BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Likely production schedules for G87 M2, G80 M3, G81 M3 Touring and G82 M4
      02-16-2021, 11:58 AM   #67
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Originally Posted by MightyMouseTech View Post
It still has a belt driven system connected to the motor/generator.
It does with BSG, not with ISG.
Lemania 2320
      02-16-2021, 12:18 PM   #68
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Have never heard of ISG adoption at BMW, only BSG, and they are only now rolling out BSG.
      02-16-2021, 12:22 PM   #69
mkoesel
Moderator
Drives: No BMW for now
Thanks for the link. I now remember reading this back around the time it was published, but as you point out, BMW has since adopted the belt driven system across their lineup on the B47, B57, and B58.
Perhaps the next generation of gas/diesel models will switch to an integrated system. However, it would seem that the window is closing. We already know much of the G70 model lineup, and it is very PHEV and BEV heavy. Given that focus, is it worth investing more in the MHEV engines at this point? The lifespan could be limited since it is entirely conceivable that, starting with the following generation at the end of this decade, every model in the entire BMW lineup will be PHEV or BEV.
I think the direction they choose with the B48, since it has not yet received a 48V system, could be a good indicator of where they will go. Alternately, the S58 that you mentioned and the upcoming new S68 are also slated for 48V, so those present another possibility to begin the switch to ISG. But for right now, I don't think we can call this a slam dunk.
      02-16-2021, 12:28 PM   #70
SW19
SW19's Avatar
2456
Drives: 2016 Alpine White M2
The only chance for the G8X to get a mildly revised grille is when the S58 adapts the 48V system where belts are all removed and the engine accessories may get repositioned which warrants a front fascia update.
Be noted, the 48v talked about here is the ISG system (check Mercedes I6 and V8 48Vs), not the way too technologically inferior BSG system found from current B58 variants.
Could be the S59 engine to improve efficiency and fix turbo lag with electric boost, although to the vast majority fixing front end aesthetic is much more important.
Do we know for sure that BMW won’t add a 48v hybrid system to the S58 engine until production ends for the G80,G82 and G87?It would be nice to know because i don’t want a hybrid M car.
      02-16-2021, 01:29 PM   #71
mkoesel
Moderator
We don't know for sure. However, forum member lemetier has strongly hinted that it will come sometime during the G8x run.
These aren't hybrids in the traditional sense. It's basically an evolution of the 12V electrical system found in cars for a century or more. It allows for efficiency gains through brake energy regeneration and provides a small electric power assist to the engine.
However, there is indeed a small weight penalty attributed to the additional hardware, and I think that auto start/stop can no longer be switched off (but that could theoretically change for M models).
SW192456.00
      02-16-2021, 01:29 PM   #72
doogdeb
Drives: BMW G42 M240i XDrive
It's highly unlikely BMW are going to leave Europe without an M2 to buy for the best part of 2.5 yrs. The new 2 series is due out sometime this year, so expect M2 within 6 months of that.
G42 M240i, Brooklyn Grey, Cognac Interior, M Technology Pack, M240i Pro Pack, Technology Plus Pack, M Adaptive Suspension.
      02-16-2021, 01:33 PM   #73
mkoesel
Moderator
ynguldyn has a very solid track record.
I don't mean to discourage you from whatever belief system you wish to follow - please do continue. However, I would be remiss if I did not remind forum members to be skeptical of alternate theories, especially those from unproven sources with no supporting evidence.
Swappy531.50
kfscoll208.50
      02-16-2021, 01:52 PM   #74
BMWGirlFL
BMWGirlFL's Avatar
6276
Drives: Z4 M40i
ynguldyn M2 support:
https://f92.bimmerpost.com/forums/sh....php?t=1698838
https://f92.bimmerpost.com/forums/sh....php?t=1702708
Artemis29376.00
      02-16-2021, 02:27 PM   #75
doogdeb
I should have put "so would expect M2 within 6 months of that". Not based on anything other than the fact that M cars rarely come out several years after new model is released. Also, I'm in the market for a new car in 2022, so hoping the new M2 will be out by then
      02-16-2021, 02:31 PM   #76
mkoesel
Moderator
This isn't a fact though. It's false.
M cars routinely come out several years after a new model is released. I'll let you confirm that on your own. A good place to start would be the F22 and F87 release dates.
Luckily, that gives you plenty of time to be convinced it's absolutely not happening and make other plans.
      02-16-2021, 02:38 PM   #77
doogdeb
Sigh! F22 was 2014, M2 came out 2016. Not surprising when it was brand new M car which never existed before.
      02-16-2021, 02:42 PM   #78
mkoesel
Moderator
Great sleuthing!
Now check:
E90 3er and E90 M3
F30 and F80
G20 and G80
      02-16-2021, 02:43 PM   #79
SeanWRT
SeanWRT's Avatar
3179
Do we know for sure that BMW won't add a 48v hybrid system to the S58 engine until production ends for the G80,G82 and G87?It would be nice to know because i don't want a hybrid M car.
I don't consider having 48V as being hybrid. Especially with ISG, it's basically just getting a much more powerful starter alternator motor mounted in between the engine and transmission. So that:
1) Brake energy recycled much faster
2) All engine accessories to be electric driven, way more reliability and efficiency (Ask E92 M3 owner how they gets an instant 20-30whp by just using a smaller pulley)
3) ISG adds noticeable and instant torque at low down where the S58 is lacking the most.
4) ISG can even power the supercharging system (MB I6 EQ boost).
I consider all of above very traditional ICE techs.
Lemania 2320
SW192456.00
      02-16-2021, 02:45 PM   #80
doogdeb
Great sleuthing!
Now check:
E90 3er and E90 M3
F30 and F80
G20 and G80
I did say 'several' years, not a couple.
      02-16-2021, 02:51 PM   #81
mkoesel
Moderator
Your original comment was "M2 within 6 months" which, having cross referenced the release dates of other models, hopefully you can now accept isn't going to happen.
      02-16-2021, 03:17 PM   #82
Artemis
Moderator
Artemis's Avatar
29376
Drives: BMW M2 Competition
  • Aug 2021: production of G42 2er starts;
  • Dec 2022: production of G87 M2 starts;
  • March 2025: production of G42 2er and G87 M2 ends;
  • April 2025: production of G42 2er LCI (facelift) and G87 M2 LCI (facelift) starts;
  • March 2029: production of G87 M2 LCI ends;
  • July 2029: production of G42 2er LCI ends.
See the timeline here.
///M is art Artemis
      02-17-2021, 01:35 AM   #83
farishat
farishat's Avatar
Drives: 2004 E46 330i ZHP, 2024 G80 M3
What is the LCI going to look like? Tone down the Beaver Grill?
      04-25-2021, 01:18 PM   #84
Artemis
Moderator
Artemis's Avatar
29376
Added to the first post of this thread:
  • March 2022 - March 2023: production of designs celebrating 50 years of M GmbH for multiple models;
  • Nov 2022: G81 M3 Touring (Competition xDrive) start of production (featuring the G80 M3 LCI changes) (no US-spec model);
  • June 2026: G81 M3 Touring (Competition xDrive) end of production;
Source:
Originally Posted by ynguldyn View Post
March 2021
An obvious bit: BMW is planning to have designs celebrating 50 years of M GmbH for multiple models with production dates between March 2022 and March 2023.
August 2020
(Trying to redeem myself for not being the first to report on G81): I can now confirm that BMW has no plans to offer a US version of G81. For the rest of us, expect it no earlier than G21 LCI in mid-2022.
March 2021
For the readers outside North America: G81 will start production in November 2022 and have a full run up to the end of production of G21. There will be a single model: Comp xDrive. As expected, it will be in LCI configuration (for instance, the new i4 widescreen dash will be standard). As far as I can see, everything that you can have on a G80, will be available on G81.
Expected SOP dates for new models:
November 2022:
G81 M3 Touring Competition xDrive. (Or is it M3 Competition xDrive Touring? Or M3 Competition Touring xDrive? These days - no one knows.)
///M is art Artemis
BMWGirlFL6275.50
      04-25-2021, 01:22 PM   #85
Artemis
Moderator
Artemis's Avatar
29376
What happened/happens in G80/G82 Kidney Land, stays in G80/G82 Kidney Land.
///M is art Artemis
BMWGirlFL6275.50
      08-09-2022, 09:06 PM   #86
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Reviving this thread....
So given that now it is Aug 2022, has the production of G80 M3 LCI started?
      08-10-2022, 08:57 AM   #87
wtwo3
wtwo3's Avatar
17971
Drives: 23 X7 40i; 23 M3; 24 cooper s
yup, it started up last month.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT
2024 Mini Cooper S Convertible
'20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima
      08-10-2022, 09:45 AM   #88
vj123
vj123's Avatar
Drives: 2022 M3c - sold
Originally Posted by Artemis View Post
  • Oct 2025: G80 M3 LCI end of production;
  • June 2027: G82 M4 LCI end of production;
G80 and G82 EOP has to be updated based on the latest info from ynguldyn.
Artemis29376.00
