04-11-2021, 05:07 PM | #1 |
Rep 1,199
I test drove a 340i with M Adaptive suspension and a 440i with M sport suspension today. The 340i bounced after speed humps which is a sign of worn shocks. It only had 30k miles on it. The 440i with 6k miles reacted as expected and compressed once then settled. The 340i was like an old Cadillac. It felt ok in turns but I didn't drive it hard on a test drive.
Is this just the active suspension trying to be soft or is something wrong? I would like to go drive another car with the M Active suspension for comparison but also want opinions here.
04-11-2021, 05:20 PM | #2 | |
Rep 710
I have an adaptive and comfort mode is shit, sport mode really tightens it up. Dinan shocks + bump stops + shockware (all made specifically for the adaptive suspension), is an amazing and fairly cheap improvement for the suspension. Drastically improved the handling, bouncing, and body roll. |
04-11-2021, 05:25 PM | #3 | |
Rep 1,199
My judgement was a little compromised during the 340 sport vs comfort experiment though because the sales guy was fairly adamant it did not have adaptive suspension. It 100% did though. I noticed the difference then decoded the VIN to check. The only way to figure this car out may be to drive another 340i adaptive over the same bumps at my townhosue.
04-11-2021, 05:39 PM | #4 | ||
Rep 710
04-11-2021, 06:03 PM | #5 | |
Rep 1,199
04-11-2021, 06:26 PM | #6 | ||
Rep 710
Something seems weird imo |
04-11-2021, 06:38 PM | #7 | |
Rep 327
It wouldn't be abundantly evident unless you were looking at the struts themselves though. |
AllaVodka634.00 |
04-11-2021, 08:51 PM | #8 |
Rep 1,199
Yeah adaptive was DEFINITELY available without the THP. I just drove a 440 GC with adaptive and it did the exact same thing over speed bumps. It seems to just be how the active suspension acts at low speeds. At least it's normal. I'm buying the car right now hahaha this one is Estoril Blue and it's amazing.
AllaVodka634.00 |
04-12-2021, 02:36 AM | #9 | |
Rep 3,408
I put it on my M-sport with adaptive and changed everything for the better. Comfort went from horrible to brilliant. Sport went from bouncy to tight and perfect. Think about ditching run flats too once they wear out. Dinan Shockware and go flat tires are a great choice before you start spending money on suspension changes. Good luck! |
jnj2455367.50 |
04-12-2021, 03:02 AM | #10 | ||
Rep 3,878
In general - Adaptive M is softer than M Sport in "Comfort", and stiffer than M Sport in "Sport". That's the whole point... versatility. And it is brilliant IMO.
04-12-2021, 06:54 AM | #11 |
Rep 844
I have the adaptive suspension and agree with your initial thoughts. It's floaty compared to other suspensions. And it does wear out quickly. Had both of my fronts changed under warranty around 45k because of noise/excessive play. Obviously the same happened to the rear after the warranty expired. I think it's a case of jack of all trades, master of none. It tries to be able to do too many things and so it does none of them at the level you would expect from BMW.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
04-12-2021, 08:02 AM | #12 |
Rep 849
Drives: BMW 435i
I've not driven a 704 equipped car, but every F3X car I've driven, both pre- and post-LCI was too bouncy for my taste in comfort.
I really didn't like the standard suspension for either AWD or RWD. The M Adaptive improves both drive platforms, but like already mentioned it still has a tendency to porpoise on bumpy roads when in comfort mode. I haven't driven a pre- and post- LCI back-to-back to feel the difference. I actually drove in them in reverse order: Post-LCI a year or two before my pre-LCI car. I do remember not being very impressed with either one in comfort. Running in sport mode helps a great deal and on my pre-LCI car, the Shockware upgrade on it's own (just the flash and no other suspension bits) was a huge improvement in both comfort and sport mode.
04-12-2021, 08:52 AM | #13 | |
Rep 327
I'd say the post LCI is certainly better but I went from a AWD/Luxury Line/non-2VF to RWD/MSport/2VF so I'd hope it would certainly feel better. When I moved on from my GTI, I did get this strong sense that my 440i was a substantially heavier/number car but now I've just gotten used to it |
04-12-2021, 08:56 AM | #14 | ||
Rep 710
Desertnate390.50 |
04-12-2021, 08:58 AM | #15 | |
Rep 327
04-12-2021, 09:31 AM | #16 | ||
Rep 710
I was worried it would be more harsh on shitty roads, but it actually improved the driving experience and at times I feel potholes less because theres less bounce. It drives less like a boat now. Only issue, is because its a little lower, its easier bottom out of parking lots if your not careful. But thats any sports oriented car |
