06-17-2021, 07:52 PM | #1 |
Rep 15
Blown turbo with no code?
My car has about 38k miles and I've had my BM3 for about the last 2k miles. I took it into the dealer for an oil change, and they said for $350 they would change the air and cabin filter. I declined that as I had a BMS intake I had still in the box. Car ran great from the dealer for the 35 minute drive home. I pulled the intake off and put the new one on, and when I went for a drive to see how it sounded, the car made no power.
I got no code, drives smooth as butter but the power meter wouldn't go past 120hp and 200lbft. The dealer called me back at the end of the day to tell me it needs a new turbo and it's going to run about $7k I need to have a little longer conversation with the dealer and ask some questions. Is it normal that there would be no code? Are there any other failure possibilities? Then I need to look into aftermarket options and find someone else to change it out. Any other questions I should be asking? I was up front with the dealer and told them I was running the BM3, but that it had been put back on the stock map. Thanks! |
06-18-2021, 12:40 AM | #2 |
Rep 1,454
Did you put the stock intake back on? Any leaks or cracks in the intake/charge piping?
2022 CT4-V Blackwing 6-speed
06-18-2021, 06:44 AM | #3 | |
Rep 15
Wouldn't a code be thrown if the ECU is requesting X psi and it doesn't see that happen? I struggle with the fact that there is no code coming up. |
06-18-2021, 07:41 AM | #4 |
Rep 844
It's possible during your install something fell into the intake tubing and got sucked into the turbo impellers and destroyed the turbo but yes there would be codes. Any weird noises or other symptoms? Have you tried flashing back to stock? Also bm3 sometimes surprises CELs so that could also be why you aren't seeing any
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
06-19-2021, 06:52 PM | #8 |
Rep 201
If they want $350 to change the air and cabin filter I would not trust them.
Also, even if you do need a new turbo, do something aftermarket for more power at half the cost. |
Chris@VargasTurboTech1933.00 imperfectluck426.50 |
06-19-2021, 06:55 PM | #9 |
Rep 4,876
06-19-2021, 09:13 PM | #10 |
Rep 15
I am going to question it, and I agree with the comments. It seemed lazy to me for the dealer to just say it's a blown turbo. He said they could take it all apart to confirm, but that would be almost as expensive as just replacing the turbo.
As soon as I lost power I put the stock airbox back on and flashed back to stock. The car drove no different in stage 1 than stock mode - just slow. I checked all of the intake connections and everything looked solid. It's certainly possible that something fell into the intake, but it was only off for a quick moment before I put the aftermarket part on. No other symptoms, and the car is just as smooth and quiet as ever. I drove it to work for a week while waiting for a code to pop up with nothing. My wife drove the car and said that while it was "sad" it drove fine otherwise. I would most likely want to upgrade. While I do have the roadster to drive, the 30 day lead time at Pure kinda sucks. I'll have to do some research and see if there are other options. Thanks again all. |
06-19-2021, 11:38 PM | #11 |
Rep 884
The compressor side turbine blew on my old 340i running a JB4 with meth and it did not throw any fault codes even with shards of metal going straight into the engine
2013 335is - sold
2011 335d |
06-20-2021, 05:58 AM | #12 | |
Rep 15
I assumed that because I was only running the off-the-shelf stage 1 BM3 tune with no other mods the turbo would hold up. I'm pretty surprised I only got 2k miles out of it. Now looking at the VTT turbo as an option, they appear to be in stock. |
06-20-2021, 09:31 AM | #13 | ||
Rep 884
2013 335is - sold
2011 335d |
06-22-2021, 07:34 AM | #14 |
Cheapskate
4447
Rep 4,993
This
And no, BM3 doesn't randomly suppress codes. Your best bet is to run a log or look yourself to see if you can diagnose it. Is there smoke coming out of the exhaust? Any weird noises? Usually loss of power after swapping an intake = boost leak or MAF issues, basically tied to the work you did. |
06-22-2021, 10:23 AM | #15 |
Rep 417
There are several documented cases in this forum of codes that didn't show until the car was flashed back to stock.
So it did happen. I don't know how or why, but we can't state that it doesn't.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
06-22-2021, 12:06 PM | #16 |
Cheapskate
4447
Rep 4,993
It doesn't block codes. The only one it can block is ones that are turned on in the tune, like cat efficiency or others you manually turn on. If you flash to stock and have new codes then those are new codes that popped up. Just like Chris said above, sometimes it takes a few drives for codes to pop up.
06-22-2021, 06:20 PM | #17 |
Rep 15
I did change the intake and that certainly could be the exact reason the turbo is dead. I spoke to the service advisor today and he said they are closer to a $5,500 bill to swap the turbo and maybe he could do better.
He said they thought it was odd as well that there were no codes, but that they could still pop up. The advisor I spoke to was very straight forward and understanding. He told me the stuck a scope down but couldn't see any blockage and that the turbo was seized. To fully diagnose it, he told me he would have to take it apart, and that it's pretty certain to need replacement. So! I spoke to a (what seems to be) a good shop that is local to me, Larchmere in Chagrin Falls. I'm going to schedule them to take it apart and likely go with something aftermarket. The car always drove fine, it's just like a switch went off and it had no power. |
07-03-2021, 10:12 AM | #18 |
Rep 389
Drives: 18 BMW M2LPower
that is correct, several cases.
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
07-03-2021, 10:20 AM | #19 | |
Rep 389
07-03-2021, 09:59 PM | #20 |
Rep 3,368
08-12-2021, 05:20 PM | #21 |
Rep 15
I have my car back! The new turbo is in, and the old turbo is out and I still have no idea what happened.
I went to my mechanic (Dan Gerber at Gerber European Auto) and he installed the new Vargas GC turbo. The old turbo spins smoothly and freely, and Dan said he couldn't see any other issues that would have caused the turbo to fail. So now I need to decide about tuning, and whether I should leave it stock or not. This was not an inexpensive event, but I know there is a lot of potential there and I miss the push of the BM3. I also now have a used turbo that I think doesn't work. Edit: I've only driven it for about 35 minutes, but can tell that it has noticeably more power than it did previously in stock mode. It might be my imagination, but I feel like the power comes on a little later with a touch of lag, but it's all very smooth. Last edited by Fodase; 08-12-2021 at 05:52 PM.. |
G.Newt810.00 |
08-12-2021, 06:31 PM | #22 | |
Rep 1,454
