06-23-2021, 08:29 PM | #420 |
Rep 25
Hi guys, Im thinking to do an HPFP upgrade - but I live in Indonesia where the octane rating is bad and we dont have ethanol at all at gas station.
Im currently running an OTS BM3 91Oct; do you think with an HPFP upgrade the power gain will be worth it if I were to stick to the 91Oct tune? Any inputs will be greatly appreciate, thanks!! |
06-23-2021, 08:34 PM | #421 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
b7ff14.00 |
06-25-2021, 10:17 AM | #422 |
Rep 164
07-04-2021, 10:29 AM | #423 |
Rep 75
Alright, so I've read through all of this (and likewise have previously posted in the thread).
If I'm on a stock turbo with MHD Stage 2, it sounds like I can upgrade to Dorsch Stage 2 (to later upgrade a turbo in the future) and just select the setting in the MHD app for the Dorsch HPFP) so that the car can run properly. Is that right? Or do I need a completely different tune for this? |
07-05-2021, 06:31 AM | #425 | |
Cheapskate
4447
Rep 4,993
07-05-2021, 11:28 AM | #426 |
Rep 75
07-05-2021, 04:59 PM | #427 |
Rep 282
again yes and no
or yes you can use the pump if you check the option . No you dont need a tune to run an aftermarket hpfp . its just a electronic controlled mechanical device to supply fuel at a certain pressure into the rail .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
07-19-2021, 11:02 AM | #428 |
Rep 5
Does anyone have experience with Deatschwerks DW440 pump?
It's a brushless pump that is advertised as having B58 Supra compatibility. I purchased one and it looks to be the same physical size as the pump and same connector that came in the fuel bucket core that I purchased. |
07-19-2021, 01:03 PM | #429 | |
Rep 216
kern4174446.50 |
07-19-2021, 09:36 PM | #430 |
Rep 5
Thanks for the reply. Sorry I didn't clarify I I have a dorch stage 2 pump and wanted to run full e85. I was just wondering if the stock lpfp would limit me in some way.
07-20-2021, 06:49 AM | #431 |
Rep 216
If you're on stock turbo than no not yet, but check your logs when under full throttle and high rpm if your fuel pressure on the low side is dropping than yes and upgrade is needed
07-20-2021, 10:44 AM | #432 |
Cheapskate
4447
Rep 4,993
Rule of thumb is if you don't need port injection then you probably don't need a LPFP. It seems to flow more than a stage 2 pump for most setups.
07-30-2021, 12:38 PM | #433 |
Cheapskate
4447
Rep 4,993
I made a video discussing why some hpfp upgrades need custom settings. Hope this helps.
07-31-2021, 05:16 AM | #434 |
Rep 122
Just wondering, does anybody now the difference between the old and new calibration for the Dorch HPFP in BM3? And when you should use which calibration?
Thanks!
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
08-01-2021, 03:52 PM | #435 |
Cheapskate
4447
Rep 4,993
Always use the new
Uni-Rapide71.00 |
08-02-2021, 12:15 PM | #436 |
Rep 216
If I remember right old calibration was for aftermarket fuel pump but the new calibration separates stage 1 and stage 2
Uni-Rapide71.00 |
09-14-2021, 07:00 PM | #437 |
Rep 780
Found a good price TU pump online so I have been thinking about getting a TU pump upgrade this few days.
1. How is the reliability of the stock HPFP? I can't seem to find much reports of it failing prematurely. I'm curious to see how long they last. 2. I think I wont be running E30 blends anytime soon as my 440i is a daily drive. Will i see much gains with TU pump on MHD stage 2 map?
2020 BMW G07 X7 3.0d M Sport
2018 Audi FY Audi SQ5 2016 BMW F36 440i GC M Sport |
09-15-2021, 07:50 PM | #439 |
Rep 780
Thx for reply. Looks like the factory pump are pretty reliable too?
09-16-2021, 09:57 AM | #440 | |
Cheapskate
4447
Rep 4,993
You need to flash the stage 2+ map to access the extra hp that's supported by the TU pump. Running the same stage 1/2 map will not net any gains because the pump itself doesn't change anything. |
