11-23-2016, 08:31 AM | #23 | ||
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
With meth JB4 and a DP terry put down 458rwhp on a B58! That's awesome. He discussed in detail how BMW really restricted fueling in this car, so at this point the pumps are the choke point. No more wiggle room like N54 or N55.
FBO-PS1 and stuff
11-23-2016, 08:33 AM | #24 |
Dejan
1755
Rep 4,197
This ^ fueling is key on the b58. I believe Terry just slightly revised map 2 but it doesn't put out more boost. Not sure it's even worth it at this point.
FBO-PS1 and stuff
11-23-2016, 01:39 PM | #25 | |
Rep 498
Torco and other octane boosters beat the living sh*t out of your plugs. I would recommend pulling a plug every 2500 miles or less to take a look. The plugs get all pitted and worn very quickly because of the additives in the octane booster. The best thing to do if you guys have it locally, is find a station with 100 octane and buy 5-10- 5 gallon fuel jugs from summit racing and mix 5 gallons of 100 with 10 gallons of 93. Either that or buy a meth injection kit. Meth injection has been around for decades now, and it is one of the least harmful things you can do to your car, if anything meth injection will prolong an engines life, it keeps the combustion chamber and piston crowns and ring lands MUCH cooler which is one of the main reasons it creates more powerand allows more boost, timing or both . A properly running meth/water injection system with the passive safety of a product such as a JB4 with the auto tune feature as a safety net, has absolutely no risk of hurting anything in the motor. Like anything else in your car, you always want to check everything out every 500-1000 miles on your car. (tire pressure, washer fluid, leaks,) you would just add inspecing the meth tank, pump and nozzles, which takes all of 5 minutes max. I went on a bit of a tangent here but avoid torco or any other octane booster at all costs. That's my point here. LOL |
11-23-2016, 02:37 PM | #26 | |
Rep 402
11-29-2016, 06:49 AM | #27 |
Rep 1,407
thanks carguy!!!
Diligentia Vis Celeritas
11-29-2016, 12:05 PM | #29 | ||
Team Zissou
3082
Rep 10,198
11-29-2016, 12:21 PM | #30 | |||
Dejan
1755
Rep 4,197
If it's indeed what he discovered and flash can bypass I enthusiastically stand corrected as I would love to get this dme cracked as well and it would be so convenient and easy to flash fix fueling choke point. Mind you this was earlier on in his b58 tuning process on his car. If he indeed did discover that it's flash related and the choke point can be lifted this is still a case of don't hold your breath, it'll be a while before the new dme is cracked. So basically fuel = choke point pick your poison, install new LPFP AND HPFP or hope flash can fix it. Note he said he HOPES that's the case. So still uncharted waters. And now there's a revised map 2 but runs less boost.
FBO-PS1 and stuff
11-29-2016, 12:36 PM | #31 | |
The Wolf
256
Rep 991
Drives: stuff
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
11-29-2016, 03:57 PM | #33 |
Dejan
1755
Rep 4,197
Yes sir exactly get that party started.
FBO-PS1 and stuff
11-29-2016, 03:59 PM | #34 | ||
Dejan
1755
Rep 4,197
The thing is when and it's only a matter of time of cracking it what wall will you hit with the LPFP and HPFP...when trying to make 17-18psi on the OEM turbo... We have see it on the N55 early and that wasn't software limited so we'll have to wait and see. How long is the question..
FBO-PS1 and stuff
11-30-2016, 11:16 AM | #35 |
Rep 548
Drives: 2011 E90 M3 ZCP
IMO, the software IPW cap is insurance for BMW. It buys them time so people don't start blowing up their B58's left and right. Once the DME is cracked, then all bets are off. They obviously know about the JB4, and then engine is clearly strong and can handle more boost. It's probably safe all day to run with the JB4, but only at the limit of the IPW. I feel like things might start getting sketchy once it's cracked and the boost gets turned up even more.
12-01-2016, 02:52 AM | #37 |
The Wolf
256
Rep 991
Drives: stuff
Has anyone on this new revision noticed when you set default boost safety to 20 it reverts to 28.4 and no matter what I do, when I save tmap as 0 like it should be it always reverts to 1 or n20/3.5bar... b58 tmap is 2.5bar
Surely this isn't right. Win10 laptop, 5/18/2016 jb4 interface usb connection. |
12-01-2016, 09:03 AM | #38 | |
Rep 116,006
Mike |
12-01-2016, 09:39 AM | #39 |
The Wolf
256
Rep 991
Drives: stuff
I did, just getting the info out there i've reviewed a couple other user's logs that show n20_tmap @ 1 as well, no wonder so many people are complaining lately eh?
12-01-2016, 09:55 AM | #40 |
Rep 548
Please keep us updated with what Terry says. I haven't updated yet and will hold off until this issue is resolved.
12-01-2016, 10:17 AM | #41 |
The Wolf
256
Rep 991
Drives: stuff
can someone email me version 3 hex?
12-01-2016, 10:59 AM | #42 |
The Wolf
256
Rep 991
Drives: stuff
Terry clarified and default settings for rev 4 are now completely different than they were previously as noticed by new settings picture in post 1, head over there and verify your default configs.
12-01-2016, 01:25 PM | #43 |
Rep 548
