saved somewhere but my question is, what do I do if it's not saved? Can I just change back to 6NS on the car FA to solve the problem? Or does it need more than this? All I've done is code EBT and some other FDL stuff. |
03-12-2018, 08:05 PM | #1060 | |
Rep 32,881
M3anLantern249.50 |
03-13-2018, 02:56 AM | #1061 |
Rep 1,201
Or you can blag it out.
I had the same issue with a modified FA. The dealer just coded it back to factory. To be accurate they did say what the issue was but never asked if I either knew about it or had done it. I just kept my mouth shut I think the bigger pictures is, the fitting of the MPPSK is business to them and they're not likely to turn away the fitting business just because "computer says no". Maybe a different story under a diagnostic scenario.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
03-13-2018, 03:25 AM | #1062 | |
(Incoming) G80 M3Cx
250
Rep 516
I'm not too keen on waiting forever if they can't figure out what's wrong! |
03-13-2018, 08:06 AM | #1063 | |
Rep 1,201
I suspect they flash all the ECU's, for the time it took them to sort my car (over 8 hours) and it's a flash not just coding. I know they left my car over night doing it's update. That could add significant time to the diagnostic if they don't immediately suspect the FA is not correct.
03-13-2018, 10:28 AM | #1064 | ||
(Incoming) G80 M3Cx
250
Rep 516
03-15-2018, 06:42 AM | #1065 |
Rep 1,909
Guys I had EBT coded unfortunately my units getting replaced today, is there a chance ill have EBT or will I need to code again?
Happy Motoring
Evdok |
03-15-2018, 06:44 AM | #1066 |
Rep 40,768
You will need to recode it.
evdok819.00 |
03-16-2018, 04:23 PM | #1067 |
Rep 1,909
Had unit replaced & I still have 2 phone option as well as audio option , have I been lucky to get a better unit with this option?
Happy Motoring
Evdok |
03-16-2018, 06:56 PM | #1068 |
Rep 1,201
Bonus
03-16-2018, 07:01 PM | #1069 |
Rep 1,909
Anyone got part number for the lower trim with the hole for the USB plug, bloody website doing me head in.....leather this and that....
Happy Motoring
Evdok |
03-17-2018, 02:36 AM | #1070 | |
Rep 10,473
51459393650 http://www.realoem.com/bmw/enUS/show...76#51459393650 |
evdok819.00 |
04-01-2018, 04:43 PM | #1072 |
Rep 32,881
04-01-2018, 04:53 PM | #1073 |
Rep 40,768
Only if car has a standalone Combox.
04-02-2018, 08:28 PM | #1074 |
Rep 2
3AG Reverse camera not in FA
I had a reverse camera fitted, it works like an OEM but was a cheaper version with some sort of activation box.
Since then I've bought a a lead, downloaded esys, and managed to change a few settings. I cant find 3AG in my FA so I guess the installer did it without writing modified FA to the car. Where, (which modules) I can find the changes you would make to activate a non OEM camera? I've ordered an chinaclone SLI and when I code that I may loose my reverse camera. I'm happy to redo the changes I've made but I don't know what was done to enable the Reverse camera. Any Ideas? Or is there a way of enabling the Speed Limit Info (8TH) without having to overwrite my existing files with VO coding ? Thanks Last edited by rk330e; 04-02-2018 at 08:34 PM.. |
04-02-2018, 09:04 PM | #1075 | |
Rep 40,768
OEM Backup Camera would be a TRSVC Module, but since you have non-OEM version, you do not have this ECU. I have no idea how non-OEM version is coded.
04-03-2018, 02:14 AM | #1076 |
Rep 637
You could:
1) Backup all your CAFD files to a folder 2) VO code all the modules 3) Backup the modules again to another folder 4) Compare the backups using TokenMaster's NCD/CAFD tool That way, you know what settings to put back, either when you do some coding or when the garage inevitably updates the software for some random reason when you take the car in. Note, if the software does get updated, you have to make the changes to the new files and not just restore the old files. |
04-03-2018, 08:20 AM | #1077 | |
Rep 1,201
I wouldn't do it to every module and I wouldn't VO code them all either. Most of them are nothing to do with the rear view camera.
04-03-2018, 10:11 AM | #1078 |
Rep 637
The problem is the "default" settings depend upon the car build date and options present.
I agree not every module would need to be done, mine needed HU_NBT (HU_xxx ), TRSVC (if present), FEM (Front PDC), REM (Rear PDC) and ICM (for control and buttons) as they are the ones potentially with settings changed for the camera and control buttons. |
