BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Disable Parking Sensor Beeping
      06-14-2021, 11:23 AM   #1
davidlunn
Drives: 440i Xdrive
One of my front parking sensors intermittently thinks it's right against an object causing the system to beep rather annoyingly when I'm nowhere near any objects. I realize I can just turn off the sensors but I like using the backup camera and rear sensors. If I could just disable to the beeping then having one sensor stuck showing red on the display really wouldn't bother me. I know I can turn the volume down on IDrive but it's still surprisingly loud.
How can I code out the beeping from the parking sensors completely?
      06-14-2021, 12:44 PM   #2
atzebmw
Drives: Tesla Model 3
For the beeping i have no idea.
But you could completely deactivate the front PDC.
Then the rear PDC and rear camera will still work.
      06-17-2021, 11:26 AM   #3
auburnf30x
auburnf30x's Avatar
435
Drives: 2017 BMW 330i xDrive
I accidentally found a way to stop the PDC beeps in Bimmercode.
Go to Rear Electronic Module => scroll to PDC deactivation during trailer operation
Change from 'Unassigned' to 'Active'.
I tow sometimes and thought it would be a useful feature, but apparently it requires some kind of a sensor that I don't have. Without that sensor, the car just assumes you're towing all the time and disables the PDC. The rear camera still works, but the beeping stops. I can't remember if the little colored squares still showed up or not, but I don't think so.
Note though, once you do this, you'll have to revert to an earlier backup to restore the function. Once coded, 'Active' is the only option under the trailer operation menu, and can't be changed back that way. It also will throw error codes, but won't create any visible warning lights or error messages.
I note that you still want the sensor functions without the beeps, unfortunately that's the only way I know to disable the PDC in any form by coding. I suppose you could unplug the sensors up front, but I'm pretty sure that will result in visible warnings and error messages.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim
      06-17-2021, 03:01 PM   #4
ST3VO
ST3VO's Avatar
England
Drives: F30 330d M Sport LCI
You can code the sensors out completely using eSys or I think Bimmercode. However you may find it's something as simple as something on the sensor, such as wax.
