11-06-2020, 02:30 AM | #67 |
Rep 25,113
Thanks flashollie along with the running it's the area I've made most 'gains'. I'm lucky/unlucky :/
- I seem to either pick up weight or add muscle quite quickly. Is that Endomorphic ? It's both annoying and a blessing depending. I guess also means I eat a bit!! - Already had the home gym set up. - I started a series of PT twice a week just before lockdown. It's with a guy I've worked with before so he knows my limits, strengths and how to push me. As you move to video this is key as it must be so difficult to convery technique to people - Phase 1 As above my PT has set the programme for me and I would have ever come up with it myself. We cycle a 4 week programme, starts with weights in metabolic workout. In this I might be benching about 60% Max weight for a 12-15 reps, the no rest and straight into a trice or other exercise. This is lactic acid and strength. Each session in the week is based on push, or pull, legs or shoulders. I supplement this with my own running or cycling. - Phase 2 this phase usually always in some way scares me so what as we go heavy. Reps alcove right down to sets of and jts 5 sets. Often it's a weight I think I can only do 3 reps at. There's a lot of rest between sets and on video it's a lot of chat. Usual runs in-between etc and I now will have a Yoga and core day - Phase 3 is really just a week. In this it's 'ok' to attempt some kind of Max effort . Just like I have done with the Pull Ups there, it's vital this is after the heavy load lifting. I like this week, feel like it's payout time!! . Finishes with a bit of a e load week. This again is something on my own I would never have done. The above has never actually been spelled out to me but I see the cycles happening....and for my needs at least it works well. In each week I also have. HIT session to keep weight down as my needs are overall CrossFit, if your needs are strength alone you would likely not use this. Ok I'll conclude, long ramble there sorry, hopefully something was useful. Too may type errors to check 1) Future proof yourself and get your own kit. Might as well and it in theory will last forever, I don't see my Kettlebells ever losing weight or going out of fashion 2) Try to get some PT but to be meaningful, IMO you need 3-6 months to learn and find a way to replicate it yourself Traditionally I've been terrible and kept almost the same routine
My car made front page of Bimmerpost
KRS_SN13515.00 |
11-08-2020, 02:54 AM | #68 | |
Rep 565
As I'm starting from scratch and I don't have PT on hand I'm going to get through a 4 weeek rotation of my sets with the exercise know well. I understand that and have the kit for it. Once I get some base strength I'll repeat that set structure with either some more weights or I can alter some of the exercises. There are numerous good demos on line. I like your suggestion to video yourself to confirm that the form is accurate. Then Ill try some of the sessions you mention. |
JustChris17487.50 |
11-08-2020, 04:04 AM | #69 | ||
Rep 25,113
One quick concept I grasped really easily and is good science. As you move through the week's, don't always feel you have to 'up the weight' There are a few ways to make the same weight more effort. Change tempo - this is my favourite explosive rep of the effort phase 1count and the down 5count. Give you a nice longer load under tension. Very very produxtiive. Less Rest between sets. Benefits endurance. More reps. So rather than 6-10 for hypertrophy around for strength / endurance 12-15. Just any variety breaks up a routine keeps you fresh and stops the body getting used to effort.
KRS_SN13515.00 flashollie178.50 |
11-08-2020, 06:35 AM | #70 | ||
Rep 121
11-09-2020, 01:22 PM | #71 |
Rep 3,216
After feeling a bit under the weather on Friday, Saturday was viewed as a rest day.
Sunday was back on the rower, for probably one of my most loved (and hated !) workouts. It's a preset interval programme, which involves the following : 5 min warmup, then some stretches 1 min hard, 1 min easy 2 min hard, 2 min easy 3,3 4,4 3,3 2,2 1,1 Target pace for the intervals was anything under 1:57. Ended up averaging 1:55.8 - felt hard, and I wasn't sure if I could hold that, with feeling crappy and having an elevated HR the 2 days before This evening I put on the headtorch and trail shoes, and went out for a little run - only 2.6 miles, mix of tarmac, forest tracks and muddy paths, with the added entertainment of 400ft of climb in there too! Averaged 10:27 per mile, which I wasn't disappointed with |
JustChris17487.50 |
11-09-2020, 01:58 PM | #72 | |
Rep 25,113
robbiep1982.50 |
11-10-2020, 11:41 AM | #73 | |
Rep 669
30 Minutes Steady State Row Every 3 minutes get off the rower and perform 5 pull ups and 10 press ups. |
robbiep1982.50 |
11-10-2020, 12:05 PM | #74 | |
Rep 4,229
Apparently they felt they couldn't keep our gym open whilst closing down and ticketing public gyms. I guess they have a point.. |
11-10-2020, 12:14 PM | #75 | ||
Rep 25,113
I used to do a warm up one with the C2 set to display the calorific effort rate:- First minute 100-199 Calorie rowing 2nd 200-299 3rd 300-399 .. etc keep going up by 100C a minute 10th 1000-1099 calorie rate 15th 1500-1599 You keep going until you hit 3 strokes outside the range. Basically a psychotic ladder that you intend to end at Max effort failure. The start is painfully slow up to about 700Cals.
robbiep1982.50 |
11-10-2020, 12:38 PM | #76 |
Rep 3,216
While most of my rowing is LSD (long slow distance, rather than something that gets you tripping), I do like to test myself on the short sprint pieces occasionally.
Today was the turn of the 100m. The rule is you must start it from a static flywheel - which means that it's an absolute pig of a thing to get going up to speed, but you've got to do that in the first 2 strokes, otherwise any chance of a decent time is gone. A decent warm up, some stretches, and then time to go for it. Six attempts, the second being the fastest at 17.0 (1:25.1 split time). A PB for me by 0.4 seconds Bear in mind that the world record for the 2000 meter event was rowed at a faster pace than I could do for 100m, they managed a 1:23.8 average split ! |
11-10-2020, 12:39 PM | #77 | |
Rep 3,216
The start is probably even worse than the finish ! |
11-10-2020, 12:46 PM | #78 | ||
Rep 25,113
11-13-2020, 09:15 AM | #80 |
Rep 25,113
Birthday treat from my PT guy!
✅ 5km mountain hike ✅ 12kg body vest ✅ 2x12kg water cans ✅ 20 stopping points each with a 26 reps exercise = 520 Reps ✅ No rest, just the joy of carrying everything up another 500m 😵 Slept well last night 😇😬 1.5hrs and 1800+ calories.
flashollie178.50 |
11-13-2020, 10:48 AM | #81 | |
Rep 3,216
JustChris17487.50 |
11-13-2020, 10:56 AM | #82 |
Rep 25,113
Indeed, you'll know the routes too up at MF, I like the challenge of the steeper Purple route. The Garmin clocks the slopes at 40+ and 50+ degrees
11-15-2020, 04:10 AM | #84 |
Rep 25,113
Looks familiar
11-15-2020, 04:42 AM | #85 |
Rep 1,094
Back in the zone now since the first lockdown , lost 14lb in the last six weeks by cutting out all mid-meal crap. Still minimal cardio , just decent duration dog walking.
Weights are increasing slowly but still not at pre-lockdown levels but are getting there. Final set (of four) on Hammer strength machines , pre-lockdown in brackets: Bench - 100kg (130) Lat pulldowns - 160kg (160) Flys - all plates (all) Upright rows - nearly all plates (all) Triceps single arm - 8 plates (8 -Smiths m/c) Curls single arm - 37.5kg (40) Shoulders 80kg (100) Shrugs 200kg (200) Right shoulder giving me jip so not wanting to push it too much flat bench and shoulder presses as i damaged it years ago and it took me ages to get back to any level of fitness. Anyway off out for breakfast , gym tomorrow to burn off my French Toast / bacon and maple syrup. K Last edited by Kendo67; 11-15-2020 at 04:57 AM.. |
JustChris17487.50 |
11-20-2020, 05:23 AM | #86 |
Rep 1,094
At the gym yesterday and was asked if i wanted to borrow any of the equipment over our impending three week lockdown that starts tonight.
Filled out my requirements and will find out later if my request has been successful once all the tickets have been looked at. Good to see the gym are thinking about their members requirements during LD . K |
12-07-2020, 02:47 PM | #87 |
Rep 3,216
Well, I started this thread with a (just) failure to break 1:30 for the half marathon on the C2 rower
Apologies for the sideways picture, I had another go on Saturday 1:29:38.2 - and average pace of 2:07.4 Only 1.1 seconds / 500m faster than the last time, looks like the continuing training has been paying off ! |
12-07-2020, 04:31 PM | #88 | |
Rep 2,048
We actually got a day outside on rock last weekend too which was cool...polished, worn out limestone on a slightly smeggy and damp day but still, it was climbing outside on rock. Imagine climbing on a bar of soap. Suffice to say I declined leading anything, although my mate led a few E1's that I seconded (and even that felt awkward for the first two routes while I found my head!). |
