BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
European Auto Source (EAS)
      01-03-2015, 09:01 PM   #67
Polo08816
Drives: 2014 335i M Sport
Shawn, would you be able to PM me a link to ediabas?
      01-03-2015, 10:38 PM   #68
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      01-04-2015, 11:24 AM   #69
Manulap92
Manulap92's Avatar
France
Drives: 318 DA Luxury (F30)
I code Kombi all the Time, in many, many cars, and never get CEL error.
You don't get CEL error when coding Kombi , is it because you code Kombi (and all others modules except DDE/DME) with engine running ?
      01-18-2015, 09:26 AM   #70
Lucardos
Drives: F48 X1 192HP MINERAL GREY
Hi shawn,
I also need a link to the latest Tool32. I have some errors after coding.
Is it just F01 that will do the trick in Tools32?
      01-18-2015, 11:37 AM   #71
shawnsheridan
Originally Posted by Lucardos View Post
Hi shawn,
Yes, F01.prg is all you need.
PM sent.
      01-18-2015, 01:06 PM   #72
Lucardos
Hi Swan,
thanks,unfortunately I don't get the errors away.
I accidentally VO coded all ECU instead of only the needed for 3AG.
I now have error Drivetrain and fuel pomp.
any option that I have?
      01-18-2015, 01:20 PM   #73
shawnsheridan
Hi Swan,
Does your DME module have CAFD with Green Dot?
      01-19-2015, 12:37 AM   #74
Lucardos
there's no green dot. it seems that I'm missing the CAFD.
How can I solve this?
      01-19-2015, 05:51 AM   #75
shawnsheridan
I suspected as much. You must inject CAFD into DME and then VO Code it.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on DME => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE.
With DME, Motor cannot be running when you code it.
      01-19-2015, 10:07 PM   #76
K320
Puerto Rico
124
Drives: G01-X3 30i MSport
Do i need to buy the token to only do the reset?
      01-19-2015, 10:50 PM   #77
shawnsheridan
You don't need to buy a Token for anything anymore as TokenMaster released free E-Sys Launcher Application with built in Token Generator.
      01-20-2015, 10:07 AM   #78
K320
Puerto Rico
124
Great. I believe i must check my version of esys. Will post info later so i can start checking my car. Thanks shawn.
      01-21-2015, 11:11 PM   #79
K320
Puerto Rico
124
This is the version of e-sys i have:
What else do i need to start the coding?
      01-22-2015, 05:07 AM   #80
shawnsheridan
PSdZData and an ENET Cable to go with E-Sys.
      01-22-2015, 07:14 AM   #81
K320
Puerto Rico
124
Great! Gonna try on weekend and let you know.
Have a great day and thanks or in spanish gracias
      01-26-2015, 02:09 AM   #82
Coolala
Japan
Drives: 2013 F30
Hi Shawn,
Could you send me the download link of latest Ediabas? Actually, I need tool32 for erasing error code. I'm using 32bit Windows. Mine is F20, is it correct for me to select 01.prg or other .prg?
Thanks!
      01-26-2015, 02:11 AM   #83
Coolala
Japan
Drives: 2013 F30
Shawn,
I have another question and I'm sorry that I have so many questions.
I found you mentioned ISTA/D Reingold, which is a diagnostic tool. Do you know where I can get this?
Thanks again!
      01-26-2015, 05:30 AM   #84
shawnsheridan
Originally Posted by Coolala View Post
Hi Shawn,
Thanks!
Shawn,
Thanks again!
Use F01.prg.
PM sent.
      01-26-2015, 04:35 PM   #85
f32_jon
Drives: 19 330i M Sport
PM sent.
Can you please send me the link to EDIABAS too? Thanks!
      01-26-2015, 04:36 PM   #86
shawnsheridan
PM sent.
      01-26-2015, 07:10 PM   #87
Coolala
Japan
Drives: 2013 F30
Use F01.prg.
PM sent.
Cool!
Shawn, you are the best!
      01-27-2015, 09:21 AM   #88
Lucardos
Hi Shawn,
thanks for your help. I was able to fix this problem.
I only have one problem that i don't get away. After coding my rear PDC stopped working. every time i put it in reverse i get error "no parking assistance, have the problem checked by service"
I already have put the old CAFD for Hu-CIC and REM, but the problem remains.
any suggestions?
Lucardos
