BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
      09-25-2018, 02:03 PM   #2465
Tpriest7893
Drives: Bmw 335i f30 N55
So if I buy a license I get one map with purchase? Can I choose what stage map I want when I first buy the $250 license?
-Tods
      09-25-2018, 02:11 PM   #2466
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
The Flasher Module is $249, Monitor Module is $99 and all other map packs are $99 each (stage 1, stage 2 and E-maps)
      09-25-2018, 02:26 PM   #2467
Tpriest7893
What's the monitor module?
-Tods
      09-25-2018, 02:36 PM   #2468
GatorF30
Drives: EBII F30
Exactly what you think it is.
      09-25-2018, 02:54 PM   #2469
Munchi435i
Munchi435i's Avatar
It allows you to do data logging
      09-25-2018, 03:10 PM   #2470
Tpriest7893
Figured lol. I just want a tune and some maps. Been going between bootmod3 and this. But for pride and bang for buck MHD seems the way to go. Just for a fun daily, not trying to make my current daily a race car. Stage 2 would be fun tho
-Tods
      09-26-2018, 12:33 AM   #2471
harkes
harkes's Avatar
China
743
Drives: M135i, NSX and AE86
Any logs with PWG Pure Stg2?
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      09-26-2018, 02:34 AM   #2472
Beemmer
Drives: crashed e93
Yo I got logs of PS2 on 91 Oct crap fuel? Can check them out?
      09-26-2018, 04:14 AM   #2473
harkes
harkes's Avatar
China
743
Yes, I'd love to see them. Email/PM/or just here in the forum
harkes@gmail.com
(A Dane in China)
      09-26-2018, 04:18 AM   #2474
SeanWRT
SeanWRT's Avatar
2510
Drives: E90 M3 & F87 M2
? MHD Flasher F Series (F2x F3x) discussion ?
Let me give you my perspective too
sean.gao@spx.com
Lemania 2320
      09-26-2018, 10:41 AM   #2475
Momir@MHD
MHD Tuning
Momir@MHD's Avatar
Drives: BMW 1M Coupé
Originally Posted by MiniNL View Post
Also, isn't the exhaust flap always open in sport mode? When turning this off, does it mean that the exhaust flap is closed in sport mode and when turned on, it's open? Or is it default behavior when off and alway open when in sport.
Thanks.
Originally Posted by GatorF30 View Post
The flap is not always open in Sport mode. It closes at idle and low RPMs. It only comes on when you get on the car.
Stock its open in standstill on mppk and m performance car and closes automatically at around 20kph on every car (under WOT it opens automatically in every mode even stock)
Originally Posted by Mountain_Commando View Post
Yes sorry, I meant I'm currently running the 98RON map, and wonder if upping to the 102RON map will make any noticeable difference.
Around 10-15HP
Originally Posted by FastF30 View Post
Ran the new map 95 octane... I'm in the city and could only run upto around 70 which is mid 3rd.... overall comparing to my old log run on 93 timing is basically doubled. boost up a lb or 2... "torque act. clutch nm" is up about 20nm's on average... timing was holding with little correction but still might mix a little more boostane to see if we can do better... I know this isn't an exact comparison for the logs but good enough for now... Overall very happy...
what is this new tag "boost target ex psi" on the data log?
boost target ex is for cars running more than 22.xPSI, the standard bmw logging channels can only show up to 22.xPSI boost target. For custom tuners this is a big achievement.
Originally Posted by F32/435i View Post
Flashed updated Stage 2+....anyone notice a change in idle now. It was so smooth and consistent with the Beta map.
First startup after flash is always rough - adaptions need to be relearned, this should be gone quickly.
Originally Posted by rogerdiaz View Post
Wanting to know same info. I got a N55 2015 335i. Interested in the Stage 1 only. I'm scared to have things start breaking on me.
The cars are very reliable and have strong internals. We recommend getting a aluminum chargepipe because the stock one tend to break under higher boost (and sometimes even on stock boost).
Thank you for choosing MHD - new and very nice updates will follow soon!
      09-26-2018, 11:01 AM   #2476
rbol13
Drives: 2014 335i M Sport
I will be getting a battery charger but just trying to get clarification...
In the manual for install it says you can brick your DME during the install if you lose voltage.
In post 2290 the poster is talking about the install and you say you cant brick on a flash.
So bricking is possible during install but not flash is correct? New to this stuff, it's not my lane. Thanks!
      09-26-2018, 11:11 AM   #2477
Momir@MHD
MHD Tuning
Momir@MHD's Avatar
Customer Dynorun - M235i 8 Speed AT, High Flow Downpipe, Wagner Evo 2 FMIC, Charge & Boostpipe, Aral 102 Ultimate Pump Gas.
M2481.50
ABPReader207.00
      09-26-2018, 11:13 AM   #2478
Momir@MHD
MHD Tuning
Momir@MHD's Avatar
You can not brick but if the flash fails the car can not be started. You need to charge up the battery and then reflash the car.
      09-26-2018, 11:20 AM   #2479
rbol13
Awesome, thanks again
      09-26-2018, 11:27 AM   #2480
_lkk
Drives: x4 35i
My x4 35i is the fourth car with n5x, 2 n54 and n55.
On all I tried all tuning (all versions of the Procede, jb and now I used dinan..before moving to MHD).
Now with MHD I'm happy, everything is perfect.
I use Stage1 95Ron because here I have only this fuel available.
I have only 2 notes:
-The first is unimportant: sports displays remain standard and mark incorrect values. Will there be a fix?
-Second, the thrust is excellent up to 5500g / m then it is a bit weak. Is it for 95RON?
My car is stock with only sporty air filter and performance exhaust; is it very unwise to use the stage2 map?
L.
      09-26-2018, 12:04 PM   #2481
FastF30
FastF30's Avatar
288
Hey MHD... Love the product... what exactly is "torque act. clutch nm" on the logging chart... Can this be used for any evaluation of engine performance... Thanks in advance..
      09-26-2018, 01:40 PM   #2482
valve float
Drives: 335i
whoa...just loaded 3rd/6th gear tq limit fix beta maps...3/4 exxtra psi in midrange is magical...haha...car is now quick to 100...goin porsche hunting tonite...lol
      09-26-2018, 03:13 PM   #2483
f32_027
Driver
f32_027's Avatar
Drives: 435i
So I've downloaded and flashed the newest version...
With the newest map, does the gear tq limit fix you mention occur automatically (because of the update)?
OR, are we supposed to adjust the torque limiters? If so, based on what?
Currently, I believe mine are just at 100% for all gears.
      09-27-2018, 11:13 AM   #2484
jaypayne05
Drives: 435i Gran Coupe M Package
Not to be off topic But I wanted to know if anyone is running a high flow cath and what brand are you using?
      09-27-2018, 01:33 PM   #2485
thug108
Drives: f30 335 xdrive m sport
2013 335  [0.00]
running a challenge HFC
      09-27-2018, 02:13 PM   #2486
Seba77W
Seba77W's Avatar
292
Drives: BMW 435i Xdrive Coupe
Running a Fabspeed high flow catted dp on my 435i since 08/2017. Not ever a CEL and passed IL state emissions as well.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
flash, mhd, tune
